Old 23rd September 2008, 08:05   #1
jfman
Garage: 2000 E39 M5
Vibration under acceleration
Well after some much spirited driving witht the dsc light off, my car started vibrating a little under acceleration.
I am thinking it's the center bearing for the driveshaft???
If so, where can/should I get one?
Also could it be something else?
Any other maintenance items that will be easier to access while it's all apart?
(oOO \ (||||)(||||) / OOo)
2000 M5 - a quarter million miles and counting.
2002 325xit waggen' with a stick
jfman is offline
Old 23rd September 2008, 16:29   #2
m5 deamon
m5 deamon's Avatar
Garage: 2001 e39 m5 carbon black on black sport interior
Send a message via AIM to m5 deamon
before you condem the center bearing did you ck the flex disk between the transmisson and driveshaft. Also is the vibration coming from the rear half of the tunnel or is it up by the shifter?
2001 m5 Carbon Black, Black sport interior, m audio
AA cai with bmc air filters
AA software going to change to either ess or pc
UUC Light Weight FlyWheel And Organic Clutch
UUC evolll ssk \ Dssr
UUC Big Boy Clutch stop v3
UUC Transmisson mounts
Steelbraded clutchline
Eisenmann Race Exhaust 83mm tips
Supersprint X pipe
Steel braded brake lines
Dinan rear sway bar
Dinan stress bars front and rear
Tc swaybar brackets
PS2 tires
Axiss ult pads front and rear
Dinan JRZ suspention kit
Euro head lights
Predator ice v2.1 angel eyes
Bimmian black kidney grills
DDM xenon fog lamps
Solaris amber bulbs
led lic plate lights
v1 hardwire
m45 blinders updated version
To Come... dinan headers, stoptec bbk
m5 deamon is offline
Old 23rd September 2008, 22:37   #3
jfman
Garage: 2000 E39 M5
It's hard to say where the vibration comes from. I would saly from the backseat area.
jfman is offline
Old 23rd September 2008, 23:31   #4
Neil Mukerji
Neil Mukerji's Avatar
Garage: E39 M5 Black
I have a bit of a vibration under acceleration in high gears at low revs. I guess it's the prop donut, but then I'd not heard of this flex disc between transmission and driveshaft. At some point I plan on acquiring a new clutch (slips a little sometimes) and I'll see what else is knackered around there as I strip it all down.
Neil Mukerji is offline
Old 24th September 2008, 22:22   #5
Kmac
Kmac's Avatar
Garage: Alpine White E39 M5; Carbon Black E46 M3
The guibo is a common failure item.
E39 M5 MY'00 (FOR SALE)
Rogue Engineering SS Kit/Rogue Clutch Stop/M Aluminium Pedals/Hardwired V1/TEC Cupholder/Titan Trim & door handles/Bimmian Knob & E-brake/Euro Arm Rest/Alutec Strut Bar/M3 Steering Wheel/35% tint/Centric Rotors/Axxis ULT's/SS Brake lines/16:9/MKIV/IntraveeII/Tubi Exhaust/AA Cai/Conforti Shark Injector/TC Design Brackets/Dinan Stage 1 Suspension/Bavarian Auto Poly Trailing Arm Bushings
E46 M3 MY'01/100k miles
TCKline Double Adjustable Coilovers/TCKline Adj Camber Plates/Delrin bushings/TCKline Racing wheels (18x10 - 19lbs)/Bridgestone RE01A 265/35r18's/Wheel Studs/Goodrich SS Lines/UUC SS Kit/ZHP Knob/Hardwired V1/XM Radio/CF Hood/CF Fenders/Dust cover delete\Dinan Front strut brace/GC Sway Bars/Superprint Stepped Headers/Rougue Midpipe w/dump valve/Random Cats/Supersprint Race pipe/Rogue Diablo Exhaust/Rugue Pullies/CSL CF Airbox/Alpha N software/StopTech BBK
E90 M3 MY '08
Bone stock
"For Sale: 20th Century French Rifle - never fired, dropped twice."
Kmac is offline
Old 24th September 2008, 23:24   #6
TopEnd
TopEnd's Avatar
Garage: 2005 M.Benz E55 AMG
Could be the center-line bearing, however like others have suggested the flex-disc/ Guibo is a more common failure...
TopEnd is offline
Old 24th September 2008, 23:35   #7
jfman
Garage: 2000 E39 M5
Yeah I'm going to replace both of them. Is there a guibo on the rear diff? And where can I buy these parts online?
Is pelicanparts.com any good as far as pricing goes?
They want 120 for the guibo and 85 for center support bearing (both OEM bmw parts)
jfman is offline
Old 25th September 2008, 07:51   #8
stilov
stilov's Avatar
Garage: AW 2000 M5
I have a vibration as well...although I would call it a little more of a bounce that I feel when under acceleration. I I put it in 6th at say 35-40 and stomp on it...it is worse and I even got a small smack. I had the exhaust off this weekend...sure enough cracks in the guibo. Got one on its way.
Garage: 2000 Alpine White M5 FOR SALE 7/00 build revised rings
PM for more details
Hers: 03 oxford green X5 3.0
DD: 2005 Honda Civc..37.5MPG!!!
stilov is offline
Old 9th October 2008, 08:09   #9
jfman
Garage: 2000 E39 M5
I bought my center driveshaft bearing along with the guibo and the transmission mounts and a new clutch as well.
Do I need a press to replace the center bearing ? How does it come off ?
jfman is offline
Old 9th October 2008, 08:14   #10
everycredit
everycredit's Avatar
Garage: 2000 E39 M5 Carbon Black
Get it on the lift and have someone underneath it and have someone run it. You'll see the issue very quickly.
Until then, you're just speculating.
everycredit is offline
The Following User Says Thank You to everycredit For This Useful Post:
jclyman (9th October 2008)
Acceleration WIRELESS E39 M5 and E52 Z8 Discussion 1 22nd December 2002 01:48
Acceleration SKXM5 E39 M5 and E52 Z8 Discussion 9 26th June 2002 07:55
Better Acceleration! MAH E39 M5 and E52 Z8 Discussion 13 16th November 2001 18:55
No acceleration m5james E34 M5 Discussion 7 26th March 2001 19:25
Acceleration David Cheresh E39 M5 and E52 Z8 Discussion 13 18th September 2000 02:23
Page generated in 0.12684 seconds with 11 queries
