Old 19th January 2002, 04:35   #11
tfung
tfung's Avatar
sounds like they just made up some explaination for you... they probably couldn't figure out what was wrong with it, and just took you for a fool and gave you whatever they could think up.. at least the warranty covered it....
US Spec 2001 E39 M5 - LHD
AC Schnitzer
Dinan
3.45 differential
Others
Euro Spec 1999 E39 M5 - RHD
2007 Mercedes E63
2007 Corvette Z06
2008 Nissan GTR
tfung is offline
Old 19th January 2002, 05:15   #12
Dallas Spikes
Dallas Spikes's Avatar
Garage: 2002 Carbon Black M5
Parker,
Don't worry, I don't use Classic (I use Moritz.), but it sounded like the excuse I heard from them (Moritz) when I wore out my rear tires of my 540 at 6K miles!! Initially, they told me it was the massive torque of the car and my aggressive driving!!!! This was on a car that I had never spun the tires nor turned the DSC off!! I was a pretty darn conservative driver in that car looking back on it. Finally, they found a rear camber problem which was fixed under warranty, but refused to pay for the new tires!! Funny, how I learned to drive the car more aggressively, but the 2nd set of tires lasted 20K miles!! (They really had a lot of tread left, but I was replacing the fronts, so I went ahead and did the rears.
Oh, those BMW excuses!!
Chris
Dallas Spikes is offline
Old 19th January 2002, 06:45   #13
rvacha
rvacha's Avatar
Garage: '08 E92 Jerez M3
BMWis fixing this because it is their problem. I highly doubt that the driveshaft itself is damaged. Have they ever mentioned a part called a guibo by chance?
'03 E53 X5 4.4i Topaz/Sand
'06 E90 330Xi 6MT Sparkling Graphite/Terra
'08 E92 M3 6MT Jerez/Speed Cloth/Carbon Leather <-- Evil Twin
rvacha is offline
Old 19th January 2002, 06:56   #14
beanboy
Garage: 00 M5 Silver
The guibo was completely destroyed as well. It was also replaced.
The entire driveshaft WAS replaced. I am very positive of this. They showed me the car while it was up on the lift. I saw the damage.
Parker
beanboy is offline
Old 19th January 2002, 06:59   #15
rvacha
rvacha's Avatar
WOW!!!!
rvacha is offline
Old 19th January 2002, 08:08   #16
greg
greg's Avatar
Garage: 2000 Anthracite
I'll just second the notion that this was the lamest, most cockamamie excuse I've ever heard. I will grant you that BMW's perform well in part because they ARE well engineered, which means components are "big enough" but not "too big". However, to claim that the design of a drive shaft is so finely tuned as to be sensitive to brand of tire? Give me a break. It just ain't so. As in NFW! Your dealer should be hog-tied, keel-hauled, roasted alive and lambasted for trying to pull thw wool over your eyes. Shame on them.
greg is offline
Old 19th January 2002, 08:53   #17
DrRob
DrRob's Avatar
Garage: '02 Z8
Absolutely rediculous!
What happened to BMW's excuse that the clutch is manufactured to be the 'weak link" in the drive train to protect the other components??? I recall this excuse being used previously to explain clutch failure.
Next they'll say the drive shaft is the weak link to protect the clutch.
Interestingly, however, when I ordered a Ford F250 with the 460 efi engine (first year efi was introduced in that engine), production was delayed because the drive shaft had to be reinforced. The efi engine had so much more torque than the carburetor version of the 460 that the drive shafts twisted.
DrRob
'02 Z8
DrRob is offline
Old 19th January 2002, 09:02   #18
JEM
JEM's Avatar
Garage: Silverstone MY2000 E39 M5
On one hand, yes, it's a stupid explanation.
However...
The M5 is not a dragstrip weapon. It's far too heavy. And weight is hard on parts.
If you go out trying to match those sub-5-second 0-60 times regularly, you should count on some occasional parts breakage.
JEM is offline
Old 19th January 2002, 09:05   #19
DarkStar
DarkStar's Avatar
Garage: 2003 E55
You should write a letter to BMW....we shouldn't have to put up with nonsense like this. You're dealers statement is false, so are the stupid comments about the cupholders!
good luck,
-Alex
DarkStar is offline
Old 19th January 2002, 09:38   #20
TiGumz
TiGumz's Avatar
Garage: 2001 M5 Anthracite
Re: Killed my driveshaft
Originally posted by beanboy
They said the reason that the driveshaft broke was because of my tires. ....
What a load of crap! If that were the case, ask them to show you in the owner's manual for a warning against using other than OEM tires. After all, given the potential for significant drivetrain damage, I'm sure it would be listed, just like the specifications for engine oil.......Sheesh.....
Glenn
08 M5 Interlagos
Dinan Exhaust
01 M5 Anthracite
UUC short shift
Dinan 3.45 Diff
07 Exige S
TiGumz is offline
VERY VERY bad news on my car...broken driveshaft, etc beanboy E39 M5 and E52 Z8 Discussion 16 12th December 2003 05:25
Rebuildng driveshaft? 535iE34 E34 M5 Discussion 0 28th March 2002 23:14
ACCIDENT with 125 cars today!!! (10 killed in TN) Angel E39 M5 and E52 Z8 Discussion 1 14th March 2002 23:54
Page generated in 0.15645 seconds with 11 queries
