Old 7th March 2009, 04:35   #1
markuswithak
markuswithak's Avatar
Garage: 2001 jet black M5
20" wheel question
Is anyone running with 20's on an E39 M5? If so what size offset and what size tire combo? I am looking at 20x8.5's and 20x10's staggered but want to make sure it can be done without rubbing.....the wheels that I am looking at are a 20mm offset......Thanks
markuswithak is offline
Old 7th March 2009, 05:33   #2
razahyde
razahyde's Avatar
Garage: 00 Carbon m5
Sales Feedback: (29)
Send a message via AIM to razahyde Send a message via MSN to razahyde
20mm front, rear, or both?
remember to keep your tire in mind too, different tires have different tires walls. michelin ps2 for example run a stretch, while goodyears are square. that can make a big difference especially if you are lowered.
razahyde is offline
Old 7th March 2009, 06:20   #3
VetteRacer
VetteRacer's Avatar
Garage: 2000 Custom M5 & 87 Dark Red Vette
Send a message via ICQ to VetteRacer Send a message via AIM to VetteRacer Send a message via Yahoo to VetteRacer
My car had 20" iForged rims on it when i got it. Car would rub in the rear after a heavy hit on the suspension.. Have not had that issue since putting the 18's back on..
If you do a history search on me you will see the measurements I took with 18s vs 20s.
Matt
My Collection:
2000 M5 - Custom Avus Blue/Black; Black/Blue/Brushed Aluminum interior; Dinan mufflers; Dinan Stage 2 S/W; Dinan Flywheel; AGA/Dinan Rear Diff Reinforcement; Blackened OEM Wheels
1987 Vette - Dark Red Metallic; Tan interior; 383 Stroker motor, LPE cam, LPE headers, ported heads; Electric Power Steering and Water pumps; Gutted; Race suspension
1989 BMW K100RS - Special ABS Edition Blue/White; Luggage; Fox shock; Remus pipe
1999 BMW R1100S - Mandarine Orange; Low bars; Luggage; Ohlins Suspension; Remus Race pipes; FIM chip
Wifes car - Dark Silver 2006 Civic EX w/Nav
VetteRacer is offline
Old 7th March 2009, 06:26   #4
markuswithak
Yeah, 20mm front and rear....I believe stock offset is 20f and 22r?
Old 7th March 2009, 16:41   #5
ALPINE_M5
ALPINE_M5's Avatar
Garage: 03 M5 Alpine White/Cinnamon
I had 20" as well. The tires in order not to rub when hitting hard bumps would need be to 245/30/20 and 285/25/20. I rant his size as well as a few others. It is not as bad as you would think also they are really low in profile. The offsets were about the same. I ran an 11" rear.
Drive like you stole it!
2007 Porsche 997 Turbo - Carrara White|Black
ALPINE_M5 is offline
Old 8th March 2009, 18:58   #6
Terry Grant
Terry Grant's Avatar
Garage: 01 M5
I would advise against 20" wheels, it ruins the ride and the handling, I think Bmw knows best for putting 18's on!!
Terry Grant is offline
Old 8th March 2009, 22:17   #7
TCM
TCM's Avatar
20s are pushing it on the E39. The 19s are the real optimum for the size and performance compromise IMO.
T.C.
'01 Silverstone M5
SuperSprint:X-pipe
TCM is offline
Old 9th March 2009, 21:19   #8
INDIVIDUAL 5er
INDIVIDUAL 5er's Avatar
Garage: '03 Aegean Blue/Champagne 540i (Sport/M-Tech)
Send a message via AIM to INDIVIDUAL 5er
I've got 20's in...
Original BMW Style 101M (from Sports 760Li) staggered rims (F= 9" & R =10").
Since the offset was 100% correct, I only had the center bore drilled out to fit my 5 series (only because I wanted these rims).
Running on Pirelli P-Zero Nero in the size: 245/30/20 (front) & 285/25/20 (rear).
You need this low of a profile on 20's or you'll look like a hick in a 4x4.
Also keep in mind that some 20" designs look too big for the e39 body.
PLEASE, only take clearance advice from someone that's been running a correct setup, with less than 3% variance from stock diameter.
In your case.....I guess...you need to speak to someone who is running on the same 20" offset.
I orginally feared a harsh ride, but suprisingly was proven wrong.
My car runs smooth on stock M-Tech II sports suspension (not much differrent than M5) w/out any rubbing what-so-ever.
One just has to keep an eye on tire pressure and avoid potholes.
The only change I will make is eventually switch my front size to 255/30/20, which esthetically looks better with a 9" rim.
Good Luck !
INDIVIDUAL 5er is online now
Old 12th March 2009, 18:35   #9
markuswithak
Thanks for all the replys, I decided to go with 20's, I will post some pics after they are on....
2001 M5, Jet black/black leather, Shark injector (race version), UUC Short Shifter, LUK Upgraded Clutch and dual mass flywheel, Ron Davis Custom Aluminum Radiator, AFE cold air Intake System, Upgraded cross Drilled/ Slotted Brakes, Complete custom exhaust with mandrel 3” x-pipe and Magnaflow mufflers, no cats or resinator, Angel iBrights, 20 tint all around, 20" staggered black Maya EX2 wheels/tires
Page generated in 0.12476 seconds with 10 queries
