12th October 2008, 19:27
#1 (permalink)
Myth Busters: Hwy cruising at low rpms?
So here's a question for M-experts.
Is it safe to run the car ~ 2000rpms on highway? I heard about possible problems with manual gearbox  in M-series when driving at lower rpms
This way I average over 24mpg/hwy
Thank you,
Gene
'01 M5 Black/Silverstone
Supersprint complete cat-back system
Supersprint race mufflers
Euro headlights
'04 M3 Black/Black 6sp
12th October 2008, 19:52
#2 (permalink)
Myth.
Happy cruising
D
'00 Royal Red/black/walnut M5
'El Diablo'
’00 Black/black DA s/c M5
Carrillo rods, Arias pistons,
Schrick cams, Vortech T-trim,
Supersprint headers/exhaust,
The Following 2 Users Say Thank You to wilsodh For This Useful Post:
12th October 2008, 23:46
#3 (permalink)
Yea, I would say myth too. M cars are pretty damn well built. If driving at 2000rpm is bad for the gearbox.....I wonder how bad dropping the clutch to show off would be  .
13th October 2008, 04:08
#4 (permalink)
I don't know how running at relatively low RPM could be bad for the gearbox. I can see it being bad for the engine IF at that RPM it was lugging, but the M5 engine is relatively tractable and can usually pull without protest from around 2000 RPM. So long as the engine isn't lugging or knocking at the RPM you are running it at, it shouldn't hurt anything.
Need4Spd
13th October 2008, 04:43
#5 (permalink)
70mph in 6th seems to be the sweet spot for cruising with maximum MPG for me. It's very responsive to pushing the pedal down at that speed, too, so I can't imaging it being hard on the drivetrain.
Not that I bought the car because it gets good gas mileage, but every little bit helps when driving to work  .
13th October 2008, 04:48
#6 (permalink)
Cruising at 2000 RPM  i would fall asleep. hahaha!
The Following User Says Thank You to Cantresjr For This Useful Post:
13th October 2008, 04:54
#7 (permalink)
if staying around 2k is bad then im screwed. around town i can keep my car under 2k rpm through all 6 gears...basically keeping the car at high idle everytime i shift lol
Dinan S2 Suspension
Dinan Monoball
Dinan Strut Brace
Dinan SSK
Dinan S1 soft
B&B triflo exhaust
Linea Corsa Lemans 19x8.5&10
Hella Euro Celis taillights
Hella Euro Celis Headlights
Intravee
13th October 2008, 17:02
#8 (permalink)
You could sacrifice maybe 1 or 1.5 mpg and run between 80-90 mph all day long on the highway.
The way she was meant to be run!
I did this all the way to Alexandria, VA and back.
Read about it here: Gas mileage on our vacation
The Following 3 Users Say Thank You to Mike S. For This Useful Post:
13th October 2008, 18:32
#9 (permalink)
The bottom line in all of this is that without having an efficiency vs. rpm curve for the engine, we're all sort of guessing.
Without the charts from BMW (or someone developing them independently) there really are too many variables to talk about what speed is most efficient.
We do know, however, that there is no issue with running the engine at any rpm in any gear, so long as the vehicle is making sufficient torque for the situation. 30 mph in 6th gear, for example, is fine on a flat or down a hill, but may not be ok going up a hill (depending on steepness). 2000rpm is fine pretty much regardless of situation or gear given the hp available.
d-
The Following User Says Thank You to DouglasABaker For This Useful Post:
13th October 2008, 21:56
#10 (permalink)
Myth.
If you're getting good MPG results, then great. The other part of going along with low rpm is high speed. Obviously, the following is true:
Idling gives you the worst MPG as you're burning gas and not moving.
Coasting gives you the best MPG as you're not burning gas and moving.
Other conditions, such as weather, tire pressure, road condition, are factors as well. Also running accessories, such as the heater, fan, AC, cruise control, radio, and lights decrease fuel economy.
But again, emphasising to the OP, this will not hurt your car.
