15th March 2009, 00:40
#1
OEM LUK clutch fails at 3,000 miles...
So last night, I took out my M5 for a spirited drive and the clutch started smoking. This morning, I went to move it and the clutch was dead and didn't catch at all.  I thought this clutch was meant to be durable. These 3,000 miles do not include any track driving, as it has been winter up here in Michigan.
15th March 2009, 00:50
#2
00 Carbon m5
noway that cant be right...3k miles? are you sure your clutch is the problem?
The Following User Says Thank You to razahyde For This Useful Post:
15th March 2009, 00:53
#3
absolutely 100% confident that it is the clutch. The clutch pedal goes to the floor and when it engages, you can feel the engine rev and the car starts to creep as the clutch gets slight grip. This is my 6th BMW, so I know how to take care of them, etc. I am irritated that I didn't get a UUC clutch/flywheel combo. I have that on a few of my other cars and that is a bullet proof package.
15th March 2009, 01:14
#4
2000 M5 Alpine White
Where did you get it from? Could it have been a defct.?
'00 BMW ///M5 Alpine White
Mods
Evolve stage 3 tune
Schrick cams
Hamann Headers (High temperature coated inside and out)
Custom made exhaust (cat delet)
KW Coilovers V3
WP Pro BBK (360 mm rotors, 8 pot calipers front, 6 pot calipers rear)
15th March 2009, 01:27
#5
2003 M5 Sterling Gray
Can you describe "spirited drive" and how you engaged the clutch during that drive in detail?
Dinan 3.45 differential
TMS Shark Injector - 91 Octane tune
IATS Relocation - Inside Air box
Strong Strut front brace
TC Design rear swaybar brackets
Bluetooth
V1
Aux port
The Following User Says Thank You to M5CCIE For This Useful Post:
15th March 2009, 02:30
#7
Do a search on UUC clutches on here, I understand that UUC is a great company and have good clutches, but search clutch threads to pic the best UUC clutch for your car, also CNS which is what I put in my car recently seems to be fine so far (think there is one forsale "new" on the for sale section), but I am still in the break in period and I am not hard on my car as others may be....and of course there is a Dinan clutch/flywheel and I think they are still running a 15% rebate. Good luck and sorry to hear about your clutch, but the stock M5 clutch maybe a little light for a 4000lbs 400hp beast with the usual burnouts and doughnuts, but I am not the one to ask.
James
15th March 2009, 02:55
#8
Originally Posted by Jeuprx-8
A few burnouts and doughnuts.. Still, it is nothing that I haven't done in my M3 or M roadster, without any problems
Your M3 and M Roadster don't have the torque of the S62.
The E39 M5 clutch is a known weakness.
"A few burnouts and doughnuts" isn't exactly most peoples' definition of a "spirited drive", I wouldn't imagine.
What you have here is one of two things:
- You're abusing the clutch, whether you know it or not.
- You got a defective part.
When engaged/disengaged properly, an E39 M5 clutch will last much longer than 3,000 miles.
Ben
2000 Estoril Blue M Coupe [Perfection]
2000 Biarritz Blue 528i Touring [Hauler]
1989 Alpine White S50 325i [Fun Machine]
1967 MGB GT [Classic]
The Following User Says Thank You to Ben Carufel For This Useful Post:
15th March 2009, 03:36
#9
2001 m5, 2003 525it
The pedal goes to the floor? Sounds more like hydraulic problems. Check your fluid, lines, slave and master cylinders, before diving into the tranny. Make sure the slave cylinder is pushing the clutch fork. The brakes use the same resovoir as the clutch, but the clutch line is above the brake, so a fluid loss in the clutch would not drain enough fluid to kill your brakes.
If you do remove the tranny, and the clutch appears ok, make sure you check flywheel as the dual mass flywheel could have failed and give the same symptoms as a slipping clutch. However, when you say "pedal goes to the floor, it makes me think hydraulic. Typically a cooked clutch still has an ok pedal, unless the pressure plate totally failed.
Dont feel bad I spent a triple the cost of the Luk on a UCC that never worked!
Please post what the problem was, so in six months when someone visits this post we will know what happened to yours.
A few burnouts shouldn't kill the clutch, but, slipping or riding it under high revs will!
15th March 2009, 15:20
#10
Shill account for CNS Racing
M5 modded
There really is only one option for you with your driving style. Check out the CNS clutch. Mine has been through some serious abuse and it lets me enjoy my car without having to baby it plus it has all the oem benefits.
http://www.cnsracing.com/product.sc?...=2&productId=1
Shark Injector RACE Version 93 (Tuned By Jim Conforti)
CNS Racing Power Clutch kit - Oversized 10.5 Inch Carbon Metallic disk w/ lightweight Dualmass flywheel(DINAN S3 Design w/ zero gearlash noise)
Supersprint Headers with JETHOT coating (Extreme Sterling)
CNS Racing Cat-Back Exhaust
OZ Racing Superleggera III Bright Silver Wheels 19x9-2.5"lip, 19x10-4"lip - three piece forged.
Evosport Under-Drive Audiophile Pulley Kit
Custom Magnaflow High Flow Metallic CATS (#59926)
Innovative LM1 Wideband Air/Fuel ratio kit
Powerflex Front Thrust Arm and Sway Bar bushings
Cool Ride Thermal Reflective Panel under Air Plenum
Stoptech/SportStop slotted rotors with Axxis Deluxe pads
Bavauto Teflon Stainless steel brake lines
MB Quart Reference RUA213 Component Speakers, 12inch Kicker Subwoofer, RF AMP and XM Radio
Peake R5/FCX(II), Compaq PDA PocketPC OBDII realtime OBDpro Serial Scantool
Euro Clear headlights, 8K Xenon, Predator Angel Eyes Rings, Clear bra, Lamin-x, Euro Smoked tail lights
UFM IATS Relocator
Pro BEL RX65 Radar Detector direct wired and BLINDER Laser Jammer.
AFE Pro Dry S Intake with custom RAM air ducts
UMNITZA sink drain brake cooling grill
Carbon Fiber rear diffuser, front kidney grill and front Hamann look lip spoiler
Hamann DTM rear spoiler
Solargard 5% Tints, Ultimate Cup Holder, Full LED interior lights and exterior blinkers, Clear Bra
CNS Racing 3.62 Differential, suspension and sway bar upgrade
Royal Purple Synchromax.
CNS Racing Oil Separators/10W60
UUC RK6A-L knob
Alutec Strut Bar
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
