Old 13th November 2008, 08:12   #1
KevinM
KevinM's Avatar
Garage: 2002 E39 M5, Sterling Gray/Caramel
How do you check the brake fluid level?
So my DSC light came on out of the blue tonight. No other warning lights were illuminated and no codes came up with my Peake reader. A quick search suggests wheel ABS sensors, fuses, and low brake fluid level to start.
Fuse 17 was a bit out, and when I pushed it back in the light went out. So I think that is the cause. However, my original brakes (pads and rotors) are at 57K miles so I thought I'd check the brake fluid level anyway (I should point out I had a brake flush a few years ag0 as part of the BMW maintenance program, then had Inspection II in January 2008). So the manual tells me the reservoir is under the driver's side air cabin filter housing, but does not state how to access it. I found many posts alluding to taking out the cabin filter housing but none that actually describe how to do it (maybe I missed the posts, but I did try).
So, just out of curiosity, how does one actually check the brake fluid level?
Thanks in advance.
Kevin
2007 M Coupe, Silver/Black
KevinM is offline
Old 13th November 2008, 08:27   #2
razahyde
razahyde's Avatar
Garage: 00 Carbon m5
Sales Feedback: (29)
Send a message via AIM to razahyde Send a message via MSN to razahyde
the reservoir is under the driver side cabin filter. rest should be self explanatory.
razahyde is offline
Old 13th November 2008, 08:39   #3
jaj
jaj's Avatar
Garage: 2008 M3 Coupe Space Grey
Thanks in advance.
Open the hood. The cabin air filter is that black box right up against the firewall at the bottom of the windshield. The whole box comes out to reveal the brake master cylinder below it.
Pop the metal spring clip that runs along the front edge of the filter box and lift off the lid. You don't need to take the filter out.
Undo the connector to the switch that sits just in front of the box - the switch comes out with the box, the wire doesn't.
Pop the three clips along the center edge of the box where the snorkel enters it - just pry up gently with a flat screwdriver blade and they'll let go. When all three have popped, the ring just slides back about 1/2 inch, releasing the snorkel's grip on the housing.
The housing is now retained by a metal spring clip that slips down over a black post at the front near the switch you disconnected. Just squeeze the spring wires together and lift - the whole filter housing will lift up and out.
Reassembly is the reverse of removal. The first time it looks a little daunting but after you've done it a few times it takes less than a minute.
jaj is offline
The Following 3 Users Say Thank You to jaj For This Useful Post:
chowdah (13th November 2008), jclyman (13th November 2008), KevinM (13th November 2008)
Old 13th November 2008, 14:21   #4
DouglasABaker
DouglasABaker's Avatar
Garage: 2002 Chiaretto Red M5
And as a side note, if you'd had a fluid flush then the level of your fluid isn't likely to tell you anything about whether your brakes need to be replaced anyway - they refilled it when it was flushed.
Lastly, remember that the sensor for pads is only on 1 pad per axle. Any or all of the other 3 could still be worn out due to a sticking caliper, etc. Take the wheels off and look if you want to be sure about pad life.
d-
DouglasABaker is offline
The Following 2 Users Say Thank You to DouglasABaker For This Useful Post:
Old 13th November 2008, 20:44   #5
KevinM
KevinM's Avatar
Jaj, thanks!! And Doug, thanks for the comments. I do need to check the brake pads but don't have lift or a jack so I guess I'll need to take it to a shop.
Kevin
KevinM is offline
Old 14th November 2008, 01:26   #6
Kent Bullis
Garage: 2003 M5 Imola Red 52000 mi
checking brake fluid level
Should the fluid be at the full line with the cap on and the level sensor down in the fluid, or with the cap off and the level sensor removed? I recently had to remove some fluid when I put new pads on and wasn't sure where my level should be when I was done.
Kent Bullis is offline
Old 14th November 2008, 03:14   #7
DouglasABaker
Cap on, sensor in...
d-
Old 14th November 2008, 03:18   #8
Redneck M5
Garage: 2002 M5 Imola Red
There also a warning switch to tell you if the hydraulic fluid is too low.
Redneck M5 is offline
Old 14th November 2008, 04:07   #9
CSBM5
CSBM5's Avatar
Garage: 2001 M5 LeMans Blue
Dealerships (and maybe your indy) have a little tool that you can just stick through an opening in the wheel and measure the brake pad thickness...just takes a second on each corner. I think it reads pad thickness in mm.
Current stable:
Ground Control camber plates
Stoptech front brake kit
Brake ducts opened
TC Design brackets
1996 Volvo 850R wagon
CSBM5 is offline
The Following User Says Thank You to CSBM5 For This Useful Post:
KevinM (14th November 2008)
[New] E39 M5 2000. Check Coolant Level and Check Oil Level sajStars E39 M5 and E52 Z8 Discussion 9 5th August 2008 16:11
Brake Fluid Level Check/Fill Procedure Chessie E39 M5 and E52 Z8 Discussion 4 15th October 2007 17:44
What is the proper fill level for the trany fluid? surge709 E39 M5 and E52 Z8 Discussion 10 1st February 2007 07:40
How to check power steering/SLS fluid level? Gop-Dogg E34 M5 Discussion 1 3rd November 2003 09:40
Checking Battery Fluid Level Chris Foote E39 M5 and E52 Z8 Discussion 0 14th April 2002 00:53
Page generated in 0.14430 seconds with 11 queries
