UK Members-Bosch Battery 110Ah, 920 CCA - Page 7 - BMW M5 Forum and M6 Forums
LinkBack Thread Tools Rating: Thread Rating: 4 votes, 5.00 average. Display Modes
Old 22nd March 2012, 01:42   #61
ger
ger's Avatar
Garage: M5 Le Mans Blue
Found that euro car parts has a sister site (carparts4less.co.uk) that doesn't have many discounts, however, the Bsoch battery sells for about £115, next day delivered. Could come in handy!
Have a look at this link:
Bosch BATTERY 110Ah - Car Parts 4 lessCar Parts Retailer
I hope this saves some money for you guys!
11/2000 M5 Le Mans Blue
My car's thread
ger is offline   Reply With Quote
Old 28th May 2012, 11:06   #62
Hakon
Hakon's Avatar
Garage: M5 Carbon 02
Battery gave up on the weekend with the doors open for an hour or two... I even remembered to swithch the lights off !
Old battery had the black eye, so popped to ECP and £133 ish later, an S5 bosche number. Slightly smaller in size, so a bit of insulating tape
was used. Initail start up much quicker and stronger and better low down pick up ?
Gervase
Hakon is online now   Reply With Quote
Old 28th May 2012, 12:25   #63
M5_MONSTER
Garage: Supercharged e39 M5, Stock F10 M5
This battery is a monster, and a great choice over oem, and price is great too
M5_MONSTER is offline   Reply With Quote
The Following User Says Thank You to M5_MONSTER For This Useful Post:
M5 London (28th May 2012)
Old 29th May 2012, 15:56   #64
NAT
NAT's Avatar
Garage: E39 M5 LE MANS BLUE
Well the original battery was 9 years old and I decided to change it as a preventative measure. At the time there was £10 between an alternative and a BMW battery so went for the BMW battery. Well its started playing up even though its only 3 years old. Doesnt last more than 4 days , somethimes less, and even after a long run , 5 minutes with the door open you get the dreaked click of death.
I have no battery drain issues that I know of and the magic eye seems to be as usefull as a chocolate tea pot to indicate the real battery health.
Its on a trickle charger now and thats helped but clearly its on its way out.
Eurocarparts, have the Bosch S 5015 for £113.87 delivered to your front door so have bought one just now.
That should solve the issue.
Use discount code BATTERY 15 @ checkout for a 15 % discount.
Cant grumble at that price.
Nat.
NAT is offline   Reply With Quote
Old 29th May 2012, 17:29   #65
Hakon
Hakon's Avatar
Crap ! and I had a look for a discount code...
Shout out to Mr K for the leg work on this.
Gervase
Current across battery?, what size is correct battery? AndyHudds E34 M5 Discussion 10 10th May 2008 00:09
Weak battery headzup! [SMG stuck in gear due to battery drain] Mr. Vroom E60 M5 and E61 M5 Touring Discussion 7 12th May 2007 03:30
Battery 100ah or original 110ah ? iMac E39 M5 and E52 Z8 Discussion 3 16th January 2007 18:52
Bosch Battery Code M5 powered E34 M5 Discussion 1 22nd November 2006 22:39
Battery Location and Charging (Was "Where is the battery located...) FAST 5 E39 M5 and E52 Z8 Discussion 24 14th April 2003 21:15
