Old 26th February 2009, 05:12   #1
blueaudis4
Garage: 2000 M5 Carbon Black Metallic
Windshield help
So something kicked up from the road the other day and put a huge crack in my front windshield. I am trying to get the replacement. Anyone know the part number for the double glazed glass that is for xenon lights and also has the built in rain sensor?
"Built For Dreamers by Dreamers!"
1998 M3 TechnoViolet
2000 M5 CarbonBlack
2001 R1100SA Black/Yellow
2005 K1200S Blue/White
blueaudis4 is offline
Old 26th February 2009, 08:48   #2
jclyman
jclyman's Avatar
I would highly recommend going to a dealer. It will be more expensive, but it will be well worth it.
In 2004 there were 4 different windshields for the M5, now there is at least another one ... maybe more. It is better at reducing incoming heat. New design ... slightly green all over, instead of greener across the top. Each windshield has a different application ... one with rain sensor, one without, one with a special coating for reducing the heat, etc.
Also it is important that it be properly shimmed when installed (read about it elsewhere on here). There is a BMW specified shim kit that should be used. The reason? So you don't get wind noise. A few guys here had theirs replaced at an independent place and had wind noise afterwards.
Also, BMW says NOT to drive the car for a day afterward.
Search is your is your friend.
- Daniel Boorstin
jclyman is offline
Page generated in 0.08523 seconds with 10 queries
