Old 6th March 2009, 23:21   #1
jfmcclung
Garage: '02 M5 Lemans Blue
suspension bushings
I'm looking to replace my front suspension bushings. I would like to upgrade from stock if possible. I have heard of Powerflex but don't have much info about them. Any suggestions would be appreciated.
Thanks in advance.
jfmcclung is offline
Old 6th March 2009, 23:24   #2
timmay77
timmay77's Avatar
Garage: M CINCO
Sales Feedback: (3)
There is some info here on the board, try doing a search on Power Flex. TMcNasty has them on his car, he posted a thread about it that I just read this week.....
__________________________________________________ ____________________
Originally Posted by Hdhntr23 View Post
I like strippers.
Current Mods
~Complete Alpine/Memphis aftermarket stereo system w/ Navi-Bluetooth-Ipod-DVD-HD Radio (Thanks Jun)
~E60 SSK ~ Illuminated ZHP Shift Knob (Thanks Starscream) ~ Ebay Ebrake Handle
~Euro Headlights (Thanks Raza) ~ Angel iBright V.3 ~ French Fogs ~ DRL Angel Eyes ~ Silverstar turn signals
~Full LED interior light upgrade
~Muffler delete with custom made Timmay77's "Signature" ///M5 - MCINCO etched staggered tips
~OEM 18x9.5" rear wheels at all 4 corners (Thanks Surge709) with 3mm Ebay spacers on the front.
~Dunlop SP Sport 9000's 275/35/18 (Thanks killer diller)
~B&G Suspension lowering springs
~Hardwired Valentine 1 (Thanks hdhntr23)
Timmay77's complete aftermarket stereo build thread: http://www.m5board.com/vbulletin/e39...et-system.html
2001 Jet Black/Black ///M5 ("M CINCO")---07 Infiniti G35S (POS) /SOLD---02 E46 TiAg Cabrio/SOLD and dearly missed
timmay77 is offline
Old 7th March 2009, 08:05   #3
TMcNasty
TMcNasty's Avatar
Garage: '03 M5 - LMB/Blk int./Alu. trim
jf I have them on my car for the last couple k miles. No complaints at all. I actually think they are excellent so far. Will do a sprintime inspection when it's a bit warmer and I'm draining tranny fluid.
All 4 front control arms and the front swaybar are poly. I run TCD (search to find out what they are) rear swaybar brackets but could not get the PF bushings to fit using them...went with OEM rubber instead back there.
There was another recent thread here where someone wanted to install PF also. In it I described the drill-out procedure for the OEM rubbers. I suggest you read that. It is a PITA just for the record. The OEMs can also be pressed out, but I tried that and couldn't get anywhere w/ the control arms on the car.
Allegedly there used to be threads regarding PF's here, but if you search you won't find much. If you wanna go for it you kinda need to do a leap of faith like I did and just order them and install them. There's a bit more info. on PF's on other BMWs in various locations including other BMW sites, but getting M5 info. on this kit is like trying to get Yoda to teach you to use the Force.
For various reasons people here mostly don't run 'em. Most notably is the fact that the BMW X5 thrust arm bushing can be pressed into an M5 control arm and solve the issue of the weak OEM M5 thrust arm bushings. Most peeps seem to just go that route. The other lower control arm bushings up front don't seem to be nearly as problematic as the thrust arms.
TMcNasty is offline
Old 7th March 2009, 14:32   #4
everycredit
everycredit's Avatar
Garage: 2000 E39 M5 Carbon Black
I need my FCAB replaced myself.
everycredit is offline
Old 8th March 2009, 21:07   #5
jfmcclung
TMcNasty,
Thanks for the help. You right, there's not much info on this site about them. I checked before posting as is the etiquette. I'll give the PF ones a try. They're pretty cheap it looks like. Labor is going to be the expensive part. Damn pot holes here in the Midwest are rough on the Beast.
Old 8th March 2009, 21:27   #6
xotickiller
xotickiller's Avatar
Garage: 2001 M5 Royal Red / caramel
Like I said before, got them in mine and love them
go BIG or go home...
2001 M5 Royal Red/Caramel/Walnut
Britalman exhaust
http://www.youtube.com/watch?v=W0eIx51GskE
fireproof!
2000 540i Blue/Gray/Walnut
got lost in the fire.....
http://www.youtube.com/watch?v=WrcGN_ZSgQY
http://www.youtube.com/watch?v=p8Ah30J9CAI
xotickiller is offline
Old 8th March 2009, 21:35   #7
ortontom
Garage: M3 blue E46 convert, E39 M5
next monday i'll have my powerflex bushes installed - i'll let you know the difference
ortontom is offline
Old 8th March 2009, 21:38   #8
wxl1988
wxl1988's Avatar
Garage: 2001 BMW M5 LMB
Sales Feedback: (7)
Send a message via AIM to wxl1988
You can also go with the BMW X5 bushings. It is a good upgrade from the stock ones.
wxl1988 is offline
Old 8th March 2009, 23:31   #9
Lscman
Garage: E39
Urethane suspension bushing surely do not belong on a premium street car. They will provide absolutely no performance gains while introducing many issues relating to niose and lifecycle. If you have a $2K weekend warrior, they are a reasonable option.
A modified premium street car deserves the same sort of bushings you find on a new $100K sports car with optional track suspension and....they are all comprised of....rubber. The rubber OE thrust arm bushings are indeed short-lived, but this can be fixed by substituting the bushings from the beastly & durable X5. They are much stronger and massive overkill.
Resolve never, screw genuine.
Lscman is offline
Old 9th March 2009, 00:10   #10
TMcNasty
TMcNasty's Avatar
jfmcclung if you're going to have someone else do the work you'd be wise to strongly consider just doing the X5 thrust arms bushings as Lscman suggests. The thrust arm bushings are the real weakspot up front. The control arm ones are apparently much more durable. Lscman and I went over this (to *****) months ago in a thread I created.
I took a chance on the PF's because I wanted to DIY this repair. #1 labor cost #2 I trust myself more than anybody when it comes to working on my cars #3 was that I was perfectly willing to throw all the PFs in the trash if I didn't like the result. Are you?
If I'd decided to have the work done by someone else I would have went X5 rubber.
Bear in mind the PF's are not an "upgrade" so to speak. They are a solution to the weak OEM M5 bushings. But the X5 ones are arguably a better solution. The main advantage of PF over OEM X5 is the ability to do all the work w/o needed a makeshift press device...or removing the arms and having them pressed out/in elsewhere. The one big plus is that once you go poly they can be removed/regreased/replaced at will w/ standard tools. And if they fail they're cake to replace. So you're good until your ball joints crap out!
FWIW my M5 is not my daily driver so I was able to take my time drilling and installing.
TMcNasty is offline
Page generated in 0.13941 seconds with 10 queries
