Old 26th November 2008, 14:08   #1
tranck
tranck's Avatar
Garage: 2000 M5 - Silverstone Metallic
Thermostat
SES code idicated bad thermostat - water temp below 1st mark always except in stop and go traffic.
Having it replaced today - 1st one in 176,000 miles.
Question, does a bad thermostat affect performance?
I understand it would if the car was running hot but running cold?
Thanks as usual guys.
tranck is offline
Old 26th November 2008, 15:40   #2
DouglasABaker
DouglasABaker's Avatar
Garage: 2002 Chiaretto Red M5
It will, but more in the longer term due to water in the oil and excess carbon buildup in various places (not the same as the CBU issue talked about here) due to lower operating temperatures. From a hp perspective in the short term you might notice a small issue, but it won't be much - the engine will not make significant adjustments for being cooler than usual.
d-
DouglasABaker is offline
The Following User Says Thank You to DouglasABaker For This Useful Post:
doc$holliday (26th November 2008)
Old 26th November 2008, 17:34   #3
Spooky36
Spooky36's Avatar
Garage: 2002 Carbon Black M5
I recently had this exact problem and ended up replacing the thermostat and temperature sensor. After driving for awhile with the problem, I did notice that while coasting with the car in gear I started to experience hiccups and hesitation. This did not happen with the throttle engaged, only while rolling with the car in (any) gear at low RPM's. Since replacing the thermostat the issue has disappeared.
On a side note, I ended up replacing the thermostat myself with the help of a friend in around 3 hours because the dealer wanted around $950 to replace it. The cost of parts (thermostat & sensor) was around $130. If you replace the O-rings and the thermostat housing gasket you're looking at around $180-$200 in parts. Just wanted to give you a baseline for the fix. PM me if you have any questions.
2002 Carbon Black/Caramel Extended Leather
Tubi Exhaust
Powerchip 93K&N Drop-in Air FiltersZ3 SSKSS Brake LinesAxxis ULT PadsIcelinkBridgestone Potenza RE 505APole Positions
Previous Bimmers:
'99 Titanium Silver/Black E36 M3
'97 Jet Black/Black E36 328is
Spooky36 is offline
Bad Thermostat.... M5Racer E39 M5 and E52 Z8 Discussion 21 21st November 2007 09:33
Biturbo Thermostat quattroboy ALPINABoard.com | BMW Alpina Discussion 2 29th June 2007 17:31
Replacing Thermostat. TeXJ E39 M5 and E52 Z8 Discussion 5 6th November 2006 01:59
3.8 thermostat illjah E34 M5 Discussion 5 29th August 2006 20:02
M5 Thermostat raland9 E39 M5 and E52 Z8 Discussion 2 11th June 2001 05:49
Page generated in 0.09475 seconds with 11 queries
