Radiator Fan Exploded - Page 2 - BMW M5 Forum and M6 Forums
Old 23rd February 2009, 06:23   #11
blueaudis4
Garage: 2000 M5 Carbon Black Metallic
Sorry to hear. This happened on my brothers M3. Time to upgrade to the zionsvilleautosport super duty M5 radiator.
"Built For Dreamers by Dreamers!"
1998 M3 Techno Violet (in heaven)
1998 M3 Cosmos Black
2000 E320 4matic-wifey
2001 R1100SA Black/Yellow
2005 K1200S Blue/White
blueaudis4 is offline   Reply With Quote
Old 24th February 2009, 00:39   #12
TMcNasty
TMcNasty's Avatar
Garage: '03 M5 - LMB/Blk int./Alu. trim
Originally Posted by M5 London View Post
I think there is no chance that the fan itself can spin fast enough to be an issue if the fan clutch is operating normally.
Oh yes. Correct. But I was thinking more along the lines of the plastic fan weakening over time regardless of it being used with a properly functioning fan clutch. Let's call it "plastic fatigue."
Bottom line is once one blade cracks off the fan is so out of balance that it instantly disintegrates. I'd opt for a metal version of this fan if it were an option.
DIY - Oil Pan Thread Repair
http://www.m5board.com/vbulletin/e39...rain-plug.html
DIY - O2 sensor change
http://www.m5board.com/vbulletin/e39...or-change.html
DIY - Replace worn and 'creaking' door seals
http://www.m5board.com/vbulletin/e39...ml#post2163106
DIY - Replace OEM battery with Bosch 49-850B
http://www.m5board.com/vbulletin/e39...h-49-850b.html
TMcNasty is offline   Reply With Quote
Old 24th February 2009, 01:43   #13
M5 London
M5 London's Avatar
Garage: M5 E39 Supercharged
Right you are !!
E39 M5 - ESS Supercharger Kit, Uprated and MONSTER Remapped to 640HP, Van Manen Race Manifolds, Van Manen DeCats, Aeromotive Stealth 340 F/Pump, Bosch Green Giant Injectors, Aquamist HFS-3 with 3 Jets, MONSTER CCV setup with Cobra Pump (2PSI boost switch), Bilstein Sprint Dampers, Intrax Springs, Dinan Adjustable Rear ARB, Stoptech ST40 Big Brake Kit, EBC Yellows, 550i SSK
www.WhatAboutCars.com
M5 London is offline   Reply With Quote
Old 24th February 2009, 02:42   #14
Need4Spd
Need4Spd's Avatar
I don't think anyone makes a metal one, but the plastic replacement is around $50-65.
Need4Spd
'01 M5 (now my brother's car) UUC SSK + Rogue WSR/RE Tranny Mounts+Royal Purple Synchromax/Axxis ULT Pads/StopTech SS Lines/TC Design from BeastPower Anti-roll Bar Brackets/Dinan LtWtFlywheel and Stage 3 suspension/4xOEM rear 275 Goodyear F1 Asymmetrics/Vines thrust arms/IATS relocation/10w-60 oil/hardwired Escort 9500i/Euro Armrest/TEC Cupholder/IceLink/PowerChip 91 Gold/TUBIs!/Strong Strut/BSW Stage 1/BT/Angel iBrights 3.0/space-saver spare by Bimmerzone
'11 Jaguar XFR, Quicksilver exhaust, Escort 9500ci
Unnamed weekend Italian 2 seater with DCT
Future - F10 M5 with manual transmission?
Need4Spd is online now   Reply With Quote
Old 24th February 2009, 02:57   #15
Jboud8880
Garage: 2002 M5 Silver
Update... The total parts to be replaced... Radiator, upper radiator hoses, fan, fan clutch, water pump, belt... The fan exploding directly affected the radiator, the hoses as well as obviously the fan and fan clutch.
For what it is worth my Indy noticed a slight wobble in the water pump pulley. Not that it was the reason for the fan exploding but he did work on a 5 liter mustang in the past that repeatedly had fans explode. After about 3 or 4 fan replacements he found the source to be a bent shaft on the water pump pulley.
Anyway the cost of the replacement parts and labor is....$2,100.
I love this car... or at least thats what I tell myself. I will post again on this point.
Jboud8880 is offline   Reply With Quote
Old 24th February 2009, 02:58   #16
jrhaile
jrhaile's Avatar
Garage: 2001 M5 Road Racer
Sales Feedback: (6)
I'm removing my fanclutch/fan before the AutoX season starts next month... just still not sure on what to do for a replacement electric fan...
Hard Motorsport 2001 Road Racing M5 #362
1997 Techno Violet M3 Cone Dodger and DD
jrhaile is online now   Reply With Quote
Old 24th February 2009, 03:04   #17
jrhaile
jrhaile's Avatar
Sales Feedback: (6)
Oh and sorry this happened... could have been worse though
The Following User Says Thank You to jrhaile For This Useful Post:
Jboud8880 (24th February 2009)
Old 24th February 2009, 23:03   #18
M5CCIE
M5CCIE's Avatar
Garage: 2003 M5 Sterling Gray
Sales Feedback: (5)
Sorry to hear that. This could be a DIY job if you're up for it. Could you breakdown the costs if possible?
Thanks and good luck,
Jim
Dinan 3.45 differential
TMS Shark Injector - 91 Octane tune
IATS Relocation - Inside Air box
Strong Strut front brace
TC Design rear swaybar brackets
Bluetooth
V1
Aux port
M5CCIE is online now   Reply With Quote
Old 24th February 2009, 23:14   #19
H8Rain
H8Rain's Avatar
Garage: E39
Here is the answer to that problem.......
Zionsville Autosport E39/E38 All Alloy Radiator with Super Duty Cooling Kit from UUC Motorwerks BMW 5 / 7 Series
MINE: Garage Queen with way to many mods to list.
HERS: X5 4.4
GONE: 1985 318i
H8Rain is offline   Reply With Quote
Old 25th February 2009, 01:10   #20
jrhaile
jrhaile's Avatar
Sales Feedback: (6)
Originally Posted by H8Rain View Post
If I hadn't already spent money to replace my OEM one last summer, this *could* be the answer, but imo, WAY TOO PRICEY for my tastes. There has to be an option to just add an electric fan...
