^^ Given the shape of the Alpine mic, I didn't see how I could mount it in the factory location. It is a bullet shaped microphone with a flat mount plate. (I'll take some pics in the morning)There really isn't anything I can mount it to up inside that pocket that houses the factory mic. I pulled it all apart and took a look at it. I planned on getting everything set up, and trying it in a few places to see where I can get a good sound from. There is a small metal shelf that I set the GPS antenna on. I put double sided tape on the bottom and kind of jammed it into it's new home. It is trapped between the dash and that metal plate.
Drill a hole and glue the mic into place? Also, how did you account for retaining the BC functions?
Tim, thanks for your help still have alot of clean up with the wires, I also have sound but no radio signal do I need an adapter? if you figure out how to get radio signal can you please post how to get signal
Congrats, Tim! I know exactly how you feel. I heard music through my (not yet fully complete) install today. I still have miles to go before I sleep--I need to fashion a custom bracket for the DQXS, run wires to the center console for the DDC and the iPod SpecDoc, and (so I discovered) learn how to make the gazillions of adjustments to the crossovers, amp gains, input and output levels to make the music beautiful. But just hearing the tweeters and woofers work as they should and knowing the RCA's are all hooked up right, and the remote leads are working, etc. all was immensely satisfying. I can only imagine how you must feel, given how extensive your install is. CONGRATS!
__________________ The Beast
2001 E39 M5 LeMans Blue with Black/Blue Sport Interior and Titanium Trim, ESS Supercharger, RMS In-Plenum Intercooler, RMS Plenum Plates and Custom-Bored 52mm Diameter "Shorty" Velocity Stacks, Dinan TBs and Headers, CNS Catback Exhaust, Evosport High-Flow Cats, Stoptech Trophy Sport Brakes (6-Pot Front/4-Pot Rear; 355 mm Rotors All Around), Dinan 3.45 Differential, Dinan LTW Flywheel, GC Coilovers (550 7" Front/325 10" Rear), Dinan Front and Rear Swaybars, Dinan Monoballs, Dinan Rear Wheels (18 x 9.5) All Around With 10mm Spacers and 90mm Wheel Studs, Michelin PS2s 275 35 18s All Around, UUC EVO3 SSK with DSSR, Voltphreaks VPR-S40P Endurance Battery (14 lbs.), Setrab 16-Row Oil Cooler, Dinan Under-Plenum Heat Exchanger Removal Kit, Vorsteiner Double-Sided CF Hood with Open Vents, CA CSL-Style CF Trunk Lid, Zionsville Super Duty Cooling System, Aquamist HFS-6 Meth Injection with Custom CF/Aluminum Trunk-Mounted Fuel Cell Designed by Howerton Engineering, XRP HS-79 Hosing, OKD Plasma Ignition Coils and Plug Boots, Smoked Hella Tailights, Clear-Corner Hella Euro Headlights, CA ACS-Style CF Front Splitters, Custom Stereo Using Stock HU, PLX Digital Gauges, V1/S1 Mounted in UGDO Location, Recaro Sportster CS Seats, Schroth 4-Pt Street Harnesses, Dinan Foglight Delete Kit, and Various Other Bits and Pieces
Coming Soon!
Hankook R-S3 285 35 18s All Around, EAS Competition Steering Wheel, TC Designs Roll Bar, Leather Eurodash, Full Leather Doorcards, TC Designs Rear Sway Bar Brackets, Rogue Stage 3 280mm Clutch with JB Racing LTW Flywheel, Dinan Differential Subframe Reinforcement, Stoptech Carbon Ceramic Rotors, Quad Head Laser Interceptor, Kenne Bell Boost-A-Pump
When the Motor Blows
Balanced and Blueprinted S62
Tim,
Did you run your rca's wires on the drivers side of car and the alpine deck wires on the right side of the car.
With my system, I did not have to run RCA's to the rear, just an AI net cable. My Alpine Imprint module is in the trunk, the AI net goes to it, and the RCA cables come from the Imprint module to the amps. I ran all of my wiring down the driver's side. The power from the battery in the trunk to the engine runs on the passenger side. You want to aviod getting near that to protect your sound from noise.
Thanks Peter! I played with it a little more this morning. I have a few kinks to work out, but am very happy with how it is going. Once I get the subs done and the Imprint module set up, I will do some of the final touches. I have a few little tricks I like to do to my systems to make them look a bit more stylish.
