• Latest threads
    • Custom feed
      • Updates
        • YouTube
          Old 12th October 2008, 12:59   #1 (permalink)
          Steve Mac
          Steve Mac's Avatar
          Tire Pressure Monitor
          Hey guys
          I am somewhat stumped
          When replacing tyres last year i noticed there were no sensors on them, I wasnt too bothered, a few weeks later the car bonged with trye defect. I ignored it and following morning one of the tyres was a bil low. Upon investigation i found a screw was in the tyre, Got that repaired and put it down to a coincedence, This has happened again resulting in a new tyre this time. Again no sensor
          Now on wed this week it bonged for the fourth journey in succession so i checked the tyre pressures and rear drivers side was at 21psi and the rest between 32-34. I obviously topped up and nothing since
          Question is, how the hell is this happening when there are no sensors on the valves. Or is there a much more intelligent system on these cars??
          Steve Mac
          _________________
          If knowledge is power,,,how brainy are my Baby`s
          2001 Le Mans beast ///M5
          1995 Fjord bitch ///M5
          2002 Black Beauty 320i Sport!!
          decisions decisions
          Steve Mac is offline
          Old 12th October 2008, 13:24   #2 (permalink)
          Neil.D
          Neil.D's Avatar
          It doesnt use anything in the valve, it works on the ABS sensor to monitor rotation. A deflated tyre (mine pings when it has dropped half a bar) is picked up owing to the decreased rolling diameter.
          Neil.D
          2000 M5 Titanium silver
          Stock - The new modded
          ''We sleep soundly in our beds because rough men stand ready in the
          night to visit violence on those who would do us harm''-
          Winston
          Churchill
          Neil.D is online now
          The Following User Says Thank You to Neil.D For This Useful Post:
          Steve Mac (12th October 2008)
          Old 12th October 2008, 13:27   #3 (permalink)
          ECB
          ECB's Avatar
          No internal tire sensors are used. The DSC/ABS brain keeps track of tire rotational speed, so when one tire loses a significant amount of pressure, the rotational speed of that tire will change relative to the other 3 and the warning light let's you know.(or something like that)
          03 Titanium Silver/Black Luxury/Burl Walnut
          Supersprint headers and Race cats, Dinan CAI, High Flow air mass meters, 17mm rear sway bar, TCD sway bar brackets
          Eisenmann Sport Exhaust, Powerchip 93 software, Rogue UD Pulleys, Rogue SSK w/ RP Synchromax fluid, Ultimate Pedals, Euro Armrest,
          Hardwired V1, Angel iBrights v.2, 6000K Low beams, HID 6000K fogs, 70W High beams, Hella Supertones, BSW Speaker Upgrade & 10" Sub, Dension IceLink
          ECB is offline
          The Following 2 Users Say Thank You to ECB For This Useful Post:
          Neil.D (12th October 2008), Steve Mac (12th October 2008)
          Old 12th October 2008, 13:55   #4 (permalink)
          Kelster
          Kelster's Avatar
          M5 Flat Tire Warning
          IIRC the system used in BMWs is a Flat Tire Warning (FTW) not a Tire Pressure Monitor (TPM). FTW works by comparing the number of revolutions of each wheel to determine if one tire is low. The theory behind it is based on the fact that with lower pressure, tire diameter is reduced and the affected wheel rotates faster than other wheels at any given speed. There are no pressure sensors.
          TPM uses a sensor in each wheel to monitor the pressure in that tire. After-market TPM sytems are available.
          2003 Jet Black ///M5 Dinan S3
          621 HP @7000 rpm/502 Ft-Lb @4500 rpm. Vortech V-2 SQ Intercooled Supercharger
          , S3 Oil Cooler, S3 Engine Management Software, Dinan S3 Clutch & Flywheel, High Flow Throttle Bodies & Velocity Stacks, Dinan 4-2-1 SS Headers, Dinan Free Flow Exhaust, BMW 545 Short Shift Kit, Stage 3 Dinan/JRZ Suspension, Dinan/Brembo Brakes, Dinan Pedal Pad Set, Dinan Strut Tower Braces F/R, Dinan Sway Bar, Dinan Lower Control Arm Monoball Kit, Dinan Rear Subframe Reinforcement, 3.45 Differential, Dinan Light Weight 18 x 9 F & 18 x 9.5 R Wheels, 4 Toyo Proxes RA1 275/35R18 /Drags: Nitto NT-555R Drag Radials 285/35R18, Blinder-M45-X-treme, Stealth Valentine 1, Bluetooth, Mk IV Navigation, v29 Perspective & Navtech 2007.2 DVD Map, M Audio with Enhanced Bass, Angel iBrite 3.0, AGA Fog lights & TEC Cup Holder
          1/4 mile: 11.795 @122.20 mph, 60' - 1.819
          Kelster is offline
          The Following User Says Thank You to Kelster For This Useful Post:
          Old 12th October 2008, 16:07   #5 (permalink)
          Steve Mac
          Steve Mac's Avatar
          Thanks for all your replies guys
          Now i wil pay attention to it again as i havent in the past, who said ignorance is bliss??
          Now back to the job in hand
          Steve Mac
          _________________
          decisions decisions
          Old 13th October 2008, 01:11   #6 (permalink)
          jclyman
          jclyman's Avatar
          You should fill the tires to the correct pressure for you (I run more pressure than recommended on the door jam), and then reset the sensor. The reset button is on the dashboard, and then drive it for at least 15 minutes after resetting.
          I got a (near) flat on a brand new set of tires two weeks ago. The "Tire Defect" signal was displayed, and I stopped. The nail impregnated tire (2 screws, rear) was 23% below the other rear (I had read that it can go as low as 30% less, before it registers). First "Tire Defect" signal I have ever gotten (in 5.5 years), but the other flat I had was at speed (over 120 MPH), and never registered. I had since read (BMW documentation) that the tire sensor doesn't register if you are going over 95 or 105 MPH (can't remember which).
          But, if properly set (and, you are going less than 95 MPH or so, which isn't easy), they do work. And, thank heavens they work. If it hadn't worked, I would have ruined a brand new tire. The pressure in the tire that was going flat was 34.5 lbs. The other rear was 44.5 lbs. (Warm tires)
          - Daniel Boorstin
          jclyman is online now
          Old 13th October 2008, 02:06   #7 (permalink)
          razahyde
          razahyde's Avatar
          Send a message via AIM to razahyde Send a message via MSN to razahyde
          ahhh this is really good info to know! thanks a lot guys, i just mounted new rims and tires and was wondering how it worked.
          Dinan S2 Suspension
          Dinan Monoball
          Dinan Strut Brace
          Dinan SSK
          Dinan S1 soft
          B&B triflo exhaust
          Linea Corsa Lemans 19x8.5&10
          Hella Euro Celis taillights
          Hella Euro Celis Headlights
          Intravee
          razahyde is offline
          Old 13th October 2008, 19:13   #8 (permalink)
          whatheheck
          whatheheck's Avatar
          I highly recommend this.
          See my post here for DIY instructions.
          Hella TC-400 Tire Pressure Monitoring System - installed
          Dan
          Supersprint Headers, Tubi Rumore Plus exhaust, Dinan CAI, Defi Heads Up Display, Strong Strut front anti-sway bar, Powerchip 93 S/W, Euro Arm rest, Fikse Profil 5S Rims; Goodyear Eagle F1 GS-D3, Polk Audio Tweeters, Boston Acoustic Speakers, Integrated 60gig Video Ipod, HiDef DICE Radio iPod interface, Icelink, Rouge Engineering Short shifter, StopTech Big Brake Kit, TC Design rear sway bar brackets, HID 8000k fog lamps, 8000K low beams, Euro clear corner HID headlamps, Mark IV Nav, Lamin X films, Predator ICE LED AE, Valentine 1, M20 Blinder Anti Laser, TEC cup holder, All LED interior lights, LED footwell lights, LED trunk lights, Ultimate Cup Holders, Hella TC-400 Tire Pressure Monitor System, etc.
          whatheheck is offline
          What are these tire pressure monitor ase2dais E39 M5 and E52 Z8 Discussion 17 26th January 2006 22:53
          Tire Pressure Monitor Frank E60 M5 and E61 M5 Touring Discussion 19 6th November 2005 02:31
          Tire Pressure Monitor livenupe E39 M5 and E52 Z8 Discussion 1 27th May 2002 17:25
          Tire Pressure Monitor? greg E39 M5 and E52 Z8 Discussion 11 2nd March 2001 00:17
          Tire Pressure Monitor greg E39 M5 and E52 Z8 Discussion 6 30th August 2000 23:26
