Old 12th November 2008, 08:08   #1
PedM5
PedM5's Avatar
Garage: Le Mans Blue M5
my M5 won't start :(
After I got my lotus I didn't drive my beast much, I wanted to get used to the feel of the new addition. When I went to turn on the beast it cranked but it didn't catch, right when it should normally catch it made a winding down noise. I tried charging the battery and it didn't help, battery has power. I was going to call a tow truck and decided to try one last time and it started right up and worked everyday for a week then all of a sudden it was dead again. Now if I try to crank it, it tries as it should but dies out as before, now at the end of the winding down it makes a shrieking noise. Not so comforting. I did a search and from what it sounds like to my ears I'd think the car is starving for fuel, I don't know if it's a clogged filter, the fuel pump or the fuel filter...or maybe none of the above?
This happen to anyone else? any suggestions before I send it off and spend $150 on diagnosis at the stealer?
2002 LMB 2 tone Blue
Powerchip Software
AFE+A/A Intake
UD Pullies
Britalman Exhaust and X-pipe
Custom "A1" Headers
JB Racing flywheel
19" BBS CH's
H&R Coilovers
Dinan Sway Bars
PedM5 is offline
Old 12th November 2008, 14:00   #2
bimmernut1
bimmernut1's Avatar
Garage: Ti Silver M5, Red Porsche C4S
If you haven't done so, the first thing I'd do is take the battery in and have it tested under load. Measuring voltage at the post doens't mean one of the cells is not bad. That's an easy first step. If you find it's the battery, replace it and get a battery tender to keep it under full charge when not being used.
2003 Titanium Silver M5
1996 Red Porsche 993 C4S
1979 Tobacco Metallic 911SC
bimmernut1 is offline
The Following 2 Users Say Thank You to bimmernut1 For This Useful Post:
jclyman (12th November 2008), Mike S. (12th November 2008)
Old 13th November 2008, 06:56   #3
Lancefitzgiben
Lancefitzgiben's Avatar
Garage: 2001 M5 Silverstone
Send a message via AIM to Lancefitzgiben
when it comes to a battery tender, how do we choose one?
Lancefitzgiben is offline
Old 14th November 2008, 02:22   #4
TMcNasty
TMcNasty's Avatar
Garage: '03 M5 - LMB/Blk int./Alu. trim
Sears had a 2 amp one one sale last week for $20 (regular price is $30). It should be up to the job...they're no brainers.
edit: still on sale!
http://www.sears.com/shc/s/p_10153_1...s+%26+Boosters
hooks up to batt or thru ciggy lighter. I own 2 of these.
TMcNasty is offline
Old 14th November 2008, 02:42   #5
nerio02
nerio02's Avatar
Garage: m5 e39 ROYAL RED
i once bought me something like that before to put in the sig lighter, but before i used it, i read the manual off that thing , and somewhere there was stated, dont use iff any electrical devices are in the car..meaning navsystem,dvd player, etc..xhen applyed trough the sigaret lighter system
i dont say they are bad,and dont want to start a yes/no debate on that.it was just noted in the warning page for my system.
so i never tryed it, too be on the safe side.
so be carefull with those, i would say.
nerio02 is offline
Old 14th November 2008, 02:48   #6
jclyman
jclyman's Avatar
BMW sells 2 (one branded BMW, the other branded Mini). The BMW one uses the cig lighter. The Mini one uses alligator clips. I prefer the alligator clips.
I have a few (and, I use 'em).
The BMW ones are more expensive, but they work just fine. Very slow charge, which is a good thing.
nerio02 is right ... be careful what you buy for an M5.
- Daniel Boorstin
jclyman is offline
The Following User Says Thank You to jclyman For This Useful Post:
nerio02 (14th November 2008)
Old 14th November 2008, 03:13   #7
Redneck M5
Garage: 2002 M5 Imola Red
Sounds like your battery. Test it. With the car off you should get 12.6. While running, a volt or more higher. Load test is a good idea.
Are the battery cable showing any corrosion?
You could also have a parasitic draw issue.
How long did you crank it while you were trying to turn it over? 15 seconds is the max at any one time. Wait two minutes between attempts to cool it off.
Redneck M5 is offline
Old 14th November 2008, 03:58   #8
bimmernut1
bimmernut1's Avatar
I've attached a link with the selection guide. I have both a battery tender plus and two of the waterproof battery tenders. Both types work fine. One just puts out more current and has different charging cycle software. Just make sure you order the 12v model. Since you want be using it for a fast charge, just to maintain the voltage level, the smaller waterproof model gets the job done for less money.
Batterytender.com - Home of All Your Charging Needs
E60 M5 w/ Dinan Stroker VS Dinan E39 M5 S3 Rallistas E39 M5 and E52 Z8 Discussion 44 16th November 2008 23:43
Video: Modded M5 Vs. Stock M5 BMWPower06 E60 M5 and E61 M5 Touring Discussion 66 13th November 2008 07:45
Picture of spotted M5: interesting paintjob on stock BMW M5 wheels Gustav E60 M5 and E61 M5 Touring Discussion 32 6th November 2008 07:44
An M5 to M5 waive... finally! joenjolera.com E60 M5 and E61 M5 Touring Discussion 23 2nd November 2008 04:37
My new M5 cpark352 E39 M5 and E52 Z8 Discussion 25 29th October 2008 03:55
Page generated in 0.13418 seconds with 11 queries
