Old 3rd December 2008, 08:18   #1
jajo
jajo's Avatar
Garage: BMW M5
Send a message via AIM to jajo
Where's the warm air?
Hi everyone.
I have run across a problem in my 2002 M5.
I have no heat.
While my heat is turned on, I can BARELY feel the heat. I can turn it on full blast, but I can still barely feel the heat.
Does anyone know what's going on here? My coolant is fine, and I know it's blowing slightly (but not a lot), but it is not even enough to get the car warm. This has been going on for the last two weeks.
I hope I can get some help.
Thank you
Jajo
2002 M5...and after 6 years, I STILL can't get enough of it
jajo is offline
Old 3rd December 2008, 10:30   #2
MarkQC
MarkQC's Avatar
Garage: M5 E39 Carbon Black -silverstone/black interior
Please specify what vents are doing what...
Remember the front middle vents will blow cold, unless you change the mixture manually...
MarkQC is offline
The Following User Says Thank You to MarkQC For This Useful Post:
jclyman (3rd December 2008)
Old 3rd December 2008, 18:22   #3
Mike Krieger
Mike Krieger's Avatar
Garage: 2000 M5 Oxford Green
Is this a fan question or a temperature question? If it is the fan, then search for second stage resister etc.
2000 Oxford Green/Extended Caramel
Split folding seats with ski bag
Alacantra headliner
Mk. IV nav upgrade v.27
16:9 monitor
UF Motorsport Intake air temp. sensor relocation
Bimmernav Bluetooth
PowerChip 93
Royal Purple Synchromax
OEM First Aid Kit
Hardwired V1
AA CAI
Bavarian Auto Angel Eye update
Supersprint headers, SS X-pipe and Evo Racing Cats
Dinan Stage 2 suspension
Dinan 3.45 Diff
Mike Krieger is offline
Old 3rd December 2008, 20:57   #4
jajo
jajo's Avatar
Garage: BMW M5
thanks for the responses.
The air doesn't feel like it's blowing anywhere, even if it's set on "max."
I even looked to see if it was a fuse to no avail. It is listed as fuse 76 which was not there. Do you think they put that fuse somewhere else other than the glvebox since it's 40v?
jajo is offline
Old 3rd December 2008, 21:26   #5
TMcNasty
TMcNasty's Avatar
Garage: '03 M5 - LMB/Blk int./Alu. trim
Well if your fan motor won't blow any air then you probably have the bad fan resistor problem commonly referred to as the final stage unit or FSU.
If your fan is working properly then your center vents could be set to "cold" vs. "hot." Take a close look and notice the thumbwheel in the very center. If this is rolled towards three blue dots instead of three red ones that's part of your problem.
Finally, and quite possibly, you have a bad thermostat and your entire motor is running cool. When that happens hot water to the cabin is greatly reduced creating only lukewarm air for you.
To test for condition three follow these instructions and run test #7.
Gadget Freaks II: Fun you never knew you could have [secret menu]
If the reading goes below 79c after the car is warmed up then your thermostat is faulty. Easiest way to test it is at highway speeds. The increased airflow over the radiator at speed will show the thermostats condition quickly.
Members:
If you want your oil pan repaired (see http://www.m5board.com/vbulletin/e39...rain-plug.html) instead of buying a new one or attempting the repair yourself PM me and we'll work something out. Thinking $60 profit is worth it. You pay all shipping of course. At the moment I have four remaining Timesert inserts looking for homes. If the demand is there I'll keep doing them. If not the tool goes on eBay minus one insert.
TMcNasty is online now
Old 3rd December 2008, 22:32   #6
everycredit
everycredit's Avatar
Garage: 2000 E39 M5 Carbon Black
Drive your car in Hawaii. Weather is fine and plenty of warm air. No warm air here in Seattle.
To answer your question, read TMcNasty's post.
everycredit is offline
Old 3rd December 2008, 23:50   #7
jajo
jajo's Avatar
Garage: BMW M5
tmcnasty, thank you for the suggestions.
When I turn the heat on, it sounds like everything is about to start. But, I hear no fan blowing.
I know it's not the center vent hot and cold switch. I've had the car going on six years so I know about that LOL.
Can the FSU be changed at home or should I take it to the dealer? Thank you for all the help so far. Oh yeah I think the thermostat is fine. The engine is running warm according to the dashboard.
Everycredit, I would love to be in Maui or kauai right now.
jajo is offline
Old 4th December 2008, 00:12   #8
KJM5
KJM5's Avatar
Garage: 2002 M5 LMB
You can change it out. I did mine. Takes about 15 minutes. Search the forum for a DIY.
2002 Lemans Blue/Caramel
9.5” X 18” OEM Wheels on all 4 corners
SS Brake Lines
Dinan Rear Sway Bar
Front Strut Brace
MKIV Nav DVD
IATS Relo
Brake Duct Mod
Stealth One
Hardwired V1
TEC Cupholder
Dinan Stage 1 Suspension – Koni’s
Stoptech Slotted Rotors and Pads
KJM5 is offline
Old 4th December 2008, 01:44   #9
TMcNasty
TMcNasty's Avatar
Haven't had to change one myself, but there are DIY threads on this board. Small hands help w/ the swap.
Members:
Old 4th December 2008, 05:04   #10
Need4Spd
Need4Spd's Avatar
Most likely a FSU if no fan activity at all. If fan blowing but you are not getting hot air, a possibility is faulty heater pump. Small unit under the hood somewhat beneath the oil filter canister.
Need4Spd
Need4Spd is offline
Page generated in 0.14495 seconds with 10 queries
