Old 11th November 2008, 17:38   #1
ps4570
ps4570's Avatar
Garage: 2003 M5 Le Mans Blue
Stripped Stabilizer Link?
Hi all! I need some DIY help. I was trying to remove my rear stabilizer bar and found the nut (part 7 below) on the driver's side Stabilizer Link won't come off. The bolt rotates, but the nut doesn't budge. It feels like there is something stripped in the Stabilizer Link. There is also a lot of play in the link compared to the other side. I can get it to wiggle back and forth. The problem is between parts 6 and 7 in the diagram below.
Before I call uncle and take her into a mechanic, I thought I'd ask for suggestions here.
Thanks in advance!
Phil
ps4570 is offline
Old 11th November 2008, 18:01   #2
m5 deamon
m5 deamon's Avatar
Garage: 2001 e39 m5 carbon black on black sport interior
Send a message via AIM to m5 deamon
you need to put a wrench on the inside of the link to keep it from spinning i think its a 15 or a 17 wrench then you will be able to lossen the nut
2001 m5 Carbon Black, Black sport interior, m audio
AA cai with bmc air filters
AA software going to change to either ess or pc
UUC Light Weight FlyWheel And Organic Clutch
UUC evolll ssk \ Dssr
UUC Big Boy Clutch stop v3
UUC Transmisson mounts
Steelbraded clutchline
Eisenmann Race Exhaust 83mm tips
Supersprint X pipe
Steel braded brake lines
Dinan rear sway bar
Dinan stress bars front and rear
Tc swaybar brackets
PS2 tires
Axiss ult pads front and rear
Dinan JRZ suspention kit
Euro head lights
Predator ice v2.1 angel eyes
Bimmian black kidney grills
DDM xenon fog lamps
Solaris amber bulbs
led lic plate lights
v1 hardwire
m45 blinders updated version
To Come... dinan headers, stoptec bbk
m5 deamon is offline
The Following User Says Thank You to m5 deamon For This Useful Post:
ps4570 (13th November 2008)
Old 11th November 2008, 22:54   #3
rneedham1979
Banned
rneedham1979's Avatar
Garage: 2005 4.8IS, 2000 STOCK M5
what he said... LOL
rneedham1979 is offline
Old 12th November 2008, 00:04   #4
ps4570
ps4570's Avatar
Sounds very obvious, but it sure wasn't last night.
I did notice a flat nut with rounded edges back there, seems like it had only two flat slides. I did put a wrench on it, but it seemed so different from what I was seeing on the passenger side, that I was scared to put too much force on the nut. I don't remember there being any room to put a wrench inside of the link on the unmoving passenger side. I'll need to make some time to look at it again.
Oh, what brought all this up is I replaced both sway bar brackets with aftermarket ones. I was having some fun driving hard and all of a sudden I started to get some wheel hop. I put the car up and found the OEM bracket on the driver's side had broken. I had planned to remove the sway bar during the replacement, but it wasn't necessary, and the sway bar seemed to be stuck or incorrectly attached to the stabilizer link on that side. Sigh, probably won't be able to get to it again until the weekend.
ps4570 is offline
Lucas Synthetic Oil Stabilizer M5_965T E39 M5 and E52 Z8 Discussion 74 7th August 2007 16:40
BT Air Intake Hose and Stabilizer quattroboy ALPINABoard.com | BMW Alpina Discussion 4 31st May 2007 07:37
Winterizing the M5 and gas stabilizer Ivan C E34 M5 Discussion 1 26th December 2002 20:16
Stabilizer fin : any idea ? ydelta E39 M5 and E52 Z8 Discussion 5 12th June 2001 09:30
Broken rear stabilizer attachment ! johann E39 M5 and E52 Z8 Discussion 12 11th May 2001 16:21
Page generated in 0.09879 seconds with 11 queries
