Old 8th January 2009, 23:59   #1
DouglasABaker
DouglasABaker's Avatar
Garage: 2002 Chiaretto Red M5
Brake Hardware Kit - Source?
Every vehicle I've ever worked on has had a brake hardware kit available that includes caliper slides, etc. I've checked all my online sources and they don't carry one. Nor does Zeckhausen (although I admittedly haven't called yet).
Since I apparently have a pair of sticking calipers (the inside pads on my fronts are pretty much gone, outsides are new) I'm guessing the last guy didn't use new caliper slides...
Anyway, does anyone have a source, or do you all just order the individual parts based on what you see in RealOEM?
And yes, it is that PM time of year - brake pads, t-stat, coolant flush, brake fluid flush, fuel filter, belts....
d-
DouglasABaker is offline
Old 9th January 2009, 00:24   #2
kindanutz
kindanutz's Avatar
Garage: 03 M5 Jet black
i wouldn't use new slides... i would take the old ones scotch brite them... get off all the built up road grim and old grease... then use a polishing wheel and put a nice smooth finish on them... problem solved...
kindanutz is offline
Old 9th January 2009, 00:33   #3
razahyde
razahyde's Avatar
Garage: 00 Carbon m5
Sales Feedback: (29)
Send a message via AIM to razahyde Send a message via MSN to razahyde
you can get stoptech parts seperate from dave. if youll give him a call he can help you out.
if you are referring to oem parts then i have no clue.
razahyde is online now
Old 9th January 2009, 00:44   #4
mottati
mottati's Avatar
Garage: '91 M5 AlpineWhite II
i've never replaced them either, just cleaned and greased.
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Old 9th January 2009, 01:04   #5
TMcNasty
TMcNasty's Avatar
Garage: '03 M5 - LMB/Blk int./Alu. trim
x2. Never done BMW or M5 brakes myself, but the only time I've replaced hardware is on drum brakes. Well...actually on calipers I've needed to replace OEM metal brake pad "novibrate" shims that had rusted, but that's all.
On calipers the guide pins just need to be cleaned and relubed w/ non-washaway brake lube. If they aren't fused to the caliper your uneven pad wear most likely points to internal caliper issues. And if they are fused...ouch.
Members:
If you want your oil pan repaired (see http://www.m5board.com/vbulletin/e39...rain-plug.html) instead of buying a new one or attempting the repair yourself PM me and we'll work something out. Thinking $60 profit is worth it. You pay all shipping of course. At the moment I have four remaining Timesert inserts looking for homes. If the demand is there I'll keep doing them. If not the tool goes on eBay minus one insert.
TMcNasty is offline
Old 9th January 2009, 01:39   #6
rneedham1979
Banned
rneedham1979's Avatar
Garage: 2005 4.8IS, 2000 STOCK M5
I have replaced them. The dealer has them and it didn't make any difference on my car. I though I may have had a hanging caliper as well but it wasn't....
Ryan
rneedham1979 is offline
Old 9th January 2009, 02:07   #7
DouglasABaker
ok, I'll just clean them, but if I get a sticky caliper again it will be the last time I help any of you Oh wait, you've been helping me lately. Nevermind!
I've always replaced them just because they are cheap. And yes, TMcNasti-name, the hardware kit is typically associated with drums, but on discs you are supposed to replace the slides (without lube, so they don't get gunked up) otherwise you get a sticking caliper. I'm really surprised both of mine are stuck.
The best part is that I broke the passenger one free last night and now I have a nasty shimmy. I don't have much pad left on the inside, so no bedding until I get new pads...
d-
Old 9th January 2009, 02:17   #8
DZeckhausen
DZeckhausen's Avatar
Garage: 2001 540i 6-Speed, Alpine White
Send a message via AIM to DZeckhausen
Uh oh! I hope you didn't grease the caliper slide pins ("guide screws" in BMW lingo) on any factory BMW brakes. The slide pins are specifically NOT supposed to be greased, since that will cause the rubber bushings in the calipers to swell, causing the caliper to stick. This results in rapid outboard pad wear. See:
BMW calipers are DIFFERENT than calipers found on many other cars, where the slide pins are located inside a steel tube, covered with thick "slide pin grease" and protected with rubber boots. Those slide pins look like this:
Dave Zeckhausen
Owner, Zeckhausen Racing
2001 540i 6-Speed
M5 Front Swaybar
Dinan Stage 3 Suspension
Dinan Front Strut Tower Brace
European Dash Conversion
CDV Deleted (of course!)
Bluetooth, NAV-TV, DVD Player
2006 Chrysler 300C SRT8 w/StopTech ST-60 front/ST-40 rear BBK
2007 Corvette Z51 Coupe 6-Speed w/StopTech Trophy ST-60 front/ST-40 rear
2009 Honda Fit Sport w/NAV w/Acura Integra front calipers, StopTech floating rotors on order
DZeckhausen is offline
Old 9th January 2009, 05:01   #9
TMcNasty
TMcNasty's Avatar
Originally Posted by DZeckhausen View Post
Ah good to know. I just AZZ-U-MEd that all calipers ran with the sealed/lubed guide pin technology pictured. Figures BMW does it differently. Good way to increase caliper sales I guess. I'm quite surprised they'd go with something different then what's in the above pic. The pic above technology works perfectly. No wonder Doug is having problems! Do BMW exposed/unlubed pins get jammed up regularly? I'd imagine they would, but please tell me if I'm wrong.
Members:
TMcNasty is offline
Old 9th January 2009, 07:00   #10
E55AMG2
E55AMG2's Avatar
Mine are always squeaky clean...but then again I clean them each time I change pads for the track and back to street.
E55AMG2 is offline
Page generated in 0.14695 seconds with 10 queries
