Old 7th January 2009, 08:55   #1
SCM5
Garage: Sterling M5
SES Problem, Fuel Ventilation Fault?
Heya, first post here and it happens to be about an SES light.
Recently purchased my new 2003 M5 with 56k miles on it for a reasonably good price.
Car is driving fine. I was on the way back home today when my SES light comes on, so i proceed to the local BMW specialist shop. It was late, so he runs the car through the computer and comes up with a Fuel Ventilation Fault. Says it's probably a fuel vapor leak and would look at it tomorrow if i took it in.
I noticed in my email that my account was validated for posting so I decided to post my situation up to see if i could get any answers before i go to sleep.
So, has anyone had this problem before and how big of an issue is it?
Thanks in advance!
Stephen
SCM5 is offline
Old 8th January 2009, 02:56   #2
chowdah
Garage: sweetness
Sales Feedback: (3)
This might be as simple as a gas cap not being tight or sealing well. You may want to reset the code (#1 purchase for all new owners should be a Peake reader) and see if it returns.
chowdah is online now
Old 8th January 2009, 04:11   #3
jclyman
jclyman's Avatar
Reset and Scan Tools for BMW Check-Engine, SRS, Oilservice Inspection
- Daniel Boorstin
jclyman is offline
Old 8th January 2009, 04:18   #4
gsfent
gsfent's Avatar
Garage: 01 M5 Black/caramel
Thanks in advance!
Stephen
Could be the fuel breather/ventilation valve, which is buried under the intake plenum. It will not affect the running of the car. I believe there is a writeup here with pictures on how to swap it out. Not a big deal.
gsfent is offline
Old 8th January 2009, 09:30   #5
SCM5
Garage: Sterling M5
Update: took it to the shop today, they could find absolutely nothing wrong with it and just reset it for me. Hope that's the end of that.
BTW, anyone go to EMW in Arcadia? Great shop, John is a great guy... so glad I found that place since I bought my M5.
SCM5 is offline
Old 9th January 2009, 15:26   #6
AfricaOffroad
AfricaOffroad's Avatar
Garage: 1991 E34 M5
There is an activated carbon filled vent tank attached to the main fuel tank.
Suggest you replace this unit (I paid the equivalent of $80 for a new one).
On my 1998 540i, this unit blocked, causing the fuel tank to build up negative pressure. This tank distortion damaged the fuel pump, causing the car to stop in the middle of no where. Ended up having to replace the fuel pump.
AC vent tank was one of the first items I replaced on my current E39, this also at 50 000miles
1991 E34 //M5
2003 E55 AMG
2009 KTM 950 Super Enduro
2009 KTM 300 XCW
AfricaOffroad is offline
Old 7th May 2009, 16:21   #7
morals
morals's Avatar
Garage: '01 CB/Caramel M5
Happened to me yesterday. I took it by AutoZone and the guy read the code and suggested it could be that. It was.
I felt like a dumbass, but a dumbass that wasn't about to have to spend thousands repairing his beast.
morals is offline
Old 7th May 2009, 16:45   #8
100%Cocoa
100%Cocoa's Avatar
Garage: E39 M5 Carbon Black/Caramel
All posts on the board suggest it will not effect the running of the car and it is just an irritating light. For that reason I left mine for 4 years as in the UK it only throws a code and does not set off the SES light. I had it done recently though, and it cured a number of random fuelling codes that we'd never got to the bottom of, and made the idle smoother, and made her behave better in traffic. The only conclusion my indie and I could come to was that the failing valve had introduced a small vacuum leak and was letting unmetered air into the engine. I lived with it for 4 years and am kicking myself now.
It functions by venting fuel vapour from the tank into the inlet manifold to allow it to be burned off while the engine is at idle, rather than escaping neat into the atmosphere. This is simply to comply with emissions legislation. The DME opens the valve at idle to allow the vapour to burn, and closes it as you accelerate. I guess it depends whether it fails open or closed as to whether you notice it or not.
Just my tuppence worth, but if it turns out not to be the filler cap then I would always recommend doing it asap now.
As for DIY, after watching my indie's assistant doing it, and seeing how much pain and skin loss was involved, I would recommend paying the half hour labour charge!
100%Cocoa is offline
Page generated in 0.14403 seconds with 10 queries
