Car won't start after heavy rain... Ideas? - BMW M5 Forum and M6 Forums
Old 30th September 2008, 06:19   #1
Fiori
Fiori's Avatar
Garage: 2001 BMW M5, Carbon Black/Silverstone
Sales Feedback: (3)
Guys, any idea what t can be??
I got rear-ended a while ago.
The car was fixed, however when it sits in really heavy rain a bit of water gets in the trunk area, a few drops or so...
As a result, the car won't start, however, the starter still shows signs of life.
It happened once before. I then jump-started it without any problems and drove for another month or so.
So, we had pretty heavy rain in Boca on Sunday and this morning I couldn't start it again. Dead! Not a single light on the cluster
Tried to jump-start it - no luck...
Then the AAA guy came over - the board computer came on, got power on the instrument cluster, the headlights came on too, however it still wouldn't start, just a few chokes...
I was told it had nothing to do with the battery and the starter seemed to be fine too...
Maybe, bad wiring isolation, since there are so many wires in the trunk area?
Thanks,
Gene
'01 M5 Black/Silverstone
Supersprint complete cat-back system
Supersprint race mufflers
Hella clear euro headlights
Umnitza 6000K Predator Ice V2
Bimmian black shadow grills
545 SSK w/E46 M3 CSL suede shift knob
TEC cup holder
'04 M3 Black/Black 6sp
Fiori is offline   Reply With Quote Quick reply to this message
Old 30th September 2008, 08:42   #2
ard
Super Moderator
ard's Avatar
How old is the battery?
ard is offline   Reply With Quote Quick reply to this message
Old 30th September 2008, 13:13   #3
Envisage0
Garage: E39 M5 Avus Blue
Good point about the battery. If it's original, it's about at end-of-life in a MY2001..
**** it, let's do it - Australian proverb
"If you are in control, you're not going fast enough."
Mario Andretti
Envisage0 is offline   Reply With Quote Quick reply to this message
Old 30th September 2008, 19:06   #4
andy777
andy777's Avatar
Garage: bmw e39 m5 midnight blue (carbon shwarts)
I would go with the battery and who fixed the car after your crash?
andy777 is offline   Reply With Quote Quick reply to this message
Old 30th September 2008, 21:00   #5
ard
Super Moderator
ard's Avatar
Oh, and bring it back to the body shop to fix the leak. Depending on your insurance, they should offer a lifetime repair warranty. and don't let them jury-rig a fix, should be working as designed by the factory!
The Following User Says Thank You to ard For This Useful Post:
jclyman (1st October 2008)
Old 1st October 2008, 14:46   #6
Fiori
Fiori's Avatar
Sales Feedback: (3)
The battery is dead but it's been installed a month ago.
They couldn't find the problem yesterday, so I think of taking it (towing) to a diff place.
Though the mechanic suggests it might be the fuel pump.
The car cranks, but won't start
Old 1st October 2008, 16:34   #7
gsfent
gsfent's Avatar
Garage: 01 M5 Black/caramel
Sales Feedback: (4)
One quick way to check for fuel is to pull a plug after a bunch of no start cranking. If the plug is wet, it is getting fuel and generally, if one cylinder is getting fuel, they all a
Does anyone know of the old trick of spraying ether into a carb to help start would work if sprayed directly into the throttle bodies?
gsfent is online now   Reply With Quote Quick reply to this message
Old 1st October 2008, 17:06   #8
awise1961
awise1961's Avatar
Garage: 2002 M5 Imola Red, 2001 540iA Sport Titanium
If it was the fuel pump a shop would test for this by applying a gauge to a test port and cranking the engine accordingly.
Has your shop tried this?
Al. Wise
awise1961 is offline   Reply With Quote Quick reply to this message
Old 3rd October 2008, 01:40   #9
Fiori
Fiori's Avatar
Sales Feedback: (3)
Ended up taking my car to a different mechanic, who specializes in BMWs.
It took him 15 minutes to figure out the problem.
He knew right away it was fuel system related... the fuel pump relay melted and I had it replaced for $50 + labor
The Following User Says Thank You to Fiori For This Useful Post:
TopEnd (3rd October 2008)
Won't start after clutch install- ideas please Dr Pooface E39 M5 and E52 Z8 Discussion 38 4th August 2012 14:23
Rain..Rain go away...PICS paulalger E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 8 24th July 2011 14:02
M5 Stuck in Gear - Won't Start - ? Ideas? supercup E60 M5 and E61 M5 Touring Discussion 2 18th July 2008 13:50
Anyone with RPI scoops drive in moderate or heavy rain? ALTANertive E60 M5 and E61 M5 Touring Discussion 13 12th January 2008 10:08
Driving in heavy rain - not fun - tire suggestions? bboomer E60 M5 and E61 M5 Touring Discussion 28 25th November 2006 23:04
