Old 11th February 2009, 19:52   #1
mswartz
mswartz's Avatar
Garage: None Yet
Whinning Noise Revelation!
Recently I have been plagued by a low to high pitched whinning noise coming from my car at a speeds between 20-60 mph. I took it to my Indie and they found that it was the center support bearing. I wanted to post this because I ahve noticed that during the winter months their have been numerous threads on this type of occurrence. Thanks and CYA
mswartz is offline
The Following User Says Thank You to mswartz For This Useful Post:
M5 London (12th February 2009)
Old 11th February 2009, 20:19   #2
chowdah
Garage: sweetness
Sales Feedback: (3)
Does your work order have a part number by chance? That might aid future searchers.
chowdah is offline
Old 11th February 2009, 23:25   #3
BMWBIZ
BMWBIZ's Avatar
Garage: 01' M5 LeMans Blue
Part number for the center support bearing is 26122228917 according to realoem.com.
I just replaced mine this past Sunday, also changed out the guibo, and CV Joint at the end of the shaft. Unfortunetly it did not solve my whinning noise problem. I got some feed back on a previous post concerning this noise.
Whining noise from drive train???
Looks like I will tackle the wheel bearings next!
Biz
BMWBIZ is offline
The Following User Says Thank You to BMWBIZ For This Useful Post:
chowdah (11th February 2009)
Old 12th February 2009, 00:19   #4
M5 London
M5 London's Avatar
Garage: M5 E39 Carbon Black/Caramel
Biz
Hi Biz,
How would you best describe your whining noise ? Is it on throttle ?
Did your centre bearing and guibo look in bad shape ?
I have a noise that sounds like a bird chirping away furiously, relative to road speed, more apparent in colder weather !
Please keep us posted.
Kumaran
My E39 M5 Headers (Manifolds)
E39 M5-ESS Supercharger VT570*-VM Race Manifolds* VM Race Cats*-VM Exhaust System* Bilstein Sprint Dampers-Intrax Springs-Dinan Adjustable Rear Anti Roll Bar*-X5 Thrust Arm Bushings-IATS Relocation Kit-VM CAI Foglights Removed-Goodridge Brake Hoses-E60 550i SSK
MB SL500-Lexus LS400-VW Golf Rallye-VW Corrado 16V-E36 M3-Stolen
M5 London is online now
Old 12th February 2009, 01:53   #5
BMWBIZ
BMWBIZ's Avatar
Hey M5 London,
My old guibo taken off the car looked pretty good actually, just a bit dried from age I guess, but no cracks or tears like others I have seen. The center bearing looked o.k. as well, a little weathered, but really could not see any stress marks or tears to the naked eye.
As for the noise I am getting, it starts off as a low constant whine, and becomes higher pitched constant whine as I speed up. The noise becomes apparent from about 45 mph on up. Below that speed, it is barely (if at all) noticable. It is not effected by weather, same noise summer and winter. Nor is the sound effected by taking exit ramps or putting the suspension under load around corners (I figured that would exclude the wheel bearings as being the culprint).
The noise comes when I am on the throttle, when the drivetrain is under load. When I let off the gas, the noise drastically reduces, almost disappears.
Biz
BMWBIZ is offline
Old 12th February 2009, 03:16   #6
Lancefitzgiben
Lancefitzgiben's Avatar
Garage: 2001 M5 Silverstone
Send a message via AIM to Lancefitzgiben
I've got a bit of a whine when off the throttle...
Lancefitzgiben is offline
Old 12th February 2009, 04:03   #7
BMWBIZ
BMWBIZ's Avatar
Yeah, most people complain about the noise when letting off the throttle. Oddly, mine does it when applying throttle.
BMWBIZ is offline
Old 12th February 2009, 04:07   #8
max95se
max95se's Avatar
Garage: '01 CB
rear diff
i've had this whining noise most especially when you are gradually pressing the throttle around 45-60 mph and up. it's my differential..
i think bms's are famous for this trait. i've taken the car to different dealers and they all said it's the diff and it's normal as it ages
and gets louder over time. i've changed the diff oil and still there.
max95se is offline
Old 12th February 2009, 04:28   #9
Fiori
Fiori's Avatar
Garage: 2001 BMW M5, Carbon Black/Silverstone
Sales Feedback: (3)
Send a message via ICQ to Fiori Send a message via Yahoo to Fiori Send a message via Skype™ to Fiori
Same thing here. Started appening after my exhaust was taken off 2 weeks ago. I believe it's some sort of exhaust leak.
'01 M5 Black/Silverstone
Supersprint complete cat-back system
Supersprint race mufflers
Hella clear euro headlights
Umnitza 6000K Predator Ice V2
Bimmian black shadow grills
545 SSK w/E46 M3 CSL suede shift knob
TEC cup holder
'04 M3 Black/Black 6sp
Fiori is offline
Old 12th February 2009, 23:47   #10
Dux
Dux's Avatar
Garage: M5 Silverstone
I too have the "bird chirping away furiously" sound.
It's rythmic and constant (not relatied to road speed and does not speed up), and only apparent in colder weather!
The noise stops when the car is warmed up.
Other than strapping the misses to the underside of the car I'm stumped!!!
Dux is offline
Page generated in 0.13744 seconds with 10 queries
