• Latest threads
    • Custom feed
      • Updates
        • YouTube
          Old 13th January 2002, 06:49   #1 (permalink)
          steve adams
          steve adams's Avatar
          racing fuel compatible with M5 ?
          The neighborhood Citgo now has 100 octane racing fuel available ... it's a bit pricey (around $4 per gallon) ...
          Is there any performance benefit to running 100 octane occasionally in the M5 ?
          Is this high octane fuel compatible with the M5 ? Any drawbacks in terms of wear and tear on the engine?
          Seems like the combination of the sport mode setting and 100 octane fuel would be a literal kick in the pants ....
          Thanks,
          Steve
          '02 Titanium / Silverstone
          steve adams is offline
          Old 13th January 2002, 07:34   #2 (permalink)
          KirklandM5
          KirklandM5's Avatar
          Send a message via AIM to KirklandM5 Send a message via Yahoo to KirklandM5
          as long as its unleaded its ok...
          only a dyno test would indicate any performance benefit...
          Since the highest street octane in Europe is 93 using the US method of measurement (98 RON, 88 Motor or 93 AKI). I doubt if anything over say 94 would make a difference using the factory computer software.
          JL
          2001 E39 M5 Titanium Silver/Silverstone
          1997 BMW M3 Gruppe N Race Car
          2005 X5 4.4i
          KirklandM5 is offline
          Old 13th January 2002, 16:04   #3 (permalink)
          joegraz
          joegraz's Avatar
          How 'bout with Dinan Stage II? Does anyone out there know?
          '03 Sterling Gray M5
          '04 Titanium Silver M3 Coupe
          joegraz is offline
          Old 13th January 2002, 18:05   #4 (permalink)
          wbarber
          wbarber's Avatar
          Send a message via AIM to wbarber Send a message via Yahoo to wbarber
          This is an interesting question. I have been putting Sunoco 94 octane gas into my car, but I don't know if I am wasting my time. Any thoughts on this?
          Bill
          wbarber is offline
          Old 13th January 2002, 18:29   #5 (permalink)
          Teutonaddict
          Teutonaddict's Avatar
          My 'butt-dynomometer' says it works!
          And I recall reading that Steve Dinan said (at last year's M5 Extravaganza) that true race gas is the easiest way to extract more BHP from our beasts.
          I use 100+ octane unleaded race gas on track days, and I swear the Beast pulls harder. Furthermore, there was a recent (12/01?)study done at Hot Rod magazine with dyno pulls at various octane levels (and with various so-called "booster" additives), that showed better performance with more true octane. The additives proved worthless for adding HP, however.
          BTW, these were done with a pretty basic Chevy big block (if I recall correctly), without the benefit of our truly remarkable BMW DMEs (brains).
          Bottom line: I use it when I can.
          -Dave
          BOTH SOLD!!
          '00 Carbon Black/Black All-Leather/Sportive
          #101421
          Teutonaddict is offline
          Old 13th January 2002, 18:33   #6 (permalink)
          Teutonaddict
          Just where IS that neighborhood CITGO?
          Hey Steve-
          Where is that high-octane pump? I'm coming to Charlotte next weekend to visit my brother (around South Park Mall area), and would love to load up!?
          Just curious. Thanks!
          -Dave
          BOTH SOLD!!
          #101421
          Old 13th January 2002, 18:48   #7 (permalink)
          KirklandM5
          KirklandM5's Avatar
          There have been 2 recent magazine tests on octane. Car & Driver did a test using modern cars and Hot Rod which did a test using a small block Mopar or Chevy (can't remember, but I think it was a Mopar).
          Key Points From the C&D Test.
          On cars designed for 87 octane (like Honda Accords), stepping up in octane made no appreciable gain in performance.
          For cars designed for premium, STEPING DOWN in Octane DID cause the car to LOSE performance. But the computers kept the motors from detonating by retading timing.
          Note that they DID NOT Test RACE unleaded in the modern cars...so it's inconclusive if it would make a difference. But if the cars designed for 87 did not pickup power with premium, it's highly unlikely you'd gain performance going over 93-94 in cars designed for premium.
          Nor did they compare the various flavors of Unleaded Premium, which can vary from 91 to 94 depending on where you live. In addition they did not test the various formulations of gasoline which include MTBE, non-MTBE, CA reformulated etc.
          Note that in California, the pump racing gas...from 76 is a reformulated blend as its approved for the street....so it may have the octane but not necessarity optimal burn rates for power in an engine that does not need it....See below..
          Now in Hot Rod's test they had a 10:1 + compression motor for there test.
          Using 87 the motor made something like 390ish hp,
          Using 91 or 92 they picked up a few ponies, it was less than 10hp
          Using 100 unleaded it picked up around 10-12 from the 87
          The real surpsise was 110 LEADED which made more power than the 100, with LESS ignition timing. This led Hot Rod (and myself) that it's not just octane it's also the formulation of the fuel.
          Even the 100 unleaded racing needs to be formulated as a "Street" emission friendly gas in california.
          2005 X5 4.4i
          Old 13th January 2002, 19:21   #8 (permalink)
          steve adams
          Dave -
          Not sure if other Citgo stations in Charlotte may also have the 100 octane pump ...
          ... the one in our area is north of the city about 17 miles on I-77 , exit 28 (Lake Norman - Cornelius exit) .... take the exit, turn left on Hwy 73 and it is about 1/2 mile down the road on your left .... single pump in center island labeled "racing fuel" ...
          ... they may carry racing fuel since we are situated close to many NASCAR team shops in Mooresville .... those guys probably enjoy running the higher octane gas in tuned personal cars ...
          I may try a tank to see if there is any notice-able performance enhancement ...
          Steve
          Old 13th January 2002, 20:30   #9 (permalink)
          Bart Carter
          Bart Carter's Avatar
          The only available octane in Las Vegas is 91.
          I the altitude requires less, so they take advantage of it.
          -Bart
          2002 Bluewater/caramel
          Any other car is a compromise
          Bart Carter is offline
          Old 13th January 2002, 22:28   #10 (permalink)
          greg
          greg's Avatar
          Best we can get here in CA is 91 octane, plus it is "oxygenated" between October 31 and anuary 1. I recently spoke to a BMW mechanic who told me that BOTH reduce power.
          Based upon personal experience, there is ABSOLUTELY AND POSTIVELY a power increase if you get the octane back up to a reasonable level. Anyting over 96 or so is PROBABLY wasted, but I'm not sure. So you can save money by getting a half tank of 100 mixed with your usual premium stuff.
          Do be sure it is unleaded though - not all race gas is.
          Hey pilots - what about AVGAS? Is unleaded 100 available at private airports? does AVGAS have any additives that might be harmful to our engines?
          greg is offline
          Old 13th January 2002, 22:45   #11 (permalink)
          PhilSeastrand
          PhilSeastrand's Avatar
          Send a message via MSN to PhilSeastrand Send a message via Yahoo to PhilSeastrand
          Steve Dinan said at the Sears Point meet that 100 octane was good for 8-10 HP with the M5. Our software will advance the timing until it knocks, always, so it can take advantage of the high octane -- not all cars do this.
          Phil
          01 M5 Silverstone/Silverstone
          04 Honda Pilot
          02 Indi Blue Mini Cooper (sold )
          PhilSeastrand is offline
