Old 8th January 2009, 22:16   #1
huesey1974
Garage: M5 grey
PDC sensor
Hi,
My park distance control has stopped working and after listrening for the pulse on each sensor found that one one the rear, the inside and not the outside is not pulsing.However i cant seem to find a way to get to it and remove it.The outer ones are easy as you just pop off the plastic strip.Any ideas would be well appreciated.
cheers
huesey1974 is offline
Old 8th January 2009, 22:32   #2
andy777
andy777's Avatar
Garage: bmw e39 m5 midnight blue (carbon shwarts)
Open the the boot and the 2 inner doors and you will see 3 gold bolts on each side, remove them and then remove the 3 plastic clips in the rear wheel arches. Slide the bumper off being sure to disconnect the cable from the pdc control unit in the right hand side boot compartment first.
You could always get an air dusted and some foam or electrical cleaner and try to clean the sensors first before you remove the bumper.
I'll see you, if you catch me
andy777 is offline
Old 8th January 2009, 23:25   #3
huesey1974
Garage: M5 grey
will do thanks very much
Old 11th January 2009, 02:10   #4
doc$holliday
doc$holliday's Avatar
Garage: 2003 M5 Le Mans Blue
PDC sensor problem, but they all seem to be working...
thought I had the same issue as the OP and others on previous threads - turning on PDC results in the immediate solid tone and the blinking PDC light. Per previous threads, everyone said to get out and listen to each sensor and find the one that is NOT clicking.
My problem is this: all of them are clicking!! I went around the car twice and am certain that putting my ear to each in turn revealed that they are all clicking.
So...where do I go from here?? Any advice is appreciated!!
thanks guys
SP
Sean Paul
2003 M5 LeMans Blue/2-tone blue & black
doc$holliday is offline
Page generated in 0.08928 seconds with 10 queries
