Old 6th March 2009, 02:10   #1
Kelleyo
Kelleyo's Avatar
Garage: 2002 M5 Sterling Grey
Doing the Odd Jobb Tune up
Tomorrow replacing the Thermostat (car is runnig very cold), Oil Seperators, fuel filter. Also replacing the stock air filters and doing a MAF clean (never been done). We are going to run MAF test as well.
Since my car has been running cold it feels sluggish. I think it is because the car stays in warm up mode and keeps the mixture rich?
Anyway hopefully this will have a positive effect.
2002 ///M5 Sterling Grey - Caramel Full Leather
K40 Stealth with front/rear difusers
Angel iBright 3.0 and Xenix fogs
MKIV Nav Computer Upgrade
E60 545is Short Throw Shifter with ZHP Knob
LeatherZ Shift and Ebrake boots with M stitching
SuperSprint Xpipe
Magnaflow 14816's
Kelleyo is offline
Old 6th March 2009, 02:23   #2
2strokecoldsmoke
2strokecoldsmoke's Avatar
Garage: 2001 Carbon Black M5
There is no reason to replace oil separators unless they are cracked or otherwise damaged.
There is nothing in them.
Just flush out with brake cleaner or some other solvent, then blow out with compressed air. They will be good as new.
Car may feel sluggish because of bad MAFs. If you have more than 40k-50k miles on them, they probably need to be replaced, cleaning probably wont' do anything.
2strokecoldsmoke is offline
Old 6th March 2009, 03:51   #3
TMcNasty
TMcNasty's Avatar
Garage: '03 M5 - LMB/Blk int./Alu. trim
Careful. I heard he doesn't like anyone doing tune-ups on him.
TMcNasty is online now
The Following 5 Users Say Thank You to TMcNasty For This Useful Post:
2strokecoldsmoke (7th March 2009), Eric Giles (6th March 2009), Kelleyo (6th March 2009), Lancefitzgiben (6th March 2009), V8 empowered (6th March 2009)
Old 6th March 2009, 03:59   #4
Lancefitzgiben
Lancefitzgiben's Avatar
Garage: 2001 M5 Silverstone
Send a message via AIM to Lancefitzgiben
cleaning the MAFS will work short-term.. but they will very quickly go south again. Best to replace them with new ones.
Lancefitzgiben is offline
Old 6th March 2009, 14:59   #5
Kelleyo
Kelleyo's Avatar
Will decide after the MAF test if I need to order new ones. WIll clean them nevertheless...
SuperSprint Xpipe
Magnaflow 14816's
Kelleyo is offline
Old 7th March 2009, 00:21   #6
2strokecoldsmoke
Worth a try. You'll only be out a $6 can of MAF cleaner...
Old 7th March 2009, 15:53   #7
intrepid one
Garage: '01 M5 Carbon Black
If you are getting to the point that cleaning the MAF's gives the car a boost, they are on the way out..Its probably time to pick up a set..thay are so simple to change, and the impact on performance is so noticeable..Its smart money
intrepid one is offline
Page generated in 0.10752 seconds with 10 queries
