Old 8th January 2009, 13:48   #1
Chemical1
Chemical1's Avatar
Garage: 2000 M5 Carbon Black / Caramel
VANOS solenoid - problem?
Hi!
I have a peake 71 code that translates to "Intake camshaft VANOS position control, Cyl #5-8". Also, when cold-starting the engine there is a noticeable difference in exhaust note - it sounds as there is exhaust leak. Once the car has a good operating temperature the noise i gone!!
I have read elsewhere that a change in exhaust note can be related to bad exhaust CPS. However, I have no code related to any of the CPS sensors.
- Does anyone know if the real problem actually is bad solenoid or something else?
Chemical1 is offline
Old 8th January 2009, 14:35   #2
M5 London
M5 London's Avatar
Garage: M5 E39 Carbon Black/Caramel
Originally Posted by Chemical1 View Post
Hi!
Hey,
It could end up being a BANK 2 Vanos Solenoid issue !
But most of the time a CPS on the same bank could be going faulty and giving you those codes, I think.
Did you clear the code and drive around and then it reappeared ?
Have you done a GT1 Vanos test ? Good idea to do one !
Most people say exhaust tone change would point towards exhaust CPS ! But your error suggest intake ?
Whats your mileage ? If its more than 110,000 KM then I personally would change intake and exhaust cps on Bank 2 as they are going to fail at some point in anycase I reckon
Kumaran
My E39 M5 Headers (Manifolds)
E39 M5-ESS Supercharger VT570*-VM Race Manifolds* VM Race Cats*-VM Exhaust System* Bilstein Sprint Dampers-Intrax Springs-Dinan Adjustable Rear Anti Roll Bar*-X5 Thrust Arm Bushings-IATS Relocation Kit-VM CAI Foglights Removed-Goodridge Brake Hoses-E60 550i SSK
MB SL500-Lexus LS400-VW Golf Rallye-VW Corrado 16V-E36 M3-Stolen
M5 London is offline
Old 8th January 2009, 19:58   #3
andy777
andy777's Avatar
Garage: bmw e39 m5 midnight blue (carbon shwarts)
If your soleniod has gone bad you will get rough idling after warm-up and you will be down on power due to misfires, also the exhaust note will not be that noticable. You might get louder than usual vanos clatter from the bank with the problem.
I'll see you, if you catch me
andy777 is offline
Old 9th January 2009, 12:29   #4
Chemical1
Chemical1's Avatar
Thanks for the feedback!
The car has well over 200.000km and the code (peake #71) reffered to above is a reaccuring one. Not 100% consistent reaccuring but nonetheless in my view an indication that the solenoid might be faulty.
I have read several threads where this code has been interpreted as a CPS issue where it actually is a solenoid issue. The peake table indicates the codes for the CPS are:
07 and 08 = intake camshaft positioning sensors
0A and 0B = exhaust camshaft positioning sensors
Has anyone had similar experiences?
Old 9th January 2009, 13:53   #5
everycredit
everycredit's Avatar
Garage: 2000 E39 M5 Carbon Black
Vanos solenoid issue is tricky to diagnose. When the solenoid goes bad, you will get random misfires, vanos and timing faults. You may also get CPS faults, catalytic converter faults, among many others.
The cheapest way to confirm vanos solenoid is to clear codes, start engine, wait for SES light to engage, read codes, and determine fault bank. Then remove the vanos solenoids and swap banks. Clear codes and redo. If the error jumps to the other bank, go ahead and order yourself a new solenoid, making certain it's the correct one (there are two versions--if you have the old one, it might be prudent to retrofit the new version, which will cost about $100 USD more).
everycredit is offline
Page generated in 0.11884 seconds with 10 queries
