Brake disc (Rotors) question - BMW M5 Forum and M6 Forums
Old 22nd March 2009, 11:18   #1
shamus_mcd
shamus_mcd's Avatar
Garage: E39 M5 in Titanium Silver
After having a look through the M-registry I noticed the USA vs the Europe M5's have different front discs?
European has floating discs to get rid of heat quicker thus less chance of warpping and USA cars have 1 piece no floating.
My question is why?
Does the USA cars discs warp easier if not why the difference?
Next question would USA discs fit European cars and visaversa?
Life is not Measured in the amount of breaths you take,
BUT in the amount of times it takes your breath way....
///M5
I'm off to the ASTHMA CLINIC now!!!!!!
shamus_mcd is offline   Reply With Quote
Old 22nd March 2009, 15:31   #2
RoundelM5
RoundelM5's Avatar
Garage: 2003 M5 - LeMans Blue
Sales Feedback: (12)
Search will pull up a lot on this. Yes euro rotors fit US-spec cars so i assume reverse is true. Lots of US guys go to euro rotors as an upgrade. Euro rotors are even cheaper I think and are available from a number of sources.
'03 Lemans Blue/Black
Suspension: Ground Control coilovers 550F/400R, Dinan adjustable rear sway bar, TC Design Rear Swaybar Brackets
Drivetrain: Dinan 3.45 differential and LTW flywheel, Rogue SSK w/ WSR
Wheels/Brakes: Dinan LTW wheels, TMS 75mm Wheel Studs
Intake/Exhaust: AA CAI and brake ducts with IATS relo, Supersprint headers with Tubi Regular cat-back exhaust
Cooling: Gulf oil filter housing and Setrab 16 row oil cooler
AngeliBright v2.0 w/ matching fogs and highbeams
BMW Bluetooth, Sirius, First Aid Kit
'95 M3 Track Car CosmosSchwarz
Motor: stock S54; VAC rod bears and high-volume competition oil pump; Dr. Vanos cryo-treated exhaust hub
Suspension: BW/JRZ DA coilovers 800F/950R, TMS sway bars, camber arms, monoballs, solid mounts and bushings
Drivetrain: BW strapless clutch/flywheel, AKG race shifter w/ WSR, DiffsOnline 3.64 variable ramp, polished gears
Wheels/Tires/Brakes: APEX ARC-8, Hoosier R6, BW 92mm/75mm wheel studs, BMW OE calipers, PFC06 pads, PFC DD rotors, BW brake cooling
Intake/Exhaust: VAC carbon fiber race intake, Epic race headers and AA 3" race exhaust
Tune: Epic alpha-n custom software
Cooling: Bimmerworld/C&R aluminum race radiator and oil cooler; Spal 2-speed fan
Safety: Full cage, Cobra Evolution driver seat and Cobra Imola passenger seat, Schroth Hybrid-II HANS harnesses, SPA fire system, Schroth window/center nets
Aero: BW splitter and wing
Data: AIM Pista MXL and SmartyCam
RoundelM5 is offline   Reply With Quote
Old 22nd March 2009, 16:51   #3
TurboCarrera
Garage: 00 M5 Silver
I've had both the US and Euro disks on the my M5 and haven't seen any noticeable performance differences on the street.
Steve
00 M5
TurboCarrera is offline   Reply With Quote
The Following 2 Users Say Thank You to TurboCarrera For This Useful Post:
jclyman (22nd March 2009), Lancefitzgiben (23rd March 2009)
Question re Bedding New Brake Pads and Rotors . . . Rcl4668 E39 M5 and E52 Z8 Discussion 7 7th September 2007 02:54
i need rotors! [Source for cheap M5 brake rotors?] devioushaze E39 M5 and E52 Z8 Discussion 6 30th April 2007 23:45
Question, Brake rotors of E60 and E39 M5...... FAST 5 E39 M5 and E52 Z8 Discussion 0 3rd March 2004 21:27
QUESTION: Regarding M5 disc brake rotors................ FAST 5 E39 M5 and E52 Z8 Discussion 5 25th March 2003 23:51
Warped brake disc kirk7 E39 M5 and E52 Z8 Discussion 2 22nd February 2003 18:07
