Old 7th January 2009, 19:48   #1
shamus_mcd
shamus_mcd's Avatar
Garage: E39 M5 in Titanium Silver
Battery problems
Looking for a bit of info.
The other day my car wouldn't start as the battery was flat (No dash lights or anything)
I charged the battery for a day'ish and basically car would just click when key turned.
I Bump started it and took it for a 50 mile drive stops and starts no problem so I left it over night on trickle charge.
The car has sat for 3 days and battery flat as a pancake again
What I've found is if I disconnect the battery completly the battery is showing fully charged but when connected the battery is showing 3 of the 4 light need to go out for a charge.
I think this is a pumped battery
Would I be correct in this?
Anyway to check?
The car is charging now but seem to only get as far as 2 light out and 2 to go.
I've checked and no lights on in boot or car radio off sat nav off as screen goes blank and i'm a bit stumped.
I think the car has had a battery before in it's history before me.
If I do need a battery what kind etc etc
I think it's a 100ma 720Ah is whats in it just now.
Car has been fine up until the other day.
Left it in Sept for week and a half and burst into life on my return.
HELP
Life is not Measured in the amount of breaths you take,
BUT in the amount of times it takes your breath way....
///M5
I'm off to the ASTHMA CLINIC now!!!!!!
shamus_mcd is offline
Old 7th January 2009, 19:54   #2
manminder
manminder's Avatar
Garage: 2000 m5 lemans blue
That is a classic sign of a battery not holding its charge. You need to replace it.
manminder is offline
Old 7th January 2009, 21:06   #3
TMcNasty
TMcNasty's Avatar
Garage: '03 M5 - LMB/Blk int./Alu. trim
If a battery cannot be charged it is defective. End of discussion. Being that you're in Scotland I'm not sure how you can get another one besides a dealership.
Members:
If you want your oil pan repaired (see http://www.m5board.com/vbulletin/e39...rain-plug.html) instead of buying a new one or attempting the repair yourself PM me and we'll work something out. Thinking $60 profit is worth it. You pay all shipping of course. At the moment I have four remaining Timesert inserts looking for homes. If the demand is there I'll keep doing them. If not the tool goes on eBay minus one insert.
TMcNasty is offline
Old 7th January 2009, 21:19   #4
Redneck M5
Garage: 2002 M5 Imola Red
If you have a voltmeter you can read the state of charge for the battery. 12.6V is a fully charged battery. If you can't charge to 12.6v, replace it.
When running the alternator should produce well above 13 volts.
You may have a bad battery. You may have additional issues, but there needs to be a good battery to find out.
Redneck M5 is offline
Old 7th January 2009, 21:37   #5
jonsmiff
jonsmiff's Avatar
Garage: e39 m5 silverstone blue
youre battery sounds like its gubbed, and also it should be an 800 or 850 ah battery,you need to check youre charging system just to make sure its up to scratch,i changed my battery a couple of weeks ago to one of these http://www.performancebatteries.co.u...s#battery_info 70 quid delivered next day for a 100 cca 900 ah with a 3 year warranty,or halfords do one that is slightly less powerful for 100 quid(with the halfords trade card this comes down to 75.00)if you are anywhere near the west end of glasgow i am quite happy to test it for you.
jonsmiff is offline
The Following User Says Thank You to jonsmiff For This Useful Post:
shamus_mcd (7th January 2009)
Old 7th January 2009, 22:14   #6
jclyman
jclyman's Avatar
A disconnected battery will give FALSE voltage readings. It must be checked using the appropriate load.
- Daniel Boorstin
jclyman is offline
Old 7th January 2009, 22:15   #7
zanta
zanta's Avatar
Garage: E39 M5 '02, Le Mans Blue
i've had similar problems today..
Actually my car has been in cold garage since beginning of November.
So I forgot to put battery to charging when i put car in garage....
It an out of charge... and I wondered why it's not charging...
So I thought I'll take the battery to battery shop for test...
i took it from the trunk... shait... It had frozen an totally broken...
lasted totally 8 years it was the original one. durable battery.
last winter no problems from -35c starts
battery even had sticker where was text tellin it should be changed 1-2005
take it out from the trunk, see if it's ok.
just buy new one, i looked that replacement batteries are here from 100€->
BMW M5 '02
'79-'05, '06- , '05-'06 , '06
zanta is offline
Old 7th January 2009, 22:39   #8
maxrpm
maxrpm's Avatar
Garage: m5 e39 blue
Yeah so take your horse and kart and go get one lol
maxrpm is offline
Old 7th January 2009, 22:56   #9
shamus_mcd
shamus_mcd's Avatar
Originally Posted by jonsmiff View Post
youre battery sounds like its gubbed, and also it should be an 800 or 850 ah battery,you need to check youre charging system just to make sure its up to scratch,i changed my battery a couple of weeks ago to one of these Car Batteries, Cheap Car Batteries, Replacement Car Batteries, Next Day Delivery from Perfomancebatteries.co.uk 70 quid delivered next day for a 100 cca 900 ah with a 3 year warranty,or halfords do one that is slightly less powerful for 100 quid(with the halfords trade card this comes down to 75.00)if you are anywhere near the west end of glasgow i am quite happy to test it for you.
Is this the one?
Where are you?
I stay in Law near Carluke but i'm off to Thurso tomorrow back Friday night.
  • 4 Year Warranty
  • 30% More Starting Power
  • 100% Maintenance Free
  • Lead Calcium Technology
  • Built in Charge Indicator
Order now
Cost Qty
£ 70.95
019 Battery
Power Cold cranking
100 900
Terminal Type
Fitting info
Length x Width x Height 354mm x 175mm x 190mm Weight26 kg
Terminal Layout
///M5
Old 7th January 2009, 23:07   #10
shamus_mcd
shamus_mcd's Avatar
At least the horse will get there .
So tempting to jump start but so many horror stories with the nav etc.
I wonder what a Positive feed back will be when I get charged for the new battery.
It's late!
Thanks for all the help guys I will go with Jonsmiff and go for the buy
No Battery no vroom no funny
///M5
Page generated in 0.15578 seconds with 10 queries
