Old 2nd November 2008, 04:35   #1
M5LAY
Garage: 2000 M5- Anthracite Metallic
Sunroof?
I recently purchased a 2000 M5 and am still learning alot of features of these great cars. Mostly cause of these forums so thanks but i been messing with the sunroof was wondering if the sunroof was suppose to go up when you push forward on the button? If it does mine doesn't. Any reason why?
M5LAY is offline
Old 2nd November 2008, 04:58   #2
kindanutz
kindanutz's Avatar
Garage: 03 M5 Jet black
well first of all it's a moon roof... and if you push the button backwards in the direction of the back of the car the moon roof will fully retract backwards... if you push the butoon up towards the roof the moon roof will tilt up in the back instead of retracting.... hope that helps
kindanutz is offline
Old 2nd November 2008, 05:18   #3
DouglasABaker
DouglasABaker's Avatar
Garage: 2002 Chiaretto Red M5
And interestingly enough, if you read the owner's manual it'll tell you what should happen when you push the button forward.
And no, he is not being pedantic by telling you it is a moonroof instead of a sunroof. Sunroof's are made of metal, moonroof's are made of glass.
d-
DouglasABaker is offline
Old 2nd November 2008, 07:13   #4
ps4570
ps4570's Avatar
Garage: 2003 M5 Le Mans Blue
In case you need a 2K manual (link will open to a PDF file).
ps4570 is offline
The Following User Says Thank You to ps4570 For This Useful Post:
WylM5 (2nd November 2008)
Old 2nd November 2008, 21:16   #5
jclyman
jclyman's Avatar
I believe ALL Owner's Manuals can be downloaded from the BMW NA website. Which I prefer to hard copy.
But, strangely enough (last time I checked), the Computer/NAV Owner's Manuals are NOT available for download from BMW NA ... ???
Go figure.
- Daniel Boorstin
jclyman is offline
Old 3rd November 2008, 03:49   #6
M5LAY
Thanks for the comments. Ok so mine is not working like i figured. It retracts back ok but does not tilt up. In the manual it says to raise it up and hold the button for 20 seconds. Well that is what mine is not doing. Any suggestions?
M5LAY is offline
Old 3rd November 2008, 04:10   #7
WylM5
WylM5's Avatar
Garage: 91 E34M5 01E39M5
Try checking your switch.
1991 E34 M5
Dinan Stage III Suspension///Dinan Chip
Brembo Cross Drilled Rotors///HRE 340 Rims
Supersprint Exhaust///UUC Short Shifter
____________________________________
2001 E39 M5
Dinan Front and Rear Brace///Dinan Software///Dinan Differential///Dinan Rear Swaybar///BP Sway bar braket
///Tubi Exhaust
Brembo Front brake kit///UUC Short Shifter///UUC Clutch + Lightweight Flywheel///Rouge Engineering Tranny Mounts///UF Motorsports IATS
///Koni front + rear
WylM5 is offline
Old 3rd November 2008, 04:34   #8
kindanutz
kindanutz's Avatar
the manual says to hold the button in the up position for 20 seconds to get it to tilt up in the back???... i don't think so... if the moonroof is fully closed and u press the button up it should tilt up within 2 secs... i hope you aren't trying to do this with the moonroof fully retracted backwards... lol
Old 3rd November 2008, 04:46   #9
WylM5
WylM5's Avatar
Ah..yes- to make this more simple.
CLOSE your moonroof. Retract your headliner all the way back so that you can see your moonroof moving. From the closed position try pushing up on your switch...as kindanutz says it should immediately start tilting up at the back end.
1991 E34 M5
2001 E39 M5
///Tubi Exhaust
WylM5 is offline
Old 4th November 2008, 20:32   #10
AfricaOffroad
AfricaOffroad's Avatar
Garage: 1991 E34 M5
d-
How did you guys know that he didn't in fact have a sunroof?
1991 E34 //M5
2003 E55 AMG
2009 KTM 950 Super Enduro
2009 KTM 300 XCW
AfricaOffroad is offline
anyone ever see a US M5 w/o a sunroof? dark knight E39 M5 and E52 Z8 Discussion 10 28th August 2007 18:18
E34 M5 with no sunroof? Rickcoin E34 M5 Discussion 19 26th November 2006 02:17
US M5 without a sunroof? Smoltz E60 M5 and E61 M5 Touring Discussion 11 15th August 2006 14:15
does the e60 M5 has sunroof? Aric E60 M5 and E61 M5 Touring Discussion 7 1st June 2005 13:08
Sunroof... SPMatt E39 M5 and E52 Z8 Discussion 6 3rd August 2000 09:03
Page generated in 0.22883 seconds with 11 queries
