Old 14th January 2002, 18:22   #1
Deanger
Garage: GT2
Exclamation Is my oil temp too high?
Had the BEAST since June. 5.6 K miles now. Right from the start I've seen temps routinely near the middle dot -- the coolest, and I do mean coolest I get is a chilly california night, cruising in 6th gear on a flat highway at about 120KPH, and that is peg at half-way between first dot and second.
In mixed driving, I often am just below or at middle dot. And by that mixed, I mean stop/start city traffic.
I've burned about 3 qt oil since new.
It's been on my mind. A friend and fellow BEAST owner has always said I'm running hot. And I did have the fan bulletin done before delivery.
Help
Dean
Deanger is offline
Old 14th January 2002, 18:27   #2
AJ
you are running just a tad hot. on the highway, doing around 70 in a 80 degree weather your needle should be just a little past the dot on the left of the 6 o'clock one.
the only time i've seen mine at 6 o'clock is right after doing 140 in a 90 degree day.
however, i wouldn't bother. next time when you bring the car in ask them to check the calibration of the oil temp meter, but again- i would not sweat it.
alex
00 m5
AJ is offline
Old 14th January 2002, 18:31   #3
Deanger
Garage: GT2
What about the oil consumption? Searching this site- I feel like that's a lot of oil I've burnt off. In an old air-cooled 911 that would make sense but, I don't know enough about the M5's powerplant.
I was conservative during break-in. Now I drive it "normally" for the most part - though I do occasionally let it run for 5-10 minutes at a elevated RPM say a few minutes a 5000RPM, then a few at 3000RPM, then a minute at 6000... This kind of steady all-level break in worked wonders in my 911's. Is it bad here?
Deanger is offline
Old 14th January 2002, 21:01   #4
PhilSeastrand
PhilSeastrand's Avatar
Garage: 2001 M5 Silverstone/Silverstone
Send a message via MSN to PhilSeastrand Send a message via Yahoo to PhilSeastrand
Oil consumption is not bad at all. 3 qts over ~6K miles is only 1 qt per 2K miles. Many people have seen much higher consumption than this. It should start to drop after 10K or so.
Phil
2010 Toyota Prius
2004 Honda Pilot
PhilSeastrand is offline
Old 14th January 2002, 21:03   #5
PhilSeastrand
Regarding the oil temp, what you described is pretty consistent with what I'm seeing. When we were at Sears Point, I got the water temp up to red (computer was warning me) and the oil was just a little over the center dot. Normal driving is slightly past the first dot and heavy driving brings it closer to the center dot.
Checking oil, back to basics? kwalls E39 M5 and E52 Z8 Discussion 25 29th April 2003 02:04
how to lower oil temp tfung E39 M5 and E52 Z8 Discussion 7 22nd June 2002 10:54
Oil level = oil temp? ALX E39 M5 and E52 Z8 Discussion 15 17th January 2002 02:46
Q: Is oil temp change normail after service? M5_Surge E39 M5 and E52 Z8 Discussion 12 8th February 2001 12:52
Page generated in 0.14751 seconds with 11 queries
