Old 16th November 2008, 12:20   #1
///M5souraya102
///M5souraya102's Avatar
Garage: 2000 M5 ,At night its balck ,and in daylight its bule.
Anyone have this problem with Ipod????
Hello ,
I been reading old posts for 3 hours now ,but could not find the answer to my problem.
My car is 2000 with DSP system .About a year ago i instaled Dice kit in my car .
It was working great until I update the software on the Ipod. Now when i turn on the car ,the Ipod will conect with the dice for a few second and then it will stop.
So I switch from CD to radio to tape ,then to CD again then it will work, but this is not the problem.
After it worked .I have no control to the Ipod from neither the Ipod or the steering wheel.
So what i do is hard rest the Ipod ,and then i can control it from the Ipod only.
Its getting annoying every time i get in the car.I tried everything like (disconect the battery and disconect the 3 pin conector and reset the Ipod through Itunes to the previous software that worked before).
Any help would be great.
Thanks.
///M5souraya102 is offline
Old 16th November 2008, 15:51   #2
Kleintje
Kleintje's Avatar
Garage: E39 M5 Dark Green
Hi,
To make you feel even worse... I have a 1999 with DSP and with a Dice system and with lates iTunes and iPod software.....and its still running.
O' I have other problems. Like the "weird" way to controll it....and I think I have a maximum of playlists. So I wanna take a look what else there is to find on the market.
FYI. I have a iPod Classic Video 160 GB.
KUP! (Keep us posted )
Kleintje is offline
Old 16th November 2008, 17:48   #3
ECB
ECB's Avatar
Garage: 03 Titanium silver M5
I would restore the previous software on your iPod.
03 Titanium Silver/Black Luxury/Burl Walnut
ESS VT 550 S/C, Supersprint headers and Race cats, Dinan 17mm rear sway bar, TCD sway bar brackets
Eisenmann Sport Exhaust, Rogue UD Pulleys, Rogue SSK w/ RP Synchromax fluid, Ultimate Pedals, Euro Armrest,
Hardwired V1, Angel iBrights v.2, 6000K Low beams, HID 6000K fogs, 70W High beams, Hella Supertones, BSW Speaker Upgrade & 10" Sub, Dension IceLink
ECB is offline
Old 17th November 2008, 07:56   #4
///M5souraya102
Originally Posted by Kleintje View Post
Hi,
I have the same Ipod.I will keep you guys posted when i find the sloution.
Old 17th November 2008, 08:01   #5
kindanutz
kindanutz's Avatar
Garage: 03 M5 Jet black
exactly... thats the only thing you changed and thats when ur problems started... so theres your problem...
kindanutz is offline
Old 17th November 2008, 08:02   #6
///M5souraya102
Any idea on how to do that???
I did it twice already,but it kept reseting the Ipod to the factory setting.
How and where do i get the previews software?
Old 17th November 2008, 08:05   #7
kindanutz
kindanutz's Avatar
go to the apple store and explain your situation... they should be able to tell you what software was originally in there and can most likely reinstall the previous software...
Old 17th November 2008, 16:34   #8
shamus_mcd
shamus_mcd's Avatar
Garage: E39 M5 in Titanium Silver
Have you tried resetting the Ipod and disconnecting Dice Power for full reset.
The only thing I usually have to do before putting iPod back in car is hold the 2 buttons on it to reset it and all is fine again.
Life is not Measured in the amount of breaths you take,
BUT in the amount of times it takes your breath way....
///M5
I'm off to the ASTHMA CLINIC now!!!!!!
shamus_mcd is offline
Old 17th November 2008, 20:41   #9
everycredit
everycredit's Avatar
Garage: 2000 E39 M5 Carbon Black
As McM5 said, reset your DICE. I had to do this once.
everycredit is offline
problem with my Ipod dice kit. ///M5souraya102 E39 M5 and E52 Z8 Discussion 1 20th May 2008 06:55
Ipod problem deamoncharger E60 M5 and E61 M5 Touring Discussion 2 24th April 2008 06:46
USB/Ipod interface problem... Alan N E60 M5 and E61 M5 Touring Discussion 3 29th June 2007 02:49
iPod Problem...I think bmw1986 E60 M5 and E61 M5 Touring Discussion 12 24th March 2007 17:21
ipod & aux input volume problem buymenow00 E39 M5 and E52 Z8 Discussion 13 14th September 2004 22:05
Page generated in 0.13788 seconds with 11 queries
