Old 9th March 2009, 16:04   #1
timmay77
timmay77's Avatar
Garage: M CINCO
Sales Feedback: (3)
Radiator Fluid Change/Flush
I did search this, but need a little more info.....
I am reading that it is better to have the dealership do this since it is messy and very difficult to get all of the air pockets/old fluid out. I have also read to ONLY us BMW fluid, no problem, I am down with that.
My issue is both of the BMW dealerships in Columbus have absolutely no idea what they are doing. I called both MAG and Kelley BMW and asked them about a radiator flush, $139+tax at both places, not too bad. But when I asked them what their method was for flushing, the SA had no clue. I asked if they flushed it with a machine or just pulled the drain plugs and then filled it back up? They BOTH had no clue, not very comforting. The guy at Kelley later in the conversation said "We definitely do not use a machine."
Should I keep looking for an Indy in Columbus? Is the "flushing machine" something I just made up in my head?
__________________________________________________ ____________________
Originally Posted by Hdhntr23 View Post
I like strippers.
Current Mods
~Complete Alpine/Memphis aftermarket stereo system w/ Navi-Bluetooth-Ipod-DVD-HD Radio (Thanks Jun)
~E60 SSK ~ Illuminated ZHP Shift Knob (Thanks Starscream) ~ Ebay Ebrake Handle
~Euro Headlights (Thanks Raza) ~ Angel iBright V.3 ~ French Fogs ~ DRL Angel Eyes ~ Silverstar turn signals
~Full LED interior light upgrade
~Muffler delete with custom made Timmay77's "Signature" ///M5 - MCINCO etched staggered tips
~OEM 18x9.5" rear wheels at all 4 corners (Thanks Surge709) with 3mm Ebay spacers on the front.
~Dunlop SP Sport 9000's 275/35/18 (Thanks killer diller)
~B&G Suspension lowering springs
~Hardwired Valentine 1 (Thanks hdhntr23)
Timmay77's complete aftermarket stereo build thread: http://www.m5board.com/vbulletin/e39...et-system.html
2001 Jet Black/Black ///M5 ("M CINCO")---07 Infiniti G35S (POS) /SOLD---02 E46 TiAg Cabrio/SOLD and dearly missed
timmay77 is offline
Old 9th March 2009, 18:23   #2
H8Rain
H8Rain's Avatar
Garage: Silver E39 Beauty
This is exactly why I like to do my own work.
But to answer your question..... IMHO I have always just drained and filled (no flush). Now when I say drain, I mean the rad AND the block plugs on both sides.
It's a bit of a pain but I enjoy it, plus I then have the satisfaction of knowing it's been done right.
Good Luck.
MINE: Garage Queen with way to many mods to list.
HERS: X5 4.4
GONE: 1985 318i
H8Rain is offline
Old 9th March 2009, 18:33   #3
gsfent
gsfent's Avatar
Garage: 01 M5 Black/caramel
Not unusual the SA doesn't know. Ask to speak to the tech who would do the job. If he can't satisfy you, run, don't walk, from the dealership.
I don't think it is rocket science to flush the system, just a little messy. Any competent indy who works on BMW's should be able to handle this.
gsfent is offline
Old 9th March 2009, 19:38   #4
timmay77
timmay77's Avatar
Garage: M CINCO
Sales Feedback: (3)
I usually do ALL of my own work, I just read some of the threads on here about air pockets and ruining an engine. Not that an M5 coolant system us different from my Accord system, I just don't want to take any chances. So I thought maybe I should just come off of $140 and pay the dealership to do a true FLUSH and not just a drain and fill like I can do at home. But it looks like they do not do a true flush anyway, so DIY maybe in my future....
I like strippers.
Current Mods
timmay77 is offline
Old 9th March 2009, 20:18   #5
DouglasABaker
DouglasABaker's Avatar
Garage: 2002 Chiaretto Red M5
Follow the TIS instructions (posted here somewhere) for bleeding the cooling system and you'll be fine. It isn't rocket science, and the M5 engine is no different than others, except it produces more energy and therefore hotspots are more of an issue.
d-
DouglasABaker is offline
Old 10th March 2009, 00:20   #6
TMcNasty
TMcNasty's Avatar
Garage: '03 M5 - LMB/Blk int./Alu. trim
I think I'll just drain the radiator yearly. Save the $, the fear, and the mess all at once.
TMcNasty is online now
Old 10th March 2009, 02:05   #7
nightkrawler
nightkrawler's Avatar
Garage: Lemans Blue M5
dear lord, you guys swear you were talking about changing rod bearings... its antifreeze, lol. drain the radiator, the drain the block on both sides. mix the coolant 50/50, turn the ignition on and set the heater to minimum speed/max temp. slowly pour the coolant in till it reaches to almost the top of the expansion tank. start it up and get it up to operating temp so the t-stat opens. let it cool back down and then re-check the level. there is also a vent screw in a line under the drivers side microfilter housing if you really want to be sure there is no air pockets.
nightkrawler is offline
Page generated in 0.12428 seconds with 10 queries
