I have a 2002 with 49,xxx miles and while driving normally a few days ago with no noticeable exhaust “blatty-ness” or reduction in power my SES came on. My oil service light was one yellow light and one red light at the time and since I changed the oil less than 2000 miles ago I reset it using the odometer button method found here in the FAQ section. The following happened; my SES light went out and my yellow/red light was replaced with greens. I figured I was all set until after another ~200 miles normal driving followed by ~1 mile of “spirited” driving the SES light comes back up. Car still feels great and no noticeable noises/power loss. I have done the following;
1. Unscrew and retighten my gas cap
2. Ordered a set of eight OEM plugs
3. Ordered a Peake tool
4. Plan to do the MAF and thermostat check this afternoon
5. Plan to replace the fuel filter today
Questions;
1. Does resetting the service indicator light necessarily rest the SES light? I searched the crap out of this and still can’t determine if the Peake is the only method of resetting the SES.
2. Aside from the above five items for maintenance/trouble shooting is there anything else I should be looking at for a proper diagnosis?
That's odd that the oil service lights would change as well. Haven't heard of that before.
Hard to tell anything w/o that Peake reader, but as long as you're waiting you could add new air filters to your list of quick possible fixes. Pretty cheap and certainly easy to install.
I don't think service light reset will do anything to SES light.
And today might not be the best day for the thermo test. It's actually a little warm out. Warm air masks a bad thermo. You shoulda done it two nights ago LOL! Test it today, but retest during our next cold snap. Maybe tonight when it cooler out. Couldn't really tell mine was bad until about 55F last fall.
The Following User Says Thank You to TMcNasty For This Useful Post:
SES light went out by itself, the only things I did were to reset the gas cap, get a fresh tank of gas and swap out the fuel filter. I still haven't received my Peake in the mail yet so I'm assuming I can still go in and see what the codes were.
Update:
Got my Peake reader today (along with my plugs and valve cover gaskets) from BimmerZone (thanks for the very fast and free shipping!!). Codes pulled were;
63-Control unit self test, safety concept master check
35-Electric fan (relay)
62-Couldn't find this in the book
That would make a bit more sense, eh? Thanks. Unfortunatley for me I reset so I can't go check again. Now I wait until it comes on again.
Edit:
Everything I've read, assuming it's b2/b3, states I'm due for both rear oxygen sensors. $172 each on Tischer, part number 11781742051. No harm in waiting until they come on again so that's what I'll do.
