Old 18th January 2002, 23:02   #1
fredcourtot
Garage: BMW M5 Titanium Silver
Send a message via AIM to fredcourtot
Angry Check Engine: X-Pipes with DINAN Software !
Guys,
I know a lot of people today have the X-pipes with either stock,Dinan, SS, B&B, Kelleners, etc..
My question is, do any of you have the X-pipes with the Dinan Software? Reason being is that I do and am constantly getting " Check Engine Soon" Dinan told me that it is because of the X-pipes. When they did the software, it was to run with stock pipes. So that is why I am getting fuel mixtures/flow issues. They want me to put the stocks back on and then correct the software so it functions properly with the new hardware (X-pipes).
I think I just might remove the Dinan Sofware completely. I know they will charge me for reprogramming the software to work for the X-pipes.
Any comments/suggestions is appreciated.
Thanks,
Fred
07 Porsche 997 TT
07 Porsche 997 GT3rs
06 RRS/SC Vesuvious
07 Mastercraft X-45
fredcourtot is offline
Old 19th January 2002, 01:43   #2
tfung
tfung's Avatar
I've got the Dinan software with the x-pipes, and the check engine light only came on once, but for another reason.. they got that fixed and it hasn't come on again... don't think it's anything to do with the Dinan software... I think more people get the SES light without the Dinan software than with the software....
US Spec 2001 E39 M5 - LHD
AC Schnitzer
Dinan
3.45 differential
Others
Euro Spec 1999 E39 M5 - RHD
2007 Mercedes E63
2007 Corvette Z06
2008 Nissan GTR
tfung is offline
Old 19th January 2002, 01:55   #3
fredcourtot
thanks Tfung,
maybe you are lucky thus far. Mine only recently started doing this. I went to Dinan this morning and they are telling me it is the x-pipe, at least that's what their Tech Support team is telling them. They looked at the faults and seems the fuel mixture/adaptions are off. You are correct, DINAN is telling me it is not the Software but the Hardware. They will need to adjust the software to work with the new hardware.
I guess thus far, I am the only one with this problem. Thanks for your help.
Fred
07 Porsche 997 TT
06 RRS/SC Vesuvious
07 Mastercraft X-45
Old 19th January 2002, 03:31   #4
BarryC
BarryC's Avatar
Garage: '08 Jet Black E92 M3
Fred,
I had a problem with the SES light soon after putting on my x-pipe and the diagnosis was a faulty cat. The tech thought he might have fried it driving it around town (after removing the stock exhaust) looking for something to stretch the x-pipe.
I have Stage II software because of the K&Ns and have had no problems with the SES light since replacing the cat. Car runs great.
Good luck!
Barry
BarryC is offline
Old 19th January 2002, 18:35   #5
FAST4DR
Senior Member (>500) Official Company representative for R&D Motorsports
FAST4DR's Avatar
Garage: 2000 M5 Anthracite///Black Sport
Send a message via AIM to FAST4DR
The code that comes up as a "faulty cat" can also be triggered by a leak in the exhaust system. If you used clamps to attach the X pipe, have the joints rechecked for leakage. Many times, the clamps that come with systems are sub-par for the job. Even the ones supplied with our Tubi Style unit are not adequate in some situations. The stock tubing is so stout, that getting it to flex and make a snug fit is tough. Check your clamps and make sure that you are using something that will allow for a perfect circlular seal (many have a reinforcement at the clamp body which will interfere). Good luck!!!
FAST4DR is offline
Old 19th January 2002, 20:25   #6
jinferno
jinferno's Avatar
Garage: 2002 porsche 911TT
I had the same problem Fred and the problem was supposedly the cats..had them replaced and took the x-pipe off
problem soleved
J
2002 Porsche 996 Twin Turbo (Basalt Black)
-EVO Exhaust
-H&R Springs
-EVO Short Shifter
-Car Graphic Pedals
-Techart Wheels w/ spacers
-EVO Diverter Valves
-K&N Filter
2003 Hummer H2 (BUBBA!)
2001 Dinan M5 (RETIRED!)
jinferno is offline
Old 19th January 2002, 20:58   #7
fredcourtot
Thanks a lot guys, it seems that it could be the cats then. Is replacing them under warranty? If not, how much are they to be replaced.
thanks for all of your help guys !
fred
07 Porsche 997 TT
06 RRS/SC Vesuvious
07 Mastercraft X-45
Old 19th January 2002, 21:04   #8
BarryC
BarryC's Avatar
The driver's side cat was replaced under warranty. Otherwise the cost would have been around $2k.
Barry
BarryC is offline
Old 19th January 2002, 21:27   #9
fredcourtot
$2K, ouch. I have a feeling that I am going to have a VERY tough time getting this done under warranty then. All dealers around here hate me cuz I have so much aftermarket stuff. I am pretty sure they will say no to warranty. How did you guys get them to OK it under warranty, did you go back to stock?
thanks again
07 Porsche 997 TT
06 RRS/SC Vesuvious
07 Mastercraft X-45
Old 19th January 2002, 21:30   #10
tfung
tfung's Avatar
it'll probably be cheaper to buy sports cats from an aftermarket tuner......
AC Schnitzer
Dinan
3.45 differential
Others
2007 Mercedes E63
2007 Corvette Z06
2008 Nissan GTR
tfung is offline
Nowack Tuning Report, The Truth (Long Version) CharlesW E39 M5 and E52 Z8 Discussion 61 7th January 2009 11:06
Nowack Tuning Report, The Truth (Long Version) CharlesW Most Memorable Threads' 44 30th November 2002 05:49
Problems to look out for when buying M5's BarryP E34 M5 Discussion 29 17th September 2002 18:52
pre-purchase inspection paolo E34 M5 Discussion 8 28th April 2002 23:46
Inspection I & II checklist please IvanDias E34 M5 Discussion 2 2nd November 2001 15:31
Page generated in 0.25815 seconds with 11 queries
