23rd September 2012, 00:54
#343
Originally Posted by nightkrawler
you cant really tell by the look of them, though if they're orange they need to go in the trash. you need to get under the car and check where the pipes go over the crossmember. when the mounts go bad they sag and allow the exhaust to touch the brace hence transmitting vibration. the majority of the vibrations felt in these cars is transmitted through the exhaust system. also make sure the brace that goes from the trans to the exhaust is not missing. there are things you can try, ie remove the belts and run the engine to eliminate anything belt driven. what you can also try is loosen the engine, tranny, and exhaust mounts/bolts, then go from drive to reverse a few times or even take it for a short ride. then tighten everything back up starting from front to back.
I just recently picked up a vibration when cold around 2k RPMs. I thought it was a guibo. It isn't. My exhaust mount is orange and saggy. The vibration is gone once I drive it a while and it warms up. Any thoughts?
