Cleaning my engine bay - BMW M5 Forum and M6 Forums
post #1 of 26 Old 22nd January 2002, 07:08 PM Thread Starter
Ashok Arora
Ashok Arora's Avatar
Question Cleaning my engine bay
Can you advise me on the right way to keep my engine clean?
I plan to use an engine cleaner spray (eg Gunk) and a jet wash. I intend to apply Armor All to the plastic bits afterwards.
Should I get it steam cleaned instead (what's the difference)?
Any precautions to take? (nobody wants a wet distributor or sqeaky belts)..
Ashok
2002 Carbonblack/Caramel
Ashok Arora is offline
post #2 of 26 Old 22nd January 2002, 07:34 PM
dwasifar
dwasifar's Avatar
Um, Ashok, where exactly in your engine bay do you see a distributor?
Seriously, I would not use solvents inside the beast's engine compartment. Get it steam-cleaned; it'll look nicer and you'll feel better about it.
dwasifar is offline
post #3 of 26 Old 22nd January 2002, 07:54 PM
Scotty
Scotty's Avatar
Agreed. I think this has been covered before on another thread, but I would also stay away from high pressure. I wash my engine every month or two, just using some dilute car wash followed by a rinse with low pressure fresh water. I use 303 protectant on the hoses and plastic bits. I wouldn't recommend ArmorAll.
Scotty is offline
post #4 of 26 Old 22nd January 2002, 07:59 PM Thread Starter
Ashok Arora
How come no Armor All - I plan to use the premoistened wipes as they don't leave the sticky residue...
post #5 of 26 Old 22nd January 2002, 10:32 PM
Scotty
Scotty's Avatar
ArmorAll contains silicone oil, which accelerates the aging of plastic and rubber.
I think it makes sense to use a product with good UV/oxidation protection and to avoid silicone oil. Otherwise, it's just a matter of personal preference (degree of sheen, fragrance, etc).
scott
Scotty is offline
post #6 of 26 Old 22nd January 2002, 10:51 PM
Bluewater M5
Bluewater M5's Avatar
I would refrain from hosing off the engine bay. I would recommend you check with a professional steamer or just hand wash the engine. There are just too many electonics in there.
Jimmy
2002 M5 Bluewater (sold)
Luxury with Bruyere trim
Supersprint X-pipe on stock exhaust
Bluewater M5 is offline
post #7 of 26 Old 23rd January 2002, 12:06 AM
greg
greg's Avatar
Mine needs it to, and I've been putting it off.
I agree that there is too much risk with high-pressure water and aggressive solvents like Gunk. They can remove lubrcation from the wrong places.
I plan to use low pressure water, a bit of car wash soap and various brushes. If I need a degreaser for some spots I will try some of the citrus-based stuff - seems to have the best reward-vs.-risk ratio.
On the other hand, the above is totally my instinct and isn't based upon too much experience OR fact. Open to other suggestions, counter-point......
greg is offline
post #8 of 26 Old 23rd January 2002, 01:07 AM
KKelly
KKelly's Avatar
Jerry Brown has cleaned all his engines for years with Simple Green and a garden hose. Stay away from stuff like Gunk. If you are concerned about electronics you can cover obvious things like fuse boxes.
The E39 has quite a bit covered compared to old BMW's and I think you would just be cleaning plastic covers for the most part. My engine needs it bad also. I would also recommend maybe removing the undertrays to get a better flow.
Steam cleaning places just blast the heck out of the engine and underneath with much more pressure than we would ever use at home.
Kevin Kelly
91 M5 Alpine White/Black
(D'Sylva Chip, Dinan springs w/Konis, camber plates
Racing Dynamics sway bars, 18" BBS RC's
345mm brakes)
'95 M3 Avus/Dove, (Conforti CAI/software, 24lb inj., GC suspension), new track rat.
KKelly is offline
post #9 of 26 Old 23rd January 2002, 01:14 AM
greg
greg's Avatar
Kevin - I've seen first hand the damage simple green can do. I once used it on some model airplane engines. I don't know what it is, but if attacks aluminum pretty badly. It's fine if you can truly get it all rinsed off, but evidently there were some places where guys had used it on airplanes that "joint" areas like where panels overlapped ended up with excessive corrosion. Since there are so many areas in our engine bay that are hard to get to, and could trap some water, I would avoid simple green.
Besides. That stuff smells SO bad!
greg is offline
post #10 of 26 Old 23rd January 2002, 03:14 AM
Aussie2U
Aussie2U's Avatar
I'd have to say watch out for water in the engine area in general. I hosed off my E420 a couple years back, and even after covering everything electrical with bags, stuffing the intake, and spraying low pressure from the hose, I still developed a miss in the engine that lasted 2 weeks!
I had blown it dry with a leaf blower until there was no moisture visible. The engine looked just great - I was proud. One turn of the key however and it just bucked, sputtered, and died. I opened every electrical compartment looking for water and then took the leaf blower again and used it for 10 more minutes everywhere I could think of. Engine now started but with severe idle problems. I then let it warm for 15 minutes at idle to make sure all moisture was gone.
For the next 2 weeks, I had a miss in the engine! Finally I got fed up and took it to the dealer. Car was under warranty, so why not, right? He called me later and said "who took a hose to the engine bay?" He said it was quite apparent because there was still water in the bottom recess areas of the spark plug canals (after 2 weeks of driving). According to him, it was grounding them out on the engine block and cleaning would not be covered under warranty.
Bottom line? I was billed for 2 hours labor due to them having to dry the plug canals without removing the spark plugs, which is evidentally hard to do on that engine. He also said he sees way too many cases of blown ABS controllers by water damage, and that I was "lucky".
So now I have a 45,000 mile ML430 with an engine bay that looks like it's gone through the Australian Outback, but I'm not touching this one with water until I hear some miracle way to clean it.
Aussie2U is offline
Nowack Tuning Report, The Truth (Long Version) CharlesW E39 M5 and E52 Z8 Discussion 90 2nd September 2011 09:49 AM
Nowack Tuning Report, The Truth (Long Version) CharlesW Most Memorable Threads' 44 30th November 2002 04:49 AM
SL 55 vs Z8 at the Nurburgring! mmunson E39 M5 and E52 Z8 Discussion 64 21st April 2002 01:42 AM
Alpina 3.0 csi JetBoy ALPINABoard.com | BMW Alpina Discussion 53 13th October 2001 11:09 AM
Steam clean the engine bay? ALX E39 M5 and E52 Z8 Discussion 15 7th September 2001 10:46 PM
