Old 18th November 2008, 01:25   #1
Kleintje
Kleintje's Avatar
Garage: E39 M5 Dark Green
Beginning of the end? DCS warning light...ABS warning light....Radio off....
I think its not that bad but;
Tonight and it happend a few months ago too my DCS light came on, ABS light and Brake warning light and my radio went blank. Engine went on running.
It was only for a few seconds. Tonight it happend 3 times. 2 times in idle (stationair?) and one time while driving.
Weird?
Are those system on the same fuse? Bad "earth" (donno how to say in English).
Anybody?
Kleintje is offline
Old 18th November 2008, 01:35   #2
LFC09
LFC09's Avatar
Garage: CarbonBlack E39 M5
how is your battery?
2002 M5 Carbon Black
Black/Grey leather
Brushed Aluminium trim
AiB 3.0 angel eyes
AiB xenon match fogs
BMW 545 shifter
Dinan rear sway bar
TCD rear sway bar brackets
X5 4.8 thrust arm bushings
Bimmernav Bluetooth upgrade
phone cradle V3xx modified
Solaris invisi-bulbs
MkIV Nav V31 custom splash
ex 1959 FC Holden sedan
LFC09 is offline
Old 18th November 2008, 01:38   #3
Kleintje
Kleintje's Avatar
Good....thanks
Nah...I think I replaced the battery summer 2007 for a new one...from BMW (or...from the dealer).
Kleintje is offline
Old 18th November 2008, 07:00   #4
WylM5
WylM5's Avatar
Garage: 91 E34M5 01E39M5
Originally Posted by Kleintje View Post
Good....thanks
Perhaps your battery isn't the problem but the connection is...i.e.- the cables were not put on real tight and have since worked themselves loose in the few months since the replacement or perhaps a wire has a break and is periodically shorting out causing your electrical gremlins.
1991 E34 M5
Dinan Stage III Suspension///Dinan Chip
Brembo Cross Drilled Rotors///HRE 340 Rims
Supersprint Exhaust///UUC Short Shifter
____________________________________
2001 E39 M5
Dinan Front and Rear Brace///Dinan Software///Dinan Differential///Dinan Rear Swaybar///BP Sway bar braket
///Tubi Exhaust
Brembo Front brake kit///UUC Short Shifter///UUC Clutch + Lightweight Flywheel///Rouge Engineering Tranny Mounts///UF Motorsports IATS
///Koni front + rear
WylM5 is offline
Old 18th November 2008, 07:25   #5
KevinM
KevinM's Avatar
Garage: 2002 E39 M5, Sterling Gray/Caramel
Truly, I'd search for you (as I never have endorsed the "do a search" mentality when I know the answer), but I'm tired and about to retire. When my DSC light recently went on as a result of a fuse, I found lots of posts that can point you in the right direction.
GL
Kevin
2007 M Coupe, Silver/Black
KevinM is offline
Old 18th November 2008, 09:35   #6
red_wings05
red_wings05's Avatar
Garage: BMW M5 Carbonblack 2000, just sold.
Send a message via ICQ to red_wings05 Send a message via MSN to red_wings05
If DCS light, ABS light and Brake warning light all comes on at the same time it is often one of the ABS sensor that is failing or there is dirt on it.
How is the weather where you are? Often in the fall, here in Sweden, with a lot of heavy rain mine get dirty and all lights brighten up.
This doesn't explain the radio though.
red_wings05 is offline
Engine warning light bmwmugguy E39 M5 and E52 Z8 Discussion 15 25th February 2008 22:49
Check light warning / Light ECU programmable? whatheheck E39 M5 and E52 Z8 Discussion 4 9th March 2007 21:22
Air Bag Warning Light? amgsmoker E39 M5 and E52 Z8 Discussion 2 2nd March 2007 02:46
Warning Light! Demon_M6 E39 M5 and E52 Z8 Discussion 1 6th May 2006 09:29
Air bag warning light rich E34 M5 Discussion 2 27th August 2003 02:50
Page generated in 0.11514 seconds with 11 queries
