battery tender hookup? - BMW M5 Forum and M6 Forums
 1Likes
post #1 of 16 Old 24th November 2008, 03:04 AM Thread Starter
illz
I picked up a battery tender - it has a few connection options - alligator clips, cig lighter, and ring terminals. I want to hook up the ring terminals but am not sure how best to. Since our trunk mount battery lacks the standard terminal posts, where have people who've gone that route hooked up the terminals? Granted, they should connect directly to the battery, but how have you guys done this?
Also, I read some other threads with links to tenders - BMW's for $100, another battery place for ~$50 - Sears has one for $19.99 - tough to go wrong! DieHard Battery Charger/Maintainer - Model 71219 at Sears.com
illz is offline
post #2 of 16 Old 24th November 2008, 03:27 AM
jclyman
In Memoriam
jclyman's Avatar
Owner's Manual Page 132. You can go wrong, if you choose one that doesn't shut off when the battery is fully charged. Also, it should be a SLOW charge so as to NOT shorten the life of the battery with "rapid charges."
- Daniel Boorstin
jclyman is offline
post #3 of 16 Old 24th November 2008, 04:05 AM
Nabio
Nabio's Avatar
I have one installed right next to my battery. It came with ring terminals, which I installed on the bolts which tighten the battery post rings. Just take off that nut and washer, slide the ring down and replace.
+1 on the above stating to get one that automatically shuts off.
Black Sapphire Metallic 2012 X5 M
Nabio is offline
post #4 of 16 Old 24th November 2008, 06:18 AM
gherardini
gherardini's Avatar
I got a BT + [Battery Tender Plus, ~$45] initially for my BMW motorcycles. It's good for extended charging of all batteries except for the BMW AGM [Absorption Glass Mat] batteries.
While not optimal, I open the trunk, pull up the battery compartment cover, pull up the plastic battery cover [you need to unscrew the bolts on the sides] and connect the alligator clips, then leave the cover on lightly & close the trunk.
Which all works until that one day when I drove out of the garage with the tender still attached.....
'02 M5 TiSi-SBI [Sexy Black Interior] - "Audrey"
BMWMOA iBMWr IBA#7268 LPR#71 SEAT#17
- Valentine1 - hardwired
- StealthOne
- SS Exhaust
- CNS Racing clutch
- PowerChips
- GrafxWerks ///M5 Lighted Door Sills, all 4 doors
- Hella Euro clear corner headlights
- Predator ICE v2.1
- Xenon fog lights
- Steath Auto Turn Signal Bulbs
- TC Designs Sway Bar Brackets
'03 540iT ///M Sport Edition [Gone & traded for...]
'10 X6M Dinan [for SWMBO, who brick-walled it...]
'87 K75S - "Maybellene"
'16 R NineT, Weld - waiting for inspiration
Sierra Vista, AZ
gherardini is offline
post #5 of 16 Old 24th November 2008, 07:03 AM
Justin13
Justin13's Avatar
I echo jclyman's statement regarding how you can go wrong. First off, don't skimp on the tender...just not worth it in the long run. Doesn't need to be the top model, but I doubt the $20 model will fit the bill.
Secondly, I hook mine up under the hood. I have enclosed a photo showing where to make the hook ups. The square cap (has a + on it) is your positive hook up and the bolt on the shock tower is the negative hook up.
Hope this helps.
Justin
BMW's owned:
-2003 E39 M5 Sterling Grey
-2003 E46 325xi Electric Red
-2003 E46 330xi Titanium Silver (gone too soon)
-2002 E46 M3 Titanium Silver (sold)
Mods:
-Full Carbon Fiber Interior including illuminated shift knob courtesy of Ultra Carbon Fiber and CA Automotive
-Fully concealed Valentine 1/Stealth 1
-Ultimate Pedals-Brushed Aluminum Anti Slip
-Clear Bra
Future Mods:
-Laser Interceptor
Justin13 is offline
The Following 4 Users Say Thank You to Justin13 For This Useful Post:
D-RodM5 (31st May 2010), jclyman (24th November 2008), NCVU (31st July 2014), TMcNasty (25th November 2008)
post #6 of 16 Old 24th November 2008, 07:12 AM
TQ2K
TQ2K's Avatar
I have the battery tender jr. and use the terminal connection. And since I have the 6.5lbs Voltphreaks battery and have no need for the oem battery drain hole, I slipped the cable thru it and connect the charger under the car and just secure it using a velcro when not in use.
TQ2K
'04 N62 - Alpine White/Truffle
'03 S62 - Petrol Mica/Champagne
'14 N18/R60 - Light White/Carbon Black
'97 S52/4/5 - Alpine White/Dove
'91 M42/4/5 - Brilliantrot/Tan
TQ2K is offline
post #7 of 16 Old 24th November 2008, 08:30 PM Thread Starter
illz
Hope this helps.
Justin
Thanks for the pic and looking out on the quality of the charger. The tech behind a battery tender is pretty simple and I trust Sears to get it right - it's no secret sauce that needs to cost a lot. They are / it is designed to be plugged in for extended periods of time, hence the float charge mode for fully charged batteries that only periodically turns on at lowest amperage as the battery dips slightly below full charge. I'm using an Optima red top battery, not OEM/Varta. Compare the Sears model to the other ~$50 one suggested in other threads - they are just about identical.
Gracias!
illz is offline
post #8 of 16 Old 25th November 2008, 05:55 AM
M5CCIE
M5CCIE's Avatar
I use the cigarette lighter adapter. No issues.
2003 M5 Sterling Gray
Dinan 3.45 differential
TMS Shark Injector - 91 Octane tune
IATS Relocation - Inside Air box
Strong Strut front brace
TC Design rear swaybar brackets
Bluetooth
V1
Aux port
M5CCIE is offline
post #9 of 16 Old 25th November 2008, 07:08 AM
TMcNasty
TMcNasty's Avatar
Justin,
Good deal on that pic. I was gonna ask about an under the hood connection and you read my mind. But instead of the shock tower "-" connection isn't there another "-" for jump starting the car? Why not just use that?
DIY - Oil Pan Thread Repair
http://www.m5board.com/vbulletin/e39...rain-plug.html
DIY - O2 sensor change
http://www.m5board.com/vbulletin/e39...or-change.html
DIY - Replace worn and 'creaking' door seals
http://www.m5board.com/vbulletin/e39...ml#post2163106
DIY - Replace OEM battery with Bosch 49-850B
http://www.m5board.com/vbulletin/e39...h-49-850b.html
TMcNasty is offline
post #10 of 16 Old 25th November 2008, 07:09 PM
jclyman
In Memoriam
jclyman's Avatar
Originally Posted by TMcNasty View Post
Justin,
Just about anywhere on the body or the engine. Any steel bolt threaded into the engine block is grounded.
- Daniel Boorstin
jclyman is offline
Weak battery headzup! [SMG stuck in gear due to battery drain] Mr. Vroom E60 M5 and E61 M5 Touring Discussion 7 12th May 2007 04:30 AM
Battery tender question.... leebro1 E39 M5 and E52 Z8 Discussion 27 12th April 2007 10:08 PM
IPod hookup in M6 gwongster E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 9 24th September 2005 07:46 PM
At what point do you need a battery tender? M5_in_MD E39 M5 and E52 Z8 Discussion 5 21st November 2003 12:41 AM
Battery Location and Charging (Was "Where is the battery located...) FAST 5 E39 M5 and E52 Z8 Discussion 24 14th April 2003 10:15 PM
