Old 7th March 2009, 19:36   #1
herrubermensch
herrubermensch's Avatar
Garage: LeMans Blue 2001 BMW M5 with black and blue extended leather and brushed aluminum trim
Sales Feedback: (3)
Send a message via Yahoo to herrubermensch
MKIV Nav Problem--Navigation Seems Lost!
I just completed a stereo installation (will post some pics soon) and reinstalled my MKIV navigation. Turns on, map comes up, but map position is totally wrong. Sometimes, it's just off by a road or two, sometimes it's off by a city or two! I thought it had been that I had a bad antenna connection, but replaced that with no improvement. Any thoughts?
The Beast
2001 E39 M5 LeMans Blue with Black/Blue Sport Interior and Titanium Trim, ESS Supercharger, RMS In-Plenum Intercooler, RMS Plenum Plates and "Shorty" Velocity Stacks, Dinan TBs and Headers, CNS Catback Exhaust, Evosport High-Flow Cats, Dinan 3.45 Differential, GC Coilovers (550 Front/325 Rear), Dinan Front and Rear Swaybars, Dinan Monoballs, Dinan Wheels (18 x 9 Front/18 x 9.5 Rear), Bridgestone RE050 RFTs (275 Front/285 Rear), UUC EVO3 SSK with DSSR, Voltphreaks VPR-S40P Endurance Battery (14 lbs.), Setrab 16-Row Oil Cooler, Dinan Under-Plenum Heat Exchanger Removal Kit, Vorsteiner Double-Sided CF Hood with Open Vents, CA CSL-Style CF Trunk Lid, Zionsville Super Duty Cooling System, OKD Plasma Ignition Coils and Plug Boots, Smoked Hella Tailights, Clear-Corner Hella Euro Headlights, CA ACS-Style CF Front Splitters, Custom Stereo Using Stock HU, PLX Digital Gauge, V1/S1 Mounted in UGDO Location, Recaro Sportster CS Seats, Schroth 4-Pt Street Harnesses, and Various Other Bits and Pieces
Coming Soon!
Stoptech "Trophy" Brakes, TC Designs Roll Bar, TC Designs Rear Sway Bar Brackets, Aquamist HFS-6 Meth Injection with Custom CF/Aluminum Trunk-Mounted Fuel Cell Designed by Howerton Engineering, XRP HS-79 Hosing, Rogue Stage 3 280mm Clutch with JB Racing LTW Flywheel, Dinan Differential Subframe Reinforcement and Dinan Foglight Deletion Kit.
When the Motor Blows
Balanced and Blueprinted S62
herrubermensch is online now
Old 7th March 2009, 20:48   #2
DouglasABaker
DouglasABaker's Avatar
Garage: 2002 Chiaretto Red M5
None that your going to like other than to park it in an open field for about 30 minutes with the ignition on and see if it can locate itself. If it does it should be able to stay "located". If it can't, then it is time to dig into the diagnostic menu and start checking signal strengths from the various satellites.
You said you replaced the antenna already - did you also replace the length of wire attached to it? It may very well be crimped somewhere and be preventing good signal transmission.
d-
DouglasABaker is offline
Old 8th March 2009, 10:00   #3
M Baker
M Baker's Avatar
Garage: 2003 M5 Lemans Blue, Caramel Leather
Three years ago I remember having to set up a Honda Navigation system right off the truck. At that time the instructions said after installing the fuse, slip the DVD in, then slowly drive it in a circle for at least 15 minutes in a completely unobstructed open area as it gets its bearings. I continually did a turning radius circle out in the middle of a parking lot and it worked. On the newer ones it calibrates during the mechanic's first road test.
When they first come in they all think they are in Southern California until they are calibrated. In otherwords, before calibration if I try to locate the nearest Starbucks (I'm in Seattle area), it finds them around Torrence, CA. (Honda's US HQ)
'90 M3 | '90 Talon AWD TSi | '99 Tahoe LS | '03 M5 | '10 Insight EX
M Baker is offline
Old 8th March 2009, 15:45   #4
herrubermensch
Sales Feedback: (3)
d-
Thanks, Doug. I will give that a try, but replacement of the antenna wire is next if that doesn't work.
--Peter
The Beast
Coming Soon!
Old 8th March 2009, 15:59   #5
IRISH M5
IRISH M5's Avatar
Garage: 03 M5 LeMans Blue
Sales Feedback: (4)
Peter, X5World Navigation System - X5world has the "mother load" of BMW navigation related information. Post a question there if you don't get the answer here.
IRISH M5 is offline
Old 8th March 2009, 16:10   #6
herrubermensch
Sales Feedback: (3)
Good thought! Thanks.
The Beast
Coming Soon!
Old 8th March 2009, 16:36   #7
DouglasABaker
The "drive in a circle" portion of that setup is actually to orient the compass - many OEM's use this same procedure when your built in compass gets lost. Other than that, it really is just a matter of waiting for the system to acquire an appropriate number of satellites (3 minimum) to locate your longitude, latitude, and altitude. The more satellites you have the more accurate your location.
Our cars also suffer the same "jet leg" from transportation with the vehicle off. When it first wakes up it will still think you are in the last location you left it (a logical assumption 99% of the time) until it gets enough satellites to realize it has been moved...
Doug
Old 8th March 2009, 17:14   #8
herrubermensch
Sales Feedback: (3)
The indicator in the upper right hand corner of my nav screen shows the globe, but does not read "GPS," so I don't think I'm getting any (or enough) satellite feeds. Hopefully, the new antenna connecting wire will do the trick. Still need to go into service mode and check settings for the gyro and all of that as well.
--Peter
The Beast
Coming Soon!
Page generated in 0.13120 seconds with 10 queries
