Old 15th November 2008, 07:31   #1
Jeuprx-8
Garage: 325ci, Z4, 745i, X5 3.0i
installed new clutch and flywheel... still have chirp when shifting :-/
So I had a new LUK clutch and flywheel installed. I have put about 300 miles on it now, and I can hear a chirp when I give it hell. In normal driving and shifting it is fine, and there is no slipping. But when I slamming it from first to second, then second to third.. I hear a slight chirp. Is this the clutch slipping or is this something else?
Jeuprx-8 is offline
Old 15th November 2008, 08:12   #2
Blue Angel
Blue Angel's Avatar
Garage: 2000 BMW M5-Gone but not forgotten
When you say ''chirp'' you mean the tires??
Nik
00 Avus Blue ///M5
98 ///M3
Blue Angel is offline
Old 15th November 2008, 09:03   #3
Stika
Stika's Avatar
Garage: E39 M5/Jet Black on Black
Sounds like you're gettin' rubber at shift changes. Not a bad thing if that's what it is (I think it is).
...i wanna go fast...
Stika is offline
Old 15th November 2008, 20:57   #4
wxl1988
wxl1988's Avatar
Garage: 2001 BMW M5 LMB
Sales Feedback: (7)
Send a message via AIM to wxl1988
IF the chirp is coming from the tires, that is something to brag about!
wxl1988 is offline
Old 15th November 2008, 21:25   #5
ard
ard's Avatar
So what WAS the break in period for that new clutch????
How many miles from your last clutch?
ard is offline
Old 15th November 2008, 21:29   #6
Bubbaschill
Garage: 2000 BMW M5 Carbon Black
That's the stock clutch/flywheel set up right? Chirping your tires while shifting has certainly piqued my curiousity...
What did it cost? The reason I'm interested is because when I purchased my car about 10K mi ago, the previous owner had installed a LW flywheel, new clutch and SSK (I think it's a UUC). The clutch works fine but the gear clatter at idle and from 1-1.5K rpms (I already changed the fluid to UUC specs to quell the clatter but it didn't work) is driving me nuts so I'm thinking about reverting back to stock - I've never driven a stock set up - if I do go back, will the performance be noticably (negatively) affected? I guess it boils down to: Is the cost and the performance hit worth removing the LW flywheel/clutch set up to eliminate the gear lash noise?
Sorry to hijack the thread - I thought this thread was a good entree to my question
Thanks in advance for anybody's thoughts -
Bubbaschill is offline
Old 16th November 2008, 00:56   #7
Jeuprx-8
it is definately coming from the tranny.. it is not the tires. I know the different sounds..
Jeuprx-8 is offline
Old 16th November 2008, 03:10   #8
Blue Angel
Blue Angel's Avatar
then you might have a problem. Probably it wasn't installed properly, but I would have it checked out asap just in case it gets worst. Keep us posted.
Nik
00 Avus Blue ///M5
98 ///M3
Old 16th November 2008, 03:42   #9
Stika
Stika's Avatar
Are you getting any other feedback from the car other than the chirp? When the chirp happens, do you hear/feel anythinhg else?
Stika is offline
Aircon Question - chirp chirp! keviha E34 M5 Discussion 12 12th June 2008 12:34
Flywheel Chirp Jayson E39 M5 and E52 Z8 Discussion 3 27th July 2007 05:21
Dinan LTW Flywheel & Clutch Assembly Installed! mikeoski E39 M5 and E52 Z8 Discussion 9 21st June 2006 01:11
Clutch / Shifting Videos are up!!! greg E39 M5 and E52 Z8 Discussion 50 22nd November 2004 15:47
Do you notice that when the clutch is let out after shifting into third, that it..... Turbo323i E39 M5 and E52 Z8 Discussion 2 24th April 2002 05:50
Page generated in 0.22586 seconds with 11 queries
