Camber plates-solid or adjustable - BMW M5 Forum and M6 Forums
Old 27th November 2008, 04:49   #1
blueaudis4
Garage: 2000 M5 Carbon Black Metallic
I am looking into getting camber plates. What is a better route to go. Adjustable like the kmac? or Dinan which are solid?
Dinan Camber plates which are fixed
5 Series*::*M5 (E39) 2000-2003*::*Chassis Tuning*::*Camber Plates
Kmac- there seems to be a stage1 and stage two
Turner Motorsport - Item# 193616 - E39 540 & M5, E38 740 Front Camber/Caster Plates (pair) - E39 E38
Turner Motorsport - Item# 193616K2 - KMAC Front Camber/Caster Plates (Pair) - Stage 2 (Street/Race) - see application chart - E39 E38 E60 E63 E64
Are the dinan plates good enough to give better turn in and feel? Or do I need to go the adjustable ones?
blueaudis4 is offline   Reply With Quote
Old 27th November 2008, 17:25   #2
Need4Spd
Need4Spd's Avatar
I can only speak to Dinan vs. Ground Control. I was all set to use the GCs for their adjustability, but their design did not seem robust enough for my tastes, and things were complicated by their sending me the wrong ones to begin with, and rather than taking them back, suggesting band-aid fixes to my tech that didn't work. So I ended up with Dinans. They are simple, very durable fixed plates. No adjustability, but the resulting camber setting when used with Dinan springs (-1.7 degrees) is just about perfect IMHO, for the street. No doubt you could use a few degrees more negative camber for the track, but you can't run that same setting on the street w/o wearing out the inner edges of your tires in a very short time (hence the need for adjustability for that kind of negative camber). So if you don't track your car, just get the Dinan plates. People complain about Dinan's prices, but there is no doubting, at least in my view, that they do their optimization homework and get in right. To me, that's worth it. I had all sorts of problems using H&R springs and Koni FSDs, and basically suffered with that setup for a year before finally going with the Dinan setup, and now couldn't be happier with that.
If you track your car, you may wish to at least consider the adjustable plates, but so far I have not been impressed with their designs. Now this is just my experience. Others have used GC plates with good success and report no problems.
Need4Spd
'01 M5 (now my brother's car) UUC SSK + Rogue WSR/RE Tranny Mounts+Royal Purple Synchromax/Axxis ULT Pads/StopTech SS Lines/TC Design from BeastPower Anti-roll Bar Brackets/Dinan LtWtFlywheel and Stage 3 suspension/4xOEM rear 275 Goodyear F1 Asymmetrics/Vines thrust arms/IATS relocation/10w-60 oil/hardwired Escort 9500i/Euro Armrest/TEC Cupholder/IceLink/PowerChip 91 Gold/TUBIs!/Strong Strut/BSW Stage 1/BT/Angel iBrights 3.0/space-saver spare by Bimmerzone
'11 Jaguar XFR, Quicksilver exhaust, Escort 9500ci
Unnamed weekend Italian 2 seater with DCT
Future - F10 M5 with manual transmission?
Need4Spd is online now   Reply With Quote
The Following User Says Thank You to Need4Spd For This Useful Post:
herrubermensch (27th November 2008)
