Anyone solve the 3k Vibration? - Page 28 - BMW M5 Forum and M6 Forums
Like Tree3Likes
Old 5th November 2009, 01:54   #271
nightkrawler
nightkrawler's Avatar
Garage: 03' M5
Sales Feedback: (3)
i would assume that the stiffer the mount is the more the vibration is going to be transferred. i think a solid aluminum mount would be much worse.
Vantaam, why dont you try this... get your car on the lift again, put a pole jack etc under the tranny, remove the top nuts off the mounts then jack the tranny up off the crossmember. then see if the vibration is still there, if its gone then we know definitely that this is how it is being transferred.
nightkrawler is offline   Reply With Quote
Old 5th November 2009, 18:26   #272
koolmofo
koolmofo's Avatar
Garage: M5 Carbon Black Metallic
Hey nightkrawler, just wanted to add my experience. I recently had my clutch replaced, and since then, I have had the vibration
being discussed here. You can feel it more at higher speeds, and when it is colder outside. (just started to get chilly in the N-East) and I noticed it more this morning. I thought it was the clutch install, but perhaps it has something to do with the mounts. I haven't had a chance
to go back to my indy, but maybe the issue could be the wrong torque, or just bad mounts.
koolmofo is offline   Reply With Quote
Old 6th November 2009, 09:06   #273
vantaam5
vantaam5's Avatar
Garage: 2003 M5 matte black
Will try tomorrow,nightcrawler and keep you updated!
-rebuild in winter 2011/2012
"submarine edition",a bit boost and some M5 parts...
vantaam5 is offline   Reply With Quote
Old 7th November 2009, 23:10   #274
nightkrawler
Garage: 03' M5
Sales Feedback: (3)
well today i confirmed that the vibration is definitely being transmitted through the tranny crossmember. got the car up in the air and a jack under the transmission, then removed the crossmember. the vibration was totally 100% gone, not even a trace. i really dont understand how it is being transmitted through the rubber mounts, it dosent make any sense.
i also found out that bmw tranny mounts have a letter designation on them for how stiff they are. the factroy m5 mounts are type "N", which is pretty stiff. the lower the letter the softer the mount. ie A would be softer than B, and C would be stiffer than B. i tried a pair of e65 mounts which are type "M", made no difference. i have an old set of e36 mounts laying around which are type "K" which seem much softer than the stock ones. im going to give them a try but i doubt it is going to make any difference. im pretty stumped here, at this point idk how we're gonna fix this.
The Following User Says Thank You to nightkrawler For This Useful Post:
vantaam5 (7th November 2009)
Old 7th November 2009, 23:15   #275
vantaam5
vantaam5's Avatar
No idea yet on this
Thanks alot for confirming,nightcrawler!
Was today too busy to try it!
Old 9th November 2009, 08:22   #276
ANiMOSiTY
ANiMOSiTY's Avatar
Garage: 2001 LeMans Blue BMW E39 M5
Are the mounts maybe just a bit worn and thus softer than original spec?
Maybe a set of new N-type mounts will solve the vibrations?
ANiMOSiTY is offline   Reply With Quote
Old 9th November 2009, 12:16   #277
escarolo
Garage: M5 E39 Le Mans Blue
What are exactly the "tranny crossmembers"?
Can you show them with pictures or a scheme?
Best Regards from Spain
escarolo is offline   Reply With Quote
Old 9th November 2009, 14:17   #278
vantaam5
vantaam5's Avatar
I have brand new mounts and installed them correst and have it
Old 10th November 2009, 00:28   #279
nightkrawler
Garage: 03' M5
Sales Feedback: (3)
yes mine are new as well and make no difference. the crossmember is a brace that bolts to the body and supports the tail end of the transmission via two rubber mounts.
Old 23rd November 2009, 01:23   #280
nightkrawler
Garage: 03' M5
Sales Feedback: (3)
Vantaam5, i mine has gotten much worse over the last month. in fact ever since i lowered the exhaust to adjust the rear hangers the vibration seems twice as bad. when i first got the car i could never really feel it when i was driving, only in neutral. now i can feel it when the car is in motion as well. i also feel it now much more through the floor and the pedals. do me a favor please... lightly rest your foot on the clutch pedal and do the in neutral rpm run up test. see if you feel it in the pedals.
i think you may be correct in your theory that it is related to the headers. im wondering if one is cracked, maybe on the inside? i've noticed the following things since the vibration has gotten worse.
slight "exhaust leak" type noise from bank 1 manifold area
found fault code 140 in dme 1 time for 02 sensor control bank 1
vibration now felt more through pedals and floor, also shifter.
obc fuel consumption shows loss of 3-4mpg
vibration is much worse when the engine is fully up to temp.
what am i missing here?
