Old 4th March 2009, 08:08   #1
gzig5
Garage: 2000 M5 Carbon Black
CV Joint Replacement
Has anyone changed the CV joint on the front of the rear diff that is attached to the drive shaft? I think/hope I have traced my problem to this. I have the parts on order and should get them today. I'd like to hear from anyone that has done this what to look out for. The technical documentation I have is not very detailed. Do I need to pack it? I read something when I searched about sealing a joint with silicone? Any info would be appreciated. Greg
gzig5 is offline
Old 4th March 2009, 09:07   #2
rneedham1979
Banned
rneedham1979's Avatar
Garage: 2005 4.8IS, 2000 STOCK M5
I didn't replace jut the CV joint, I did the whole shaft. Yes when you reinstall it make sure it is full of high temp wheel bearing grease or CV grease. The CV joint should come with a small gasket which blows. Throw it in the garbage. Get a high quality RTV and put joint. Follow the directions and you will be good to go.
Ryan
rneedham1979 is offline
Old 4th March 2009, 15:47   #3
gzig5
Thanks Ryan. These directions you mentioned, is that the TIS or some else? I had thought it was the center bearing but that looks good and the u-joint has no play at all. In fact, driveshaft and guibo look pretty new. If the CV doesn't fix it, it is going to start to get real expensive...
gzig5 is offline
Old 4th March 2009, 18:30   #4
rneedham1979
Banned
No, its from being in there and having to get back under there to fix the CV grease leak that made a huge mess. The whole driveshaft is 400 bucks or so shipped online. It was worth it for me to buy the whole thing.
Ryan
Old 11th April 2009, 16:09   #5
HDClown
HDClown's Avatar
Garage: 2002 M5
Discovered my CV joint on the driveshaft is torn. Where did you find a driveshaft for $400 online? Is it a Genuine OEM part? Tischer sells it for $708. The CV joint assembly itself is only $135 so I was planning to only buy that assembly. Tischer also sells the center support bearing for $70 so I figured I'd replace that for good measure as well. I already have a new flex disk from a previous repair.
If I can get a Genuine OEM complete driveshaft for $400, I'd do that instead. Does the complete driveshaft including the center mount bearing?
RealOEM references "See SI 260196038" on the part for the CV joint assembly. Do you have a copy of this SI you could post/send?
2002 LMB/LMB M5 - Alcantara Headliner, Electric Shades, Folder Down Seats, M-Audio
-Britalman Exhaust, Brembo GT 355f/345r Big Brake Kit, Centric Posi-Quiet Pads, AA CAI
-UF IATS Relocation, UUC Evo3 SSK + DSSR, UUC Clutch Stop 19" Breyton Spirit Rims
-TCD Rear Sway Brackets, Euro Angel Eyes, Angel iBright v3.0, Stealth Bulbs, Stealth One
-Valentine One, Roof Spoiler, OEM Voice Control, OEM Trunk Storage Bin, 13% Solar Gard HP Tint
-http://gallery.slipoftime.com/m5
HDClown is offline
Old 11th April 2009, 16:35   #6
rneedham1979
Banned
use these guys... great parts and service!
Driveline Service - BMW Driveshafts
Old 11th April 2009, 17:26   #7
gzig5
Well my problem turned out to be the worse case scenario. The differential has broken teeth on the ring and pinion. I had replaced the CV and the problem didn't go away so I took it in to the shop. If you are interested, I'll sell you the CV I removed, which has 28k miles on it for $45 shipped. It seems to be in perfect shape and the boot is not torn.
gzig5 is offline
Old 14th April 2009, 01:02   #8
HDClown
HDClown's Avatar
Garage: 2002 M5
So it looks like these guys are just rebuilding driveshafts? They charged $400 for a complete assembly? Did you have to send yours in first to be rebuilt or did they send you one fresh and then you sent yours back as core?
How long have you had this driveshaft in your car?
HDClown is offline
Old 15th April 2009, 17:57   #9
rneedham1979
Banned
No they send you a balanced drive shaft with a new BMW CV, BMW u joints and a new BMW support bearing. When you receive the shaft you send your back to them in the box. I have had it in my car for over a year. No issues.
Ryan
Old 15th April 2009, 18:51   #10
timmay77
timmay77's Avatar
Garage: M CINCO
Sales Feedback: (5)
Ouch, sorry to hear that!! If you don't mind me asking, what were your symptoms that lead you to this?
Originally Posted by Hdhntr23 View Post
I like strippers.
__________________________________________________ ____________________
TIMMAYFEST 2010, A Nationwide M5board.com meet, in Columbus Ohio May 21,22,23, 2010
Come join a gathering of M5board members!
2001 Jet Black/Black ///M5 ("M CINCO") Current Mods:
Complete Alpine/Memphis aftermarket stereo system w/ Navi-Bluetooth-Ipod-DVD-HD Radio (Thanks Jun) ~ E60 SSK ~ Illuminated ZHP Shift Knob (Thanks Starscream) ~ Ebay Ebrake Handle ~ Euro Headlights (Thanks Raza) ~ Angel iBright V.3 ~ French Fogs ~ DRL Angel Eyes ~ Silverstar turn signals ~ Full LED interior light upgrade ~ Muffler delete with custom made Timmay77's "Signature" ///M5 - MCINCO etched staggered tips ~ OEM 18x9.5" rear wheels at all 4 corners (Thanks Surge709) with 3mm Ebay spacers on the front. ~ Stoptech slotted rotors and Centric Posi Quiet Pads (Thanks Dave at Zeckhausen Racing ) ~ Dunlop SP Sport 9000's 275/35/18 (Thanks killer diller) ~ B&G Suspension lowering springs ~ Hardwired Valentine 1 (Thanks hdhntr23)
timmay77 is offline
Page generated in 0.14044 seconds with 11 queries
