The Good, the Bad and the VANOS...(long!) - BMW M5 Forum and M6 Forums
Like Tree3Likes
Old 24th November 2008, 22:06   #1
100%Cocoa
100%Cocoa's Avatar
Garage: E39 M5 Carbon Black/Caramel
I've had my Sept 2000 M5 for nearly 4 years now and so far I've only had a very few niggly problems that haven't cost the earth, or caused me any great pain to put right, until.... I noticed back in the spring that she didn't feel quite right, but just put it down to age catching up with the car (117,000 miles now) and that I hadn't noticed things changing through the colder months. Shortly after I'd noticed this feeling of age though, I kept getting intermittent episodes of dramatic changes to the exhaust note, but with no noticable drop in power. I'd had a faulty Exhaust CPS before, so was fairly convinced it was that again, but was getting different codes this time - namely B1 Exhaust CPS, B1 Inlet CPS & Crankshaft Correlation Sensor.
I paid for a full GT1 diagnosis and VANOS test just to be sure, which showed Bank 2 (5-8) was fine, if a little noisy, but Bank 1 was utterly shot. The GT1 couldn't even get past the first measurement. Hmmm, I thought - it's not just a 90 quid sensor then! The official diagnosis by Phil Crouch was a failed solenoid unit so I spent £300 and changed it over.
Where it felt almost fine before, bar the intermittent exhaust note change, now the car would barely run. I couldn't understand how changing one part for a newer one could make a problem soo much worse??
Back to Phil and he plugged her back in again and we got 3 pages of codes! He now diagnosed that either the new unit was faulty or that the little gauze filters round one of the solenoid valves themselves had broken up on the old one and clogged an oil channel or two inside the VANOS unit, which would have the same effect. Ironically, I'd probably made it worse by puhing more bits of gauze in when I fitted the new unit.
(This is where BMW would make you by a new VANOS unit for £3,500 or whatever they cost..... I think even a recon'd unit is £1,500)
So I took her in to Phil's again so he could remove the VANOS on bank 1, break it down to its component parts and give it a thorough clean. He'd then re-assemble it with all new seals. It was only due to be 2 hours labour so I asked him to do both sides while he was at it - half the time is taking off the plenum chamber etc anyway, so it seemed sensible. The total, in theory, for both sides to be fully stripped and cleaned would be around £500. I would then have peace of mind that both units were in rude health and be safely fitted with new seals all round.
The car went back in, and after a while I called Phil to see how things were going. He said that B2 was fine and done, but B1 was full of a tar-like goo, presumably from years of oil not being able to flow freely through the unit. This wasn't to be a problem though - it'd just take a little more effort to clean. At least it explained all the problems in one go!
Very excited, I went to collect the car on Wednesday evening just gone, as Phil had finished the clean, given it an oil service, run it up, performed a completely successful test and driven it home. Phew! Happy days are here again I thought......
It had cooled right down by the time I got there, so I fired it up and my heart completely sank. It was worse than ever! The idle was so rough it was almost like sitting inside a washing machine. I drove it to the end of his road and back and it even stalled twice. Not good.
Even though it was late, Phil being Phil, agreed to struggle back to the workshop there and then, where he discovered that one of the tiny wires that powers the solenoids had chafed through on the way home and was shorting on the body of the unit. He sleeved and resoldered it and the idle impoved dramatically, but GT1 still couldn't advance the inlet cam.
We took it all apart again (it's getting pretty late now!) and with a magnifying glass found a crack in one of the tracks on the solenoid pcb. This is starting to drive me nuts! It must have happened as we took it apart for the 3rd time!
Anyhow, he laid a thin strand of wire along the track and soldered it in place. Now things were starting to sound and feel better and the only thing still failing the test was the exhaust retardation. Since we'd suspected the Exhaust CPS for over 6 months, I agreed to take the car and I'd do the sensor myself on Saturday and go from there.
I'm extatic to say that that went fine and the car is utterly transformed. I am certain that my Bank 1 VANOS has been gunked up for years, as I have never experienced such awesome torque so low down AND such a desire to rev right to the top. It's like a new engine and the noise coming out of my Tubi Rumore is cleaner, and more powerful sounding - in a cold blooded, menacing kind of way. It's like music to my ears! Don't misunderstand me here, the car's aways been amazing, and between 2k & 6k, it's always been like sh*t off a shovel. It's the 2 extremes that have made themselves so apparent now and across the whole rev range it's smoother, mechanically quieter and more willing to rev. When you blip the throttle now, instead of a rattle and a pause, you hear a huge rush of air into the plenum and the rev counter flicks round the dial instananeously . On top of that, the odd idle and wandering revs at parking speeds that I put down to age, have completely gone. The difference in the way the engine feels is like the difference between your head with a hangover and the way you feel after a billiant sleep on the weekend. (Sorry, but I can't think of a better way to desribe it!)
I thought my aging beast was getting long in the tooth and I'd have to nurse her along to the end, but how wrong I was. All she wants now is to be grabbed by the scruff of the neck and driven like she's been stollen. I pushed her hard this weekend and all she wanted was MORE. I have to say I feel the same way.......
Total Bill, including the arguably unnecessary solenoid unit, all the peripheral seals etc, CPS, fuel back an forth, tests and service, was near enough £1200. In my mind, for a car of this calibre, that's a very small price to pay for peace of mind, a mile wide grin and chills up your spine very time you drive it (or even just think about driving it!!)
I'd like to thank Phil for not letting this get the better of either of us, not counting the hours too closely(!), and to Kumaran (M5 London) for all his help with the DIY bits and bobs. Big thanks also to all those on the board who helped out with all my questions leading up to this over the last few months.
I hope this thread may ease the fear that some M5 owners like me, have/had about VANOS failure, and give a few pointers to those with odd problems out there. I've bored you with all the gory details here, as it shows that there really isn't anything you can't fix on these cars if you have the inclination (or know Phil!) and they aren't as expensive to run as some would have us believe...... They are just the greatest cars in the world.
100%Cocoa is offline   Reply With Quote
The Following 15 Users Say Thank You to 100%Cocoa For This Useful Post:
2strokecoldsmoke (29th November 2008), agregatM5 (20th May 2009), ard (24th November 2008), Beemer Guy (2nd December 2008), drfv (25th November 2008), Envisage0 (25th November 2008), gavinp (24th November 2008), J Irwan (26th November 2008), JesperT (25th November 2008), L F X (25th November 2008), Mike S. (24th November 2008), Samsir (17th March 2009), shoand03cobra (26th November 2008), TommeH (4th February 2012), wilsodh (24th November 2008)
Old 24th November 2008, 22:16   #2
wilsodh
wilsodh's Avatar
Thanks for taking the time to write everything up. Great post!
Glad it had a happy ending. Sounds like you've got your back!
Dave
'00 Royal Red/black/walnut M5
'El Diablo'
’00 Black/black DA s/c M5
Carrillo rods, Arias pistons,
Schrick cams, Vortech T-trim,
Supersprint headers/exhaust,
Old 24th November 2008, 22:28   #3
Tiauguinho
Tiauguinho's Avatar
Garage: 2001 M5 Le Mans Blue
Thats a very happy ending!
Good to know that the VANOS can be cleaned and that it may be a solution to some of its problems
2001 BMW E39 M5 Le Mans Blue + Heritage Nappa Black Leather - Van Manen Headers, Stoptech ST-40 BBK. The Garage Queen.
2004 BMW E39 530i Touring M Package Individual Carbon Black + Cinnamon Nappa Leather. Smooth Daily Driver.
Tiauguinho is offline   Reply With Quote
Old 24th November 2008, 22:32   #4
ard
Super Moderator
ard's Avatar
Mechanics like Phil are few and very far between.....
Old 24th November 2008, 22:40   #5
gavinp
Garage: M5 e34 LE 9/50
Great write up, thankyou.
Did Phil say what he thought had caused the gunking up of the vanos ?
This would be interesting so as to possibly avoid in the future
gavinp is offline   Reply With Quote
Old 25th November 2008, 00:02   #6
100%Cocoa
100%Cocoa's Avatar
The blockage almost certainly came from the plastic gauze filter on the solenoid valves breaking up. You could feel it between your fingers on the one I took out. It's the bit circled in red in the pic.....
The Following User Says Thank You to 100%Cocoa For This Useful Post:
gavinp (25th November 2008)
Old 25th November 2008, 04:23   #7
KevinM
KevinM's Avatar
Garage: 2002 E39 M5, Sterling Gray/Caramel; 2007 Z4M Coupe
I'm glad it all worked out! Thanks for the post and pictures!
Kevin
2007 Z4M Coupe (#2) Silver Gray/Black
Too many kids' cars...
KevinM is offline   Reply With Quote
Old 25th November 2008, 06:03   #8
L F X
L F X's Avatar
Garage: 2001 M5 668
i love this post
L F X is offline   Reply With Quote
Old 25th November 2008, 07:03   #9
Beasty5
Beasty5's Avatar
Garage: 03 M5 Blue
Here, here. I am happy for you. What a happy ending. Man, I wish Phil had a twin brother that lives next door. Its guys like that you don't mind paying dealer prices because you know your beast is in good hands. Glad your beast is back.
Vic
03 M5 Lemans Blue/Silverstone -
Powerchip Mafless Tune
Magnaflow 14816s
E60 545i short shifter
powerflex polyurethane thrust arm bushings.
AC Schnitzer style carbon fiber front splitters
M Audio
MB Quart Reference Series front speakers
Polk Audio Tweeters
Matte Black Kidneys
BC Racing Coilovers
Dinan Rear Sways
Beastpower Brackets
BMW iSimple Ipod integration
Beasty5 is offline   Reply With Quote
Old 25th November 2008, 07:58   #10
Stamper1
Stamper1's Avatar
Garage: 2000 M5 silver
Fantastic post, the world needs more Phils.
Stamper1 is offline   Reply With Quote
WTB: Vanos units - Good, bad or ugly. Chris_731 Parts / Other For Sale or Wanted 10 14th September 2008 05:07
Long trip report - some good, some bad glowrider E60 M5 and E61 M5 Touring Discussion 15 21st June 2007 13:57
