Old 23rd September 2008, 02:16   #1
Evilburn
Evilburn's Avatar
Garage: 2001 Alpine White M5
Peake Code Woes
I have tired searching for a solution to my question but haven't found anything specific enough, so I apologize in advance if the answer is already available.
About every other time I do a wot run in second or third gear it'll throw an SES light. And every time it is some combination of misfire codes always involving multiple cylinders. Other symptoms include slightly rough idol and lots of hesitation and bucking before the engine is up to temp (without the ses light).
I am confused where to start as I seem to only be registering symptoms, no sources.
In talking with a few other guys the symptoms seem like they may stem from a faulty crank position sensor. Is that a good place to start?
Thanks in advance to anyone who can offer any help!
Evilburn is offline
Old 23rd September 2008, 02:19   #2
mottati
mottati's Avatar
Garage: '91 M5 AlpineWhite II
id replace the mass airflow sensors if they haven't been replaced in the past 50k miles.
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Old 23rd September 2008, 03:40   #3
ard
ard's Avatar
Disconnect the MAFs and see how it idles. Seriously.
Hold off on that crank position sensor...you'd likely see camshaft position errors along which crankshgaft position errors.
What fuel flow numbers can you get when you do DavidS MAF test?
ard is offline
Old 23rd September 2008, 19:13   #4
Evilburn
Evilburn's Avatar
I haven't had a chance to test the MAFs yet, but I'll try and do that soon and report back.
What should happen when I disconnect the mafs at idle?
EDIT:
I just ran out at lunch and ran the MAF test and got a max reading of about 90 at 7000 rpms wot in second gear. Adjusted and its still below 100. So I guess new MAFs are a must, hopefully that will help with some of the other issues as well.
Evilburn is offline
Old 23rd September 2008, 21:12   #5
TurboCarrera
Garage: 00 M5 Silver
I don't think the car will run at all with a bad crank position sensor - my mercedes was dead in the water with a bad one. However, the M5 will run with a bad cam position sensor.
Steve
00 M5
TurboCarrera is offline
Old 23rd September 2008, 21:46   #6
andy777
andy777's Avatar
Garage: bmw e39 m5 midnight blue (carbon shwarts)
Are you should you are in the right mode for testing the maf's, 90 l/h is quite bad. For the maf's test you need to hit the button twice for l/h.
andy777 is offline
Old 23rd September 2008, 23:28   #7
REKIII
REKIII's Avatar
Garage: 2001 Jet Black M5
Sales Feedback: (5)
I did the tests with Adam at lunch. We had it in the right mode, besides, 90 in any mode would be bad I think.
He did notice a slight short lived improvement when he cleaned the mafs a couple weeks ago.
The reason we deduced the bad crankPS is because of this SEL only coming on at high RPM during a Full throttle run. The car would go into limp mode then a shut down start up of the engine would make the EL and limp mode go away.
The MAF's definitely do not appeat to be operating correctly though.
Also, I'm pretty sure the dealer history said that multiple CamPS's have been replaced in the last 15K.
Bob
2001 Jet Black M5
2006 Jeep Grand Cherokee Limited 5.7 HEMI
2001 Dodge neon - Slomatic winter beater
REKIII is offline
Old 24th September 2008, 00:05   #8
Evilburn
Evilburn's Avatar
Bob
That's correct, though I'm not sure if all or only a couple were replaced.
Thanks for the added info Bob, sorry about the initial exclusion of that.
Evilburn is offline
Old 24th September 2008, 02:53   #9
Capt. Willard
Capt. Willard's Avatar
Garage: 2001 BMW M5 Anthracite
My 2001 M5 49,000 miles just developed the exact same symptoms within the last week. I had the dreaded oil filler cap failure blow about two and a half quarts of oil all over the passenger side of the engine bay a few weeks ago. I cleaned every thing up pretty well but have not checked the air filters yet for oil contamination of the maf. I'm hoping that is all it is and not oil soaked coils or something worse. I will be watching this thread closely....
Capt. Willard is offline
Old 24th September 2008, 03:29   #10
ard
ard's Avatar
I
This is classic bad MAF! The DME is protecting the engine since it sees that fuel is way off.
(When you disconnect the mafs at idle the DME (obviously) ignores the MAF and runs on a mapped air/fuel... which will, if the MAFs are real bad, result in a SMOOTHER idle.)
Bad cranksensor and the car will not run - more common after a clutch replacement and someone misaligns it.
ard is offline
PEAKE CODE READER NAT E39 M5 and E52 Z8 Discussion 22 20th July 2008 18:41
PEAKE code definition please Blue Angel E39 M5 and E52 Z8 Discussion 8 1st June 2008 01:01
Peake Code Reader kiddhan625 E39 M5 and E52 Z8 Discussion 3 21st August 2007 14:47
Help with Peake Code Please! Jefsmr2 E39 M5 and E52 Z8 Discussion 3 22nd June 2007 03:06
Peake Code Reader - Code 69 BrokeManWorkin E39 M5 and E52 Z8 Discussion 9 3rd February 2007 06:03
Page generated in 0.14954 seconds with 11 queries
