• Latest threads
    • Custom feed
      • Updates
        • YouTube
          Old 11th October 2008, 20:42   #1 (permalink)
          huntercross
          huntercross's Avatar
          Question regarding plenum removal
          I am going to take my plenum off in the next couple of days to try to clean out the idle control valve (my idle fluctuates a bit) and replace the throttle valve switch. (is there 1 or 2?)
          My question is, do I need to replace any of the plenum or throttle body gaskets when doing this? Also, any insight to cleaning out the idle control valve or replacing the throttle switch would be appreciated.
          huntercross is offline
          Old 12th October 2008, 20:10   #2 (permalink)
          J Irwan
          J Irwan's Avatar
          I think depend on the condition of the rubber gasket. If it is deteriorating then you should replace it.
          On mine I did not replace mine as the intake plenum gasket still in good condition (when I replaced the "fuel tank breather valve" under the plenum).
          Regardz,
          J Irwan
          02 Carbon Black ///M5
          J Irwan is offline
          Old 12th October 2008, 23:11   #3 (permalink)
          mfizzlenyc
          mfizzlenyc's Avatar
          From what Ive read and done you must replace the gasket upon removing the plenum
          2000 Silverstone M5
          Dinan CAI
          Dinan Headers
          SS race cats
          SS X pipe
          Dinan Cans
          Dinan Flywheel
          Dinan 3,45 Diff
          Dinan S3 Suspension koni
          Dinan S4 Software
          Rogue SSK
          Rogue Tranny mounts
          BBS LMs
          Winters Mod list
          BMS -Throttle body tunning- stage 3 inspection
          BMS -Dinan Sub frame reinforcement kit
          Dinan- Bms- (Daytona prototype engine build)
          mfizzlenyc is offline
          Old 13th October 2008, 00:25   #4 (permalink)
          J Irwan
          J Irwan's Avatar
          That would be depend on the condition and the mileage.
          My beast had around 36K when I removed the intake plenum, the rubber gasket still pliable and solid.
          This intake plenum gasket (sandwiched between the top and the bottom intake plenum) does not see as extreme heat like say "Valve cover" gasket or "head" gasket.
          If you ever open the valve cover, I would alway replace that.
          Although one thing I forgot mentioned to the OP. There are 16 "self-locking" nuts that should be replaced (self-locking nuts ideally to be used only once).
          These are the nuts that secure the original (8) Air intake funner/trumpet to the lower/bottom intake plenum.
          My $0.02
          Regardz,
          J Irwan
          J Irwan is offline
          Old 13th October 2008, 21:58   #5 (permalink)
          everycredit
          everycredit's Avatar
          You "should" replace it, but you may not "need" to repace it.
          Don't use gasket in a tube stuff. Recoat with glycerine to prevent friction from putting the cover back on and prevent tearing. Glycerine can be in suppository form, personal lubricant, or Mr. Bubbles. Pick whatever is most convenient and least embarassing.
          everycredit is offline
          Old 14th October 2008, 01:12   #6 (permalink)
          huntercross
          Hahahaha!
          Thanks for all the input. Does anyone have any tips for both cleaning the idle control valve and replacing the throttle valve switches?
          Plenum Question eclips E39 M5 and E52 Z8 Discussion 3 10th July 2007 06:57
          Question: Removal of Cats VanM E39 M5 and E52 Z8 Discussion 37 17th October 2006 16:36
          Plenum removal help please Pete E39 M5 and E52 Z8 Discussion 0 10th June 2005 03:07
          Wheel removal - dumb question dwasifar E39 M5 and E52 Z8 Discussion 37 25th March 2003 20:50
          Really Stupid Battery Removal Question !! IvanDias E34 M5 Discussion 2 9th February 2002 19:16
          Page generated in 0.19577 seconds with 11 queries
