Old 23rd September 2008, 09:32   #1
andy777
andy777's Avatar
Garage: bmw e39 m5 midnight blue (carbon shwarts)
Is this true?
1. Push & hold the ASC+T/DSC button (for approx 10 seconds)...the instrument cluster light will illuminate...THEN...will go off.
2., When the light goes back off...you are in a half-on/half-off mode...where the brakes will still be applied to a wheel that has lost traction...but the engine throttle reduction part of ASC+T/DSC is off.
once this mode has been activated...the only way to deactivate it is to turn the engine off...the next start-up will put the system back in default mode (ASC+T/DSC on).
andy777 is offline
Old 23rd September 2008, 14:09   #2
dave_gt
dave_gt's Avatar
Garage: E39 M5 Le Mans Blue
1) This mode does exist and it is found like you said by holding the DSC button for about ten seconds.
2) Last time it was discussed there was some disagreement on exactly how it differs from normal DSC on mode. I've tried it a few times in the wet and deliberately lost traction to see how it performs. It felt to me like power was still being cut rather than just brake application and the engine note softened like it was not maintaining full power. It did seem to cut the power a little less viscously though, and the system seemed to return power to me faster than with normal DSC on. Still no chance of getting the back end out powering out of a corner like you can with the 'race' mode on the TC of new Ferraris and the like, but it did seem a bit less intrusive.
2001 M5, Lemans Blue / Silverstone
Standard except for a few bits & stereo:
6.5" Focal components, 10" Directed sub, IceLink, JL Audio & Directed amps (hidden). Predator ICE, Stealth bulbs, V1, Roadpilot
1990 Mazda MX-5 (brilliant) 1998 Nissan Primera GT (modded)
dave_gt is offline
Old 23rd September 2008, 18:45   #3
Blockdoc
Blockdoc's Avatar
Garage: 2003 Sterling Gray M5
IIRC, we sort of came to the conclusion that it doesn't do anything? I believe that it was never programmed into our ECU?
I may be wrong, but that is my recollection.
Brian
2003 Sterling Grey M5
Dinan Free Flow Exhaust, Dinan Rear Sway Bar
Super Sprint Headers
Custom tuned by ESS
Rogue Octane SSK and WSR
DICE Ipod connectivity
Bimmian Black Kidney Grilles
Ultimate Pedals
Rear Wheels Up Front (275s all around)
Supercharged by ESS!! (Kit number 01)
Blockdoc is offline
Dreams do come true. Cyrus E34 M5 Discussion 15 24th October 2005 12:57
Can it be true? UKMFreak E60 M5 and E61 M5 Touring Discussion 5 22nd September 2005 23:40
Is this true? blue max E39 M5 and E52 Z8 Discussion 1 15th November 2003 04:40
Is it True that...... TC M3 E90 M3 Sedan, E92 M3 Coupe, E93 M3 Convertible, E46 M3 and E36 M3, Z4 M and Z4 M Coupe 1 23rd May 2003 22:48
Page generated in 0.09925 seconds with 11 queries
