Umnitza ICE problems - BMW M5 Forum and M6 Forums
Old 17th October 2008, 01:36   #1
Doctor J
Doctor J's Avatar
Garage: 2010 E93 M3 Jerez Black
Hi guys,
For the past couple of weeks I've been noticing both right and left side angel eyes/Predator ICE flickering on and off. Most of the time it is the driver's side and other times its the passenger side. I also get the "check side lights" warning on the dashboard.
I checked all the connections and they seemed fine.
what is the cause of this?
2010 BMW E93 M3 - Jerez Black/Fox Red
01' BMW E39 M5 - BBS CH 19s, Bilstein PSS9s and Dinan exhaust - sold
00' Acura Integra Type R - uber modified track car
Doctor J is offline   Reply With Quote
Old 17th October 2008, 04:15   #2
gsfent
gsfent's Avatar
Garage: 01 M5 Black/caramel
Sales Feedback: (3)
Originally Posted by Doctor J View Post
Hi guys,
Could be a ballast. Easy to fix. Contact the seller for a diagnosis and replacement parts.
Old 17th October 2008, 05:06   #3
stilov
stilov's Avatar
Garage: AW 2000 M5
one time I had a wire loose in my lights (I had the angel eyes wired as my parking light) and I would get a check side light. What I noticed was when it said that...the angel eye was not even lightning up...
Garage: 2000 Alpine White M5
PM for more details
Hers: 03 oxford green X5 3.0
DD: 2005 Honda Civc..37.5MPG!!!
stilov is offline   Reply With Quote
Old 17th October 2008, 08:24   #4
RevMan
RevMan's Avatar
Garage: 2003 M5 LeMans Blue
The two most probable causes are
1) The crimp connector provided with the kit may not make full contact as the OEM wire diameter is small and may not make full contact with the metal crimp connector. You can move the crimp connector and see if the light flickers. If so, you have found the problem.
2)As gsfent stated, the ballast can be the problem and just needs to be replaced. Contact the seller.
The "check side light" only means that the angel eyes are not on. The side light receives its light source from the Predator ICE or the OEM lighting element. There is no side light bulb. Once you solve the connection problem or the ballast problem, the "check side light" will go out.
Hi guys,
RevMan is offline   Reply With Quote
Old 17th October 2008, 17:28   #5
Beemer Guy
Beemer Guy's Avatar
Garage: Porsche Pano S
Sales Feedback: (6)
I had the same problem and it was a bad ground caused by those lousy connectors. Take them off and solder the wires in.
HTH,
Michael
2000 Jet Black/Black
2003 LMB M5 R.I.P. 01/02/08
2008 Namibia Orange R1200GS (hence the handle "Beemer Guy")
All the BMWs now sold. Now back in a Porsche. There is no substitute.
Beemer Guy is offline   Reply With Quote
Old 17th October 2008, 21:32   #6
Doctor J
Doctor J's Avatar
thanks guys
Umnitza or Hella ?! SSense E39 M5 and E52 Z8 Discussion 94 7th February 2011 12:55
iPhone owners - 2.02 update fixes BMW iDrive problems [but not all problems] scoopz E60 M5 and E61 M5 Touring Discussion 30 26th January 2009 01:27
My Experience with Umnitza shopard Off Topic Forum 28 23rd July 2008 18:39
AiB 3.0 Vs umnitza (pics) LFC09 E39 M5 and E52 Z8 Discussion 5 14th June 2008 14:16
My experience with Umnitza SCC E39 M5 and E52 Z8 Discussion 30 11th December 2006 19:36
