Old 11th November 2008, 16:49   #1
1bad540
1bad540's Avatar
Garage: 2002 M5 Titanium Silver
Wheel bearing bad??
Lately, I have been getting a low speed "rubbing" type feeling in the steering wheel. I noticed the RF wheel rotor rubs a little more when I spin the wheel after driving. I removed the caliper so I could spin the rotor freely. There is a slight rubbing type sound coming from the center hub. Is it normal to have some noise from the bearing or is it gone bad. I haven't check the other side yet to compare the noise level. I also suspect maybe its going bad because I have had a lot of tire defect messages. Any thoughts
1bad540 is offline
Old 11th November 2008, 18:18   #2
Envisage0
Garage: E39 M5 Avus Blue
Originally Posted by 1bad540 View Post
Is it normal to have some noise from the bearing or is it gone bad. I also suspect maybe its going bad because I have had a lot of tire defect messages. Any thoughts
Noisy bearing + tyre defect messages.. Just what I had.
New bearing sorted it. Not a big repair..
**** it, let's do it - Australian proverb
Envisage0 is offline
Old 11th November 2008, 22:10   #3
1bad540
1bad540's Avatar
Is it normal to have a bearing go bad at 50K miles? Did you have the slow speed rubbing type vibration as well? I'm guessing there should be no noise coming from the center hub when it spinning. I'm sure it's magnified when the weight of the car is on the wheel as well. Is it a DIY job to changes the bearing?
1bad540 is offline
Old 12th November 2008, 00:07   #4
shamus_mcd
shamus_mcd's Avatar
Garage: E39 M5 in Titanium Silver
my front one went at 57k but i think that was due to the dodgey garage who fitted new front disks.
My wheel made a ticking noise rather than a rubbing noise.
Life is not Measured in the amount of breaths you take,
BUT in the amount of times it takes your breath way....
///M5
I'm off to the ASTHMA CLINIC now!!!!!!
shamus_mcd is offline
Old 12th November 2008, 02:06   #5
BKH
BKH's Avatar
Garage: 2000 BMW M5 Silverstone
FWIW I had Chris at BMS listen to my wheel bearings a few days ago - he used a stethoscope and found one "grumbling" wheel bearing on my car (with 95k miles). I'll replace both when my Dinan BBK goes on shortly.
BKH is offline
BAD VENDOR WHEEL PROBLEMS WHAT DO I DO? daddymalu E60 M5 and E61 M5 Touring Discussion 26 12th November 2008 00:14
wtb wheel bearing razahyde For Sale or Wanted 1 1st October 2008 09:13
wheel bearing problem? madm5 E34 M5 Discussion 4 16th June 2005 23:34
wheel bearing noise tonym5 E34 M5 Discussion 4 28th January 2005 09:03
Anyone have a front wheel bearing go bad? MariettaM5 E39 M5 and E52 Z8 Discussion 7 14th August 2003 05:11
Page generated in 0.10263 seconds with 11 queries
