Brake disc advice - BMW M5 Forum and M6 Forums
Old 31st December 2008, 00:24   #1
JB_UK
Garage: 'OO M5 - Silverstone
Brake disc advice
Just took my car in for a clutch and got a call to say that my brake discs and pads were in bad condition and needed replacing. I agreed on the advice of the technician who estimated that they only had approx 200 miles left in them. As this was about a weeks motoring for me I decided to have them done at the same time as the clutch at a cost of £640. Wanting to see the state of the discs I asked the dealer to put them in the boot so I could have a look for my self. Them agreeing to this gave me some confidence that the discs must be in a bad state.
On a quick inspection when i got home my own thoughts are that the discs look not too bad. Even wear across the surfaces(front and back), no discolouration, cracking etc and with only approx a 3mm rim.
On this basis does anyone know the minimum thickness for discs. I don't want to create an issue until I have some good information to work from. Any help would be most appreciated.
Regards
John.
JB_UK
'00 Silverstone
'99 323SE
'94 MX6
JB_UK is offline   Reply With Quote
Old 31st December 2008, 00:38   #2
Stika
Stika's Avatar
Garage: E39 M5/Jet Black on Black
Min. thickness should be stamped on the rotor (if they're the stock ones).
...i wanna go fast...
Stika is offline   Reply With Quote
The Following User Says Thank You to Stika For This Useful Post:
JB_UK (31st December 2008)
Old 31st December 2008, 14:05   #3
DouglasABaker
DouglasABaker's Avatar
Garage: 2002 Chiaretto Red M5
And you only get about 3 mm of wear before they need to be replaced...
d-
DouglasABaker is offline   Reply With Quote
Old 31st December 2008, 19:37   #4
mikeoski
mikeoski's Avatar
Garage: 2000 Avus Blue M5
Dr Z will solve your Brake problem
Look now further than here: BMW E39 M5 Products - StopTech big brake kits, stainless lines, short shifters, pads, tires
Centric Slotted and one of the Axxis low dust is your best bet for the street.
mikeoski is offline   Reply With Quote
Old 1st January 2009, 07:17   #5
DZeckhausen
DZeckhausen's Avatar
Garage: 2012 328i 8-Speed, Mineral Grey Metallic
Actually, you only get 1.6mm of total wear before they are done. In front, the rotors started out at 32mm thick when new and the minimum allowable thickness is 30.4mm. In back, the rotors started at 20mm thick and the minimum thickness is 18.4mm.
Dave Zeckhausen
Owner, Zeckhausen Racing
2001 540i 6-Speed (Sold)
M5 Front Swaybar
Dinan Stage 3 Suspension
Dinan Front Strut Tower Brace
European Dash Conversion
CDV Deleted (of course!)
Bluetooth, NAV-TV, DVD Player
2006 Chrysler 300C SRT8 w/StopTech ST-60 front/ST-40 rear BBK
2007 Corvette Z51 Coupe 6-Speed w/StopTech Trophy ST-60 front/ST-40 rear
2009 Honda Fit Sport w/NAV w/Acura Integra front calipers, StopTech floating rotors on order
2012 BMW 328i Luxury Line, 8-Speed
DZeckhausen is offline   Reply With Quote
The Following 3 Users Say Thank You to DZeckhausen For This Useful Post:
CSBM5 (1st January 2009), JB_UK (2nd January 2009), jclyman (1st January 2009)
