the title says it all... does the K&N filter improve MPG? Does it ruin your mafs? is it worth it? ive done the searching but come up still with two sides to it and im just trying to find out for myself.... any feedback on the issue would be accepted..
2001 ///M5 Ti Silver, Black sport interior
UUC Big Boy Clutch Stop V3
RPM North Exhaust Bypasses
Resonator removed
Stoptech Slotted Front and Rear
Stoptech SS Brake lines
Axiss ULT Pads Front and Rear
ATE Blue brake fluid
E60 550i SSK w/ RE WSR w/ ZHP knob
DDMTuning Headlights xenon 6000k
DDMTuning Foglights xenon 6000k
Ultra HD 60+ LED angel eyes
Matte Black kidney grills
Matte Black rear diffuser
Matte Black ///M5 badge
Chrome/amber bulbs
20% Tint all windows
V1 hardwire
OEM ///M5 floormats
OEM trunk cargo net
OEM Black M5 plate frames
MK4 DVD navi
Various opinions, but I note that Dinan uses K&N for his CAI.
If you are going to use K&N, oil it and then let it sit for a day or two to make sure any/all excess oil has evaporated. Most folks over oil.
It seems if you don't allow them to thoroughly dry, oil used to impregnate the filter can get past and foul the MAF's.
i would buy em and stick em in without putting extra oil on it... but does it do anything say as in mpg or is it just there for cleaner air cause mostly what i researched was people just change oem air filters every oil change
Resonator removed
Chrome/amber bulbs
V1 hardwire
OEM ///M5 floormats
OEM trunk cargo net
MK4 DVD navi
K&N's rely on the oil to filter out some of the particulate - I wouldn't use them without it. Then again, given the number of MAF foulings, I wouldn't use them with it, either...
I've often considered this too. I dont think the miniscule gains in HP or MPG would justify risking your MAFs being fouled. Actually I dont think the high price of the K&N filters justifies the tiny *supposed* increases in power or economy personally.. And I've used K&N in every vehicle I've owned, right up to when I bought the 535. I like the OEM paper german filters- they're robust & do a fine job. Why bother changing to something else? Just keep renewing the OEM filters every few thousand miles, and you wont have any filter-fouling-MAF issues at all.
And to the people that run K&N filters, thats ok too- you obviously arent over-oiling them, if they work ok. But I'm sticking to the OEM paper type until someone can prove there's a really good reason to use K&N
1996 Black-on-black BMW ///M535i E39 (euro):
ok so it seems that i will just change the oem filters every oil change and not risk fouling the mafs and since there is no real "huge" gains which i wasnt expecting really but thanks guys
Resonator removed
Chrome/amber bulbs
V1 hardwire
OEM ///M5 floormats
OEM trunk cargo net
MK4 DVD navi
Unless you are changing your oil every 25K changing the filters every oil change is just throwing money away.
d-
The Following 2 Users Say Thank You to DouglasABaker For This Useful Post:
