Windshield wipers stopped working - Any thoughts? - BMW M5 Forum and M6 Forums
post #1 of 11 Old 6th November 2008, 04:42 PM Thread Starter
BhamM5
BhamM5's Avatar
Exclamation Windshield wipers stopped working - Any thoughts?
Living in the Pacific Northwest, functioning windshield wipers are essential to survival. I tend to keep my in the auto-sensing position, however, when driving home last Friday (in the rain) they suddenly stopped working. There was no response in any of the wiper positions. Fortunately, there was still daylight left and I was on a country road doing 35mph and was able to pull off the road quickly. I turned the car off and then turned the car back on and everything was back to normal as if it never happened. I racked it up a minor and temporary glitch.
And that brings us to this morning. I'm driving 80mph on I-5 heading into Seattle for work. It is dark and raining hard. I have the wipers on the auto-sensing position and they are working perfectly. Again, they suddenly stopped working. Thank god the traffic was light because I had to do an emergency pull over to the shoulder because I could not see anything. I turned the car off and back on multiple times with no success at recovering wiper functionality. Not left with many options, I got back on the freeway and slowly drove a mile to the next exit that had a gas station. I was able to buy a bottle of RainX and apply it to the windshield. By the time I completed this process and restarted the car to continue my commute, the wiper functionality had returned.
My thinking is the wiper motor must be overheating and shutting down but if anyone has any further insight into this behavior, I would be most appreciated. Thanks!
BhamM5 is offline
post #2 of 11 Old 6th November 2008, 05:19 PM
jclyman
In Memoriam
jclyman's Avatar
It has never happened to me (maybe 'cause I don't use them much in SoCal, although I take a lot of long trips and have driven in heavy rain from Seattle to the Oregon border), but I, too, always have them on Auto.
My first assumption would be the same as yours. The symptoms make heat sound logical. But, why wouldn't it happen to all M5s?
Could you be missing some rubber strips or insulation that keep cabin heat from getting to the motor? The next thing I would try, is to turn off the interior heat (I know, it will be COLD) and see if it still happens.
It could be dirty contacts on the motor, or a motor that is nearly worn out. Nearly worn out motors (brushes almost completely worn down) sometimes work intermittently, although they usually go south and never return. And, I suppose it could be a motor that lets some water inside it's case.
Good luck.
- Daniel Boorstin
jclyman is offline
post #3 of 11 Old 7th November 2008, 02:34 AM Thread Starter
BhamM5
BhamM5's Avatar
So I was able to get my car into the local dealer this morning and they were able to take a look at it. It looks like it was a simple replacement of a relay versus the more expensive possibility of the wiper motor. They said it is a pretty common failure. In any case, it allowed me to make it home safely as the weather is worse this evening than it was this morning and wipers were a requirement.
BhamM5 is offline
The Following User Says Thank You to BhamM5 For This Useful Post:
jclyman (7th November 2008)
post #4 of 11 Old 12th December 2008, 05:26 PM
Cantresjr
Cantresjr's Avatar
Cantresjr is offline
post #5 of 11 Old 12th December 2008, 06:48 PM
gsfent
gsfent's Avatar
Originally Posted by Cantresjr View Post
did they tell you were the relay is or the part number? i have the same problem
From memory, below the passenger side cabin air filter box. Do a search, I think someone actually did a writeup with pics and part number.
Dinan Stage 3 suspension, SS jet coated headers, ESS SC kit w/ 1 range colder NGK's, 92mm pulley, 440 Big Greens, TTFS alpha N tune for meth, RK plenum plates, Sachs high performance PP and CCC proprietary clutch disc, stock DMFW, open brake ducts, Hamann front splitters, TEC cupholder, U.S.(Euro style) tilt/slide armrest, 6k HID fogs, 6k super white low beams, V1/Stealth1, dual head LI, 2.65 diff w/40% lockup/2x dynamic, compact spare, Euro trailer hitch, Mocal oil cooler, ACS type rear spoiler, Rogue custom SSK and tranny mounts, ST 355 BBK (fronts), BP sway bar brackets, Bluetooth retrofit, Speedhut boost gauge, Dinan TB's and VS, KB BAP, Howerton/HFS-3 Aquamist WI trunk setup.......
gsfent is online now
post #6 of 11 Old 12th December 2008, 08:05 PM Thread Starter
BhamM5
BhamM5's Avatar
The invoice I have shows the part number as 61-36-8-384-505 (Double Relay). ($23.88)
I have not had a single problem since this relay was replaced and I have been using the wipers a ton lately.
BhamM5 is offline
post #7 of 11 Old 15th December 2008, 01:59 AM
Cantresjr
Cantresjr's Avatar
post #8 of 11 Old 15th December 2008, 02:51 AM
ard
Super Moderator
ard's Avatar
Just so us DIYers can feel good ( ) what was the labor charge?
Glad it was relatively simple
A
ard is offline
post #9 of 11 Old 15th December 2008, 06:24 AM Thread Starter
BhamM5
BhamM5's Avatar
BhamM5 is offline
post #10 of 11 Old 15th December 2008, 08:07 AM
Nabio
Nabio's Avatar
Fired up the beast tonight, it's finally raining in Berkeley. Turn on the wipers, they move about a third of the way up and stop. Now they are just frozen there. I'm going to try it again tomorrow and hope its one of those electrical gremlin deals, but if not it looks like I too may need a new relay.
edit: Just saw the above labor charge. Two minutes later I found this thread with instructions on replacement. I love this board.
Black Sapphire Metallic 2012 X5 M
Nabio is offline
Troubleshooting stopped wipers? M5Joe E39 M5 and E52 Z8 Discussion 13 25th March 2011 05:26 PM
HELP!! WINDSHIELD WIPERS NOT WORKING boostinb18c1 E39 M5 and E52 Z8 Discussion 5 5th November 2008 10:54 PM
<Wipers Stopped Working> mruiz0280 E39 M5 and E52 Z8 Discussion 6 19th April 2008 09:24 PM
Windshield Wipers sctazmon E39 M5 and E52 Z8 Discussion 4 23rd December 2003 07:31 AM
Windshield wipers Wyldm5 E34 M5 Discussion 6 19th September 2000 06:09 AM
